举报
dylackman 发表于 2013-10-31 10:16 static/image/common/back.gif9 i+ u+ h) q1 J% W6 J2 M+ ~ 材料硬度多少?是不是太硬了?
zhitao 发表于 2013-10-31 22:42 static/image/common/back.gif - k- f+ N7 S e' m( @7 u$ P楼主用的机加丝锥还是挤牙丝锥,还有,底孔尺寸是合理,攻丝机的参数设置是否合理,比如转速等
gaoyns 发表于 2013-11-1 09:43 static/image/common/back.gif * L0 T' ?% V/ R+ b3 z50Mn为合金结构钢,强度可达900MPa,延伸率低,攻丝前需退火,退火后硬度为229HB。若未退火硬度大、强度高, ...
糊涂啊弥 发表于 2013-12-9 22:35 static/image/common/back.gif! U! O& f- U% a$ U 硬度260HB左右
liuzhugang 发表于 2013-12-17 13:29 static/image/common/back.gif8 ]' O K* |* [ 螺距太大,一般采用旋风铣,或者攻丝的时候采用菜油,菜油比皂化油等效果好
本版积分规则 发表回复 回帖并转播 回帖后跳转到最后一页
Powered by 3dportal X3.4 Licensed Copyright © 2001-2013 Comsenz Inc.
GMT+8, 2026-5-3 13:17 , Processed in 0.137247 second(s), 27 queries, Gzip On.
