本帖最后由 shui2012 于 2014-9-2 11:03 编辑 0 v7 B, W. l1 o. w7 i3 ?6 l) J6 g" J
4 N1 x" k5 V' I' i0 h% S
r0 A/ d: }1 m0 S8 t( T$ i4 `; } 新版本的Camnetics Suite 2015软件套装,给 SolidWorks, Solid Edge 和 AutoDesk Inventor使用设计师们提供了更高阶的工具和功能集成。其中包含GearTeq(齿轮组生成器)、CamTrax64(凸轮生成器)和GearTrax(齿轮生成器)。- i+ a" O' E2 }% v
) T1 F! {' b" G$ q! `& E: A& y Camnetics 致力于改进传动部件的设计方式。6 A9 u$ h2 d8 u# T4 M! k& \: m
& E% g3 V) p& a; x' r9 c3 d
下载说明:& T& H. j* e$ r" D- {
扩展名为exe的是在线安装包(总是最新的)8 `# K; l- q7 _6 V; n+ @
扩展名为zip的是完整安装包$ c: O& k8 D1 n `+ s5 z. D/ F
*****SolidWorks*****# [. X5 o5 k j6 a4 [+ b1 Q
GearTeq(齿轮组生成器)
; |2 u; c. f S. S' P; I& _GearTeq 2015 for SolidWorks Setup(支持SolidWorks - 2015,2014,2013,2012,2011,2010,2009), |5 P2 h* Z, @" W6 W* P
http://www.camnetics.com/downloads/gearteq/2015/setup.exe+ P j0 ?, A8 @" X# j
http://www.camnetics.com/downloads/gearteq/2015/gearteq2015install.zip/ ]% D% S( ?- M# J
3 r" w& U* {2 c i& x8 F2 Q/ P
GearTrax(齿轮生成器)
) U" c4 Y" t/ v" s" p$ iGearTrax 2015_for SolidWorks Setup(支持SolidWorks - 2015,2014,2013,2012,2011,2010,2009)
; V5 l2 c' }! G: }0 dhttp://www.camnetics.com/downloads/geartrax/2015/setup.exe
9 Q" p9 _5 f( c: Jhttp://www.camnetics.com/downloads/geartrax/2015/geartrax2015install.zip
9 m4 ] u$ Z2 }2 @5 q
2 \0 R6 u1 a* T+ d2 E# W ~; s. aCamTrax64(凸轮生成器)
* R) q2 R! Q t8 zCamTrax64 2015 for SolidWorks Setup3(支持SolidWorks - 2015,2014,2013,2012,2011,2010,2009)$ H- |3 [6 w" l" n6 Q
http://www.camnetics.com/downloads/camtrax64sw/2015/setup.exe
# e+ ^/ X/ a. s$ rhttp://www.camnetics.com/downloads/camtrax64sw/2015/camtrax64sw2015install.zip" h9 i* z/ W8 r5 u6 n
8 v" u$ b/ _* Y% ^) l, [! I
*****Solid Edge******
2 O7 f. o3 Z! @: D: T" S0 g4 ZGearTeq(齿轮组生成器)
- E" C: b# L- AGearTeq 2015 for Solid Edge Setup(支持ST7,ST6, ST5, ST4)- q* f8 m6 u* J: q% n1 U
http://www.camnetics.com/downloads/gearteqse/2015/setup.exe1 Q( U5 K) X4 {
http://www.camnetics.com/downloads/gearteqse/2015/gearteqse2015install.zip
6 [9 B3 p! P) k1 b4 ~, ^* I, h4 S: q' l* M
GearTrax(齿轮生成器)5 Y) d: M0 U3 S3 }1 q
GearTrax 2015_for Solid Edge Setup(支持ST7,ST6, ST5, ST4)6 g& O1 ^- c! C8 h* K( g4 J
http://www.camnetics.com/downloads/geartraxse/2015/setup.exe
0 U. y$ k8 G2 N4 a r5 ?3 Yhttp://www.camnetics.com/downloads/geartraxse/2015/geartraxse2015install.zip# B: s3 a5 e$ ]0 U$ [
7 _' w9 H$ }* N3 n( w
CamTrax64(凸轮生成器)
+ U: B5 N3 x* { [; dCamTrax64 2015 for Solid Edge_Setup(支持ST7,ST6, ST5, ST4)5 C$ P% n: n, t3 F6 Z. W/ f$ w7 }
http://www.camnetics.com/downloads/camtrax64se/2015/setup.exe
5 u; s }7 m# N8 J+ M! y5 O! ihttp://www.camnetics.com/downloads/camtrax64se/2015/camtrax64se2015install.zip' g; h6 M! {/ {6 A
3 x7 d/ O' b) x* Q# F8 ?" M
*****Autodesk Inventor******
. t* \; s* }4 c6 HGearTeq(齿轮组生成器)
( y; o' L; j. c- ~ D" C2 \' z% KGearTeq 2015 for Autodesk Inventor Setup(仅支持Inventor - 2015)
2 r# ]: j; q! Zhttp://www.camnetics.com/downloads/gearteqai/2015/setup.exe
" ]8 e2 _. m6 z1 bhttp://www.camnetics.com/downloads/gearteqai/2015/gearteqai2015install.zip
, \2 b8 e& `4 e+ }; d; v( [7 i4 d
4 | s* D4 t% m+ C0 xGearTrax(齿轮生成器)
' G* b5 z3 Y: Z. ^- C9 w& s$ q6 _$ OGearTrax 2015_for Autodesk Inventor Setup(仅支持Inventor - 2015)
* |- h q( i) F( K- f* W5 [; e5 mhttp://www.camnetics.com/downloads/geartraxai/2015/setup.exe
, l3 w- O3 Q" m! j7 y6 w5 fhttp://www.camnetics.com/downloads/geartraxai/2015/geartraxai2015install.zip# I" @: V0 a8 e/ A) {! {0 ^
# l2 m9 X8 E2 H# b6 N( f2 O/ L5 F
CamTrax64(凸轮生成器)
6 m4 p' \% l: s8 X: l/ [CamTrax64 2015 for Autodesk Inventor Setup(仅支持Inventor - 2015); A* B! H$ m) [6 F4 f! E' H5 A- ^" A
http://www.camnetics.com/downloads/camtrax64ai/2015/setup.exe
7 a" j+ E* i1 Q' |) Lhttp://www.camnetics.com/downloads/camtrax64ai/2015/camtrax64ai2015install.zip
7 ~. H- f" c; [2 i, N! l |
