查看: 1173|回复: 1
[求助] 关于一键转X-T图档宏的问题
发表于 2013-11-25 13:57:48 | 显示全部楼层 |阅读模式 来自: 中国广东东莞
: w1 T  K/ t  e8 P) p
这样的一段代码怎么写,求指点:转档成X-T时,保存的文件名为提取Description当中的字符,如果Description当中没有字符,则以原文档名称保存。7 D4 Z- F9 b) g9 H
Dim swApp As Object$ K! ]3 Z, F: D7 G" {7 o+ `: i3 i
Dim Part As Object$ o- [- A1 ^! D+ a- b& Y* m. p$ Q& x
Dim boolstatus As Boolean
$ g' X9 I, \8 g- @1 C" NDim longstatus As Long, longwarnings As Long2 Z/ t6 |, R# Y+ I# w
Dim Locatie As String
2 x4 ^0 F3 ~7 A# n) ]Dim Locatie_aangepast As String& }# B. Q, E: ?6 x8 W0 R- A
Dim OpenDoc As Object. G. F! x' J5 @2 @( d0 p- y+ T
Dim Extensie_nieuw As String8 @. i7 X9 p! R& Y6 @
Dim Extensie_oud As String
& j7 c( z! g) O- _5 UDim retval As String, |- W3 F) V/ v, L6 A; D% L. e
Dim Naam As String
/ G! b5 `) U2 h+ {3 ?0 MDim Naam_aangepast As String# Z4 k5 O4 n) h3 j9 V% N, v- n( J
. e8 j/ e4 w7 b  l  X9 R! p4 r; \4 q2 T4 W
Sub main()" A7 Y% P1 H/ A7 I
Set swApp = CreateObject("SldWorks.Application")( U+ e( j  G& {( M, E
Set swModel = swApp.ActiveDoc
+ [% i) j( f' W$ R' z8 ?Set OpenDoc = swApp.ActiveDoc()
2 i6 k1 G" i) R% MExtensie_oud = ".SLDPRT"9 x4 f% J! n. r% }) w  F
Extensie_nieuw = ".x_t"
3 K) `" }% A1 b- DLocatie = OpenDoc.GetPathName
0 B+ o7 f! r: [; i7 ?Locatie_aangepast = Left(Locatie, Len(Locatie) - 7)
+ {9 A; F7 D- g- @  E9 d4 ~retval = Dir$(Locatie_aangepast & Extensie_oud)$ x- [% \$ [& e* i$ J# z. I
Naam = Dir$(Locatie)# u7 {/ q) i1 s3 l* j) |/ d  L
Naam_aangepast = Left(Naam, Len(Naam) - 7)  X( N# Q! o; b! B, f, {, j4 Y+ W, ]
Titel = OpenDoc.GetTitle% T- f  Z6 y' b8 k" |
Titel = Left(Titel, (Len(Titel)))
" O: d6 p: g- _# t: J. {
- W" e1 x& @/ A7 s; N' x2 S
5 `. k" u( N7 p. L2 i9 n
 楼主| 发表于 2013-11-26 07:58:05 | 显示全部楼层 来自: 中国广东东莞
自己来顶一下,等高人
