' |, @) S( ~: t3 o/ L
" Y. o- E% V7 g1 T7 T4 R! _6 e. O) Z%
$ X9 H* G6 p. T+ k/ R% sO1001/ q6 [$ z4 T. h4 d
(O1001)# {( J4 h7 k' }6 o1 B( P& d
(DATE=DD-MM-YY - 10-02-14 TIME=HH:MM - 11:43)
* U# _$ Q9 D( C: e4 I& N/ u# g5 p- u3 {(MCX FILE - O1001)
' `, I6 Q5 l3 K: Y! m# J4 W(NC FILE - C:\USERS\JUN\DESKTOP\O1001.NC)
' N6 ^1 p: e. z% }' h(MATERIAL - ALUMINUM MM - 2024) J7 b; X5 D- ^
( T1 | 10. FLAT ENDMILL | H1 | D1 | WEAR COMP | TOOL DIA. - 10. )& E% o/ c# m! m
( T2 | 10. DRILL | H2 )4 s3 X" `; F ~1 n: c
( T3 | | H3 )% o# `8 G+ I, W+ D, Z+ T/ u
G21
! w- ~: N& o4 O7 I" H3 r3 O" jG0 G17 G40 G49 G80 G90! f `* ]3 |/ M% s% H. F- f
T1 M68 G9 e9 W& N, w5 o5 C* D' M: U
G0 G90 G54 X-109.578 Y0. S3500 M3. G0 ~8 z+ ~2 J; C5 g/ X$ s
G43 H1 Z20. M8 T2
- A. h) Z0 l+ ^: v4 J" H; UZ2.
6 \8 A% V6 [: L. J$ j7 u2 tG1 Z-2. F3.6
, q* `' x* ]. H7 N( O1 n8 z- sG41 D1 X-99.578 F1000.
9 k: t' G0 g! R3 t; I% \G2 X0. Y99.578 I99.578 J0.
9 V+ a, I5 V) _. [X99.578 Y0. I0. J-99.578
9 r- j, }( G9 r/ \ o4 lX0. Y-99.578 I-99.578 J0.5 }/ {3 |0 t9 n
X-99.578 Y0. I0. J99.578" z+ x C" P% Q; E L2 C j! u9 x q+ X
G1 G40 X-109.578 j3 d) ~% d$ I, C3 u4 s
G0 Z20.
1 e% ^" ?; X' eM5
4 z7 p9 V7 @, Y/ y( }G91 G30 Z0. M9
2 W# {- S; C/ R. f8 L3 ^" y6 c5 CM01
1 a3 C& y3 H5 K0 b: d6 |' l- HN2 T2 M65 a( d0 W* c0 g5 M
G0 G90 G54 X-77.951 Y-23.682 S1000 M3, Y: O0 D+ e4 ?/ E* A7 L* _) [
G43 H2 Z20. M8 T3
* {4 L" }, x& `, J- ZG98 G83 Z-10. R2. Q3. F200.6 Z/ u- K& m7 q- P2 ]
X-32.568 Y-28.038
, y- R3 s) V D% S& CX31.813 Y-37.751
5 ~2 A/ a) F" b3 \" IX45.478 Y19.435
6 i4 s. f2 ?) M5 f2 ZX-33.729 Y73.684
) m r P, N! V! @G80 Z20.
0 ?0 r5 ]- y# p! I% K, DM5% o: V& G% {, s* O% N
G91 G30 Z0. M9
! M9 g! T4 j8 [+ bM01
9 V' X, y$ Z$ x2 Q& g) j! P, H3 nN3 T3 M65 t: p' f8 ^$ x# _
G0 G90 G54 X-77.951 Y-23.682 S300 M3+ [7 O/ L7 E3 ~
G43 H3 Z20. M8 T1
a; D& c. I) h4 }8 _% l" q! QM29 S300
% s/ Z0 k) s1 ~- W8 BG98 G84 Z-8. R2. Q3. F300.
