我用 E9.0 E10.0 软件自带的 gpp2test.df2 GPP2TEST.dx2 gpp2test.ex2 进行后处理 代码如下
4 \( ?3 {& y8 a
1 G( E7 o9 m/ H5 s+ ~
7 K- U( r; j2 l: M: X很想知道如何使用,怎么处理出来都是这样的代码 要怎么样才能改好???
6 ~6 E% V) U/ u* i# G; i( q+ ]-- STARTUP : 5 d2 ?9 V" j U5 r: g ?# Y
--- BEGINNING OF TAPE :
. @0 R" U/ e) Q/ U% J' i5 e: y+ rBLOCK_NUM = 0: M | b. ~% C' p8 H
REF_NAME = NC Setup6 j p* m- o$ T! n
DATE_SDD = 23) ~, z' r" f% f. o
DATE_SMM = 2
s- L9 b, f! O3 |) RDATE_SYY = 2013
! X* V, N9 D6 }2 dTIME_SHH = 20/ F0 L0 Z! T+ W% \$ [; x5 c. P
TIME_SMM = 7( x5 ^2 S5 [6 g; ~: p$ N* ]6 G7 I- G3 ~
TIME_SSS = 2
n3 A) K) ~$ {, R1 V9 MMACSYS_NAM = M_MODE 8 v0 s% I1 R6 h* f* w$ R
NUM_ORIGS = 11 [% Y0 b; S2 `
PFM_UNITS = MM
) G4 J% U9 p) G* _' @5 W$ _+ VUSER_NAME = Administrator
9 b' U" J5 g' k) iNODE_ID = 00007FFF
0 B$ D8 k' R" D2 q; v/ L; [X_HOME = 0' {9 `6 Z3 O7 x7 R1 C& ^
Y_HOME = 0
+ S, |6 M( {. IZ_HOME = 100.0010681152 C! _4 g4 o6 C( B" a
X_MACH = 0& n& q' }: C; l8 O: q, {9 u0 `
Y_MACH = 03 e; h) j- @, e0 g7 E. L0 y. J5 N
Z_MACH = 0# q6 o( X; z; P. j3 f9 E
EXT_POST = 0
8 F; l8 L) N$ F+ G0 J1 e" |- VFACTOR_ = 1 ; P$ ^+ @; h4 r
FILE_NAME = 15_3.FULL-3X.gpp2test
+ d) ?1 ~: l3 }5 VOUTPUT_DIR = C:\
7 c; I5 u% ?4 m: {PLATFORM_ = NT
0 p1 E, X. o- F; h) n$ a2 G6 U& P# k! HPART_NAME = 15_3# y( N! d9 O1 p0 G4 ^/ |8 _
PART_PATH = E:\ch15
/ p) e0 ~* @7 n% d( y& T: ~POST_NAME = gpp2test5 b7 G; J( N6 q* ~6 V! s) q
TP_BLOCKS = 58741 |
