一般要将钣金件展开图拷过数控编程,一个个另存效率很低,不知有没有批量方法?
+ @; u7 {$ `: p% F( J; L$ G
8 P3 Z6 B4 a) R* ^5 m9 m) W0 F下面方法可另存pdf,却不能另存dxf
^: K Q) z( V0 pPrivate Sub cmdExportDxf_Click()5 @2 b7 `" c6 _/ t# p# Y( u
Dim f As File+ P- ^4 p- J1 w! X2 `; O
Dim fo As Folder; H7 g$ P; E) n/ h4 f( F! b+ x) k
Dim sName As String9 y7 m9 h" f! C' {& C( g
Dim sExNameForOut As String
3 A3 K1 M3 ~% Y1 ~ Dim sExNameForIn As String* V% K! r# g( h
8 S. G$ v/ l+ F1 j/ H% o sExNameForIn = "SLDPRT"
9 w% `; s% {7 m$ u sExNameForOut = "dxf"1 t6 \: E1 |3 g/ @# z( K
$ l- V3 I- F7 P" `, L1 E" }
Set fo = fso.GetFolder(txtDir)
# I7 V ^ H3 m! ~& |) ?9 O4 ~, C
) m# W; j8 J) {! L3 W5 b) U" ` If Not fso.FolderExists(fo) Then
4 ~, K0 p5 R0 \ MsgBox "目录不存在!"
, v6 l6 p4 U' ~6 v) j Exit Sub
5 ]! Z7 j& i; o End If: O8 \3 w) N* J6 E
3 Q, C5 `1 G) L% K+ N- i4 W$ U Dim retVal As Boolean+ g: x8 g( g0 _0 q" h
For Each f In fo.Files
; A' w9 |; ^" f/ C4 h0 t. q) k9 l' `5 [ Dim sSaveName As String
- @5 {6 ?% K* t$ {( a% F* v) M Dim longstatus As Long$ i3 Q3 j" ~- t, n
Dim longwarnings As Long
- c; K1 E1 P9 S9 H M Z3 H6 v+ R! n
If fso.GetExtensionName(f) = sExNameForIn Then5 }! v, W7 n' B/ G) [! |! ^, P5 g2 \: |; x
If Not Left(fso.GetBaseName(f), 2) = "~$" Then
" y: q- G3 q, k8 S3 ` g* g2 f6 H' Set part = swApp.ActiveDoc6 V( L& g! |" L
Set part = swApp.OpenDoc6(f, 1, 0, "", longstatus, longwarnings). g& ]- }' Z1 J' L) \4 }$ S u
If IsSheet(part) = True Then8 `+ k5 G6 Q4 c* y
sSaveName = fso.GetParentFolderName(f) & "\" & fso.GetBaseName(f) & "." & sExNameForOut
) z9 i4 t/ d' K0 ~( Z0 Q retVal = part.SaveAs3(sSaveName, 0, 0)
3 |, n0 U7 L: o5 y- r' retVal = part.SaveAs4(sSaveName, 0, 0, 0, 0)* u. @/ E" Q2 h3 l$ V
) ?! H5 M% P, J$ ^
End If
5 |. S3 [2 w/ G4 `$ r End If1 ]2 w7 H' m6 _- [( {5 Y
End If
9 C# [# b. ?+ j% w' part.Close3 K `/ X4 y2 Z2 Q3 p( s( X
swApp.CloseDoc (f)0 C+ f5 g$ ?8 Q* _) s2 o7 U0 @
Next
/ \: w" S) B7 s: {End Sub" N7 C5 u& s2 B1 T4 _0 d( u
5 e0 [( T/ ^9 y0 U. ?5 N
