楼主 |
发表于 2014-4-13 22:05:36
来自: 中国广东肇庆
0 G5 l( D, N) H: t: N7 [, ~不是这个意思,我是在组件里点选一个零件,然后打开(暂停),然后调整好方向,然后再点恢复...................
" Q2 k- @( h8 p, Z0 M我是想在调整好方向后,在按一下某个快捷键(如 ` ),就自动恢复了,就不用鼠标点“恢复”按钮
2 `3 N! c- a0 e. p8 ]- L3 u8 l+ e; E Y- i4 X( r' b8 z5 o
D$ U; K* q, bmapkey 2+ @MAPKEY_LABEL打开元件新建绘图;\
/ B& Y9 C) e: P& X" }3 X9 Z. T& fmapkey(continued) ~ Activate `main_dlg_cur` `OpenModel`;\
7 \! ?+ k' E# n1 ^3 h, H( A' Y; f. amapkey(continued) ~ Activate `UI Message Dialog` `ok`;@MANUAL_PAUSE;%1+;$ {9 F3 U2 v( u
% T9 Q! F. w1 N# F/ A' Mmapkey 1+ @MAPKEY_LABEL新建绘图;~ Command `ProCmdViewOrient`;\1 g& e6 j+ z1 z5 o" H
mapkey(continued) ~ Activate `orient` `NmViewCheckBtn` 1;\
1 A2 ]; {" q5 \1 o" H+ mmapkey(continued) ~ Select `orient` `namedviewPH.NameVw_List` 1 `Default`;\
( k2 q& C4 M. wmapkey(continued) ~ Activate `orient` `namedviewPH.NameVw_PB_Save`;是;\
! L$ y* |+ @# k+ U* b* g+ pmapkey(continued) ~ Command `user_new_drw_cmd` ;~ FocusOut `new_drw` `InputText`;\1 k. Z. D% o* S" h
mapkey(continued) ~ Select `new_drw` `SelectType` 1 `a4_frm`;\3 ^4 {7 D# V6 ?) D! ?& u/ t, {
mapkey(continued) ~ Activate `new_drw` `Ok`;%1/;~ Command `ProCmdDwgPageSetup` ;\
7 {7 d% K2 w- {" C1 t5 v5 N- \mapkey(continued) ~ Activate `pagesetup` `ChkShowFmt` 0;~ Activate `pagesetup` `OK`;\
6 U5 X% ^, J5 k+ Dmapkey(continued) ;%.0;%.0;@PAUSE_FOR_SCREEN_PICK;\) Y) d" P( D. M
mapkey(continued) ~ Timer `UI Desktop` `UI Desktop` `popupMenuRMBTimerCB`;\
. W6 ?5 F6 ?4 d. B7 G' v9 m* jmapkey(continued) ~ Close `rmb_popup` `PopupMenu`;~ Command `ProCmdEditProperties` ;\
4 j% t m6 K# U' Y7 Xmapkey(continued) ~ Select `drawing_view` `orient_method_op` 1 `geometry_ref`;\
( ?5 t i2 n' g- e9 A( ?, kmapkey(continued) @PAUSE_FOR_SCREEN_PICK;~ Open `drawing_view` `OrientRef2`;\# J) X; h$ f* J
mapkey(continued) ~ Close `drawing_view` `OrientRef2`;\
8 s5 E5 ^5 A1 I; b8 ?mapkey(continued) ~ Select `drawing_view` `OrientRef2` 1 `Left`;@PAUSE_FOR_SCREEN_PICK;\: r, x3 _2 [3 u& V% {% V
mapkey(continued) ~ Select `drawing_view` `options_list` 1 `ViewDisp`;\
" a5 _8 J4 K9 imapkey(continued) ~ Select `drawing_view` `disp_style_rad` 1 `hidden`;\
! Y4 U) g5 y* {; ^) n* W/ Zmapkey(continued) ~ Activate `drawing_view` `psh_apply`;~ Activate `drawing_view` `psh_close`;\
# t, J, _4 _% O! }* p$ g5 q5 |mapkey(continued) ~ Select `main_dlg_cur` `DrwAssyTree` 1 `node0:view_2 92 0 -1 -1 -1`;\: v, y- ?" f$ E. V
mapkey(continued) -1`;%77;\
8 E* _/ F, n5 Qmapkey(continued) @PAUSE_FOR_SCREEN_PICK;\: L6 Q, ` i. m% c
5 W3 p; J7 k! t* wmapkey(continued) -1`;%77; |