/ M* B8 @' \& L6 k tX-32.568 Y-28.038& {4 n6 c3 Z0 t6 H
X31.813 Y-37.751
5 X O" v" S* H' e: AX45.478 Y19.435
0 j* ^1 b5 @# F) S9 M4 y- w1 @X-33.729 Y73.684
3 G. j) j" @! Q# L& yG80 Z20.
" r4 d' R. S& Y5 DM5
H5 |/ x. T2 ] F5 x6 B3 xG91 G30 Z0. M90 ]7 z6 z4 |& G6 |: Z |
G28 Y0.# n1 Q! o E) w9 j4 `6 g
M30* b% G) a0 Z4 T( K5 U; ^$ g) m% g
% P4 ]; p( E& T
这是法兰克的 有刀库 带备刀 下载链接: http://pan.baidu.com/s/1o6I0Osi
6 z) E: Y2 z0 L5 s$ O5 E: r I %
0 I( k7 S9 G* w! D: n+ T" PO1001
( T( J+ o# x; l" V; C9 L ]6 v(O1001 3) }0 I$ e( F5 {/ i9 y$ s1 U
(DATE=DD-MM-YY - 10-02-14 TIME=HH:MM - 11:45)
" y3 v7 H% Y4 d" R: d(MCX FILE - O1001)
1 F& e, a0 M( L! p) `. i$ ]% Q W(NC FILE - C:\USERS\JUN\DESKTOP\O1001 3.NC)
, f: N2 F. I1 z( \/ v) C! {+ X& Y(MATERIAL - ALUMINUM MM - 2024). [+ |' u# e' \% _: t+ R
( T1 | 10. FLAT ENDMILL | H1 | D1 | WEAR COMP | TOOL DIA. - 10. ). F5 u+ R; U+ K+ j3 M
( T2 | 10. DRILL | H2 )/ O0 i: y Q5 L' w
( T3 | | H3 )6 O( X: {8 g( l/ q. C( r8 {; g
G21
2 {% A; w: `: S& zG0 G17 G40 G49 G80 G90! a5 b% }/ R* r, [" V
T1 M6
" n7 G: ?* b, ~G0 G90 G54 X-109.578 Y0. S3500 M3
- i. F! K: I* ]& CG43 H1 Z20. M8 T2& Q m$ W4 m; u# R: E% G: f
Z2.
5 \) Z9 D. D; }( E$ p) WG1 Z-2. F3.6: J3 q& A2 ?2 X9 X) M. A& i$ K
G41 D1 X-99.578 F1000./ J5 a: y8 L& b* m0 [; [+ t
& b$ h! w% h8 rX99.578 Y0. I0. J-99.578# q8 ]5 A% T9 ^. F0 W
X0. Y-99.578 I-99.578 J0.3 ?8 j# H. K4 c1 R9 V9 [
8 d5 D' _/ w$ {. Z& KG1 G40 X-109.578
- R ^# l$ [1 X8 OG0 Z20.6 w4 ~- Q V) O0 C/ n
M5/ z$ \: ~+ S) ]/ P+ S9 I; I
G91 G30 Z0. M92 ^- }+ Q% q J2 @& E. B3 f
M015 ]$ j. M; \% C e# C$ D
T2 M6
% ~6 ` | X0 L6 B# c! HG0 G90 G54 X-77.951 Y-23.682 S1000 M3
7 E/ |$ Y4 M4 }: l7 i2 yG43 H2 Z20. M8 T30 W1 }$ o, o0 ~1 @
G98 G83 Z-10. R2. Q3. F200.- f6 F' F5 R: R; U! C
X-32.568 Y-28.038- N! ]6 F/ j/ J! Y
X31.813 Y-37.751
; X" K& M4 F% x* O. l; _0 F4 m7 ^# XX45.478 Y19.435
4 o1 J: m( Z: c6 Y( G3 _6 l( E9 [X-33.729 Y73.684$ F& j3 \& t4 Z& j/ z; {* J" k; r
G80 Z20.& R9 N" A* w$ P9 o7 O4 [: N
M5
3 Y" p' Z7 x- I( @G91 G30 Z0. M9
5 D1 `, A) ~. n& }' m- iM01
; k M) W+ V6 J# z2 v5 DT3 M60 I% {8 O) e0 u
G0 G90 G54 X-77.951 Y-23.682 S300 M3( j3 `0 J* n" o9 X3 o. l2 T- \3 ?
G43 H3 Z20. M8 T1
/ H0 p% i% x. K0 WG98 G84 Z-8. R2. Q3. F1., }1 l+ k* S" N
X-32.568 Y-28.038
. P6 d. X( G3 W$ WX31.813 Y-37.751
* d4 c; A. S* qX45.478 Y19.435
2 w& P* |; x/ \; L IX-33.729 Y73.684
, L4 F* Q$ H+ e8 q6 cG80 Z20.6 X) o% O! Y! }0 j! g
M51 A- @! K- k( v( ]
G91 G30 Z0. M9
' q% r) w; C3 p+ t' UG28 Y0.
( k, }& T" }$ {M306 i; U2 a) v# K* |4 h9 \
2 A+ M' [) k3 N3 D8 b o$ }7 b 这是三菱的 带刀库 带备刀 下载链接:http://pan.baidu.com/s/1dDDt1HB
* M5 L4 `& }% X 版本是x5的喔 |
