查看: 4393|回复: 4
[求助] 为什么hypercad和TD不能共存
发表于 2014-1-1 16:18:57 | 显示全部楼层 |阅读模式 来自: 中国山东烟台
td和hypercad差不多,我们用的正版的hypermill,挂的hypercad,再装td2011,hypermill就打不开了。显示hypercad的t3gen和TD的t3gen有冲突。求大神解决怎样在一台电脑上让二者都存在。因为想用TD三维造型。% t! ]: h. x5 g) m* r
发表于 2014-1-1 20:04:04 | 显示全部楼层 来自: 中国江苏无锡
2 Z% y* J* L7 s& B6 M* B* i# i5 a+ `5 H$ w  [: _
Co-existence of different versions of the ThinkDesign Suite
: x( L* O( P9 l" q5 I
- `& v6 [7 x7 Z) c5 s! O" z+ dDifferent versions of the products of the ThinkDesign Suite can co-exist alongside each other on the same computer. To have different versions operating on the same PC, you must restore the register of the Dlls needed to run the version you wish to use.
" d% p5 J% `1 j6 _4 Y To use a version of the ThinkDesign Suite which is different from the last version installed, proceed as follows:7 H+ g0 a$ g6 s! T2 k, H8 d
9 ?2 N% _' [3 D5 m& i1.Open the "C:\Program Files\think3\2011.1\common\utilities" folder (if you installed to a different folder, open the "common\utilities" subfolder under your own installation folder).2 Y% x8 ~: q7 N; p- D
2.Double-click switch.exe.5 i, h/ k1 A3 n* L  U: t3 Q
3.In the list, select the version of the product you wish to use. With the double-click the dll registration will be automatically performed and the selected version will be started.  R$ n8 c8 J9 v1 B. b
发表于 2014-1-5 21:56:07 | 显示全部楼层 来自: 中国广东深圳
搜索安装目录的 SwitchUI.exe 运行这个文件,选择你要挂在哪个CAD平台.
发表于 2014-1-6 15:17:01 | 显示全部楼层 来自: 中国广东广州
把hypermill挂到TD上不就可以了吗
发表于 2014-3-27 11:35:52 | 显示全部楼层 来自: 中国安徽芜湖
楼主能提供hypercad最新的版本吗
