4 d+ M; r; Q- H2 m' E
3 a5 n3 e/ |! g- \" \% o" m( x) k現在新版的冷卻液開/關- # --------------------------------------------------------------------------
$ n s' R& Q% Z' j; X* K - # Coolant output code selection for X style coolant' W( k* C$ U _# r$ }- [* d
- # Note: To enable X style coolant, click on the General Machine Parameters icon) q# C& c: S% [3 G+ M
- # in the Machine Definition Manager, Coolant tab, disable first check box
( h% K2 a1 g' O; ^) Q" s - # Output of X style coolant commands in this post is controlled by pcan, pcan1, & pcan2
, d4 ^' E, W7 a c" g7 c1 y - scool50 : "M8" #Coolant 1 on value# ?+ Z( k j* B* _) f! F; D
- scool51 : "M9" #Coolant 1 off value" |6 N4 Q& f% T1 k7 U
- scool52 : "M14" #Coolant 2 on value3 s! \: h% `3 j: b/ v6 e( c, u& }8 K
- scool53 : "M15" #Coolant 2 off value
6 G: D1 _# K1 k* W - scool54 : "M88" #Coolant 3 on value# u4 `' b' @; f. M# C5 S; w& R; Z
- scool55 : "M89" #Coolant 3 off value* E$ u3 H* ~( t" |, F$ u2 w
- scool56 : "M8(Coolant4=ON)" #Coolant 4 on value
- E/ l4 j% N6 R/ x/ k: F - scool57 : "M9(Coolant4=OFF)" #Coolant 4 off value
# B, n7 O: J* |/ n+ s- P - scool58 : "M8(Coolant5=ON)" #Coolant 5 on value: _ z7 D1 v) K" S# d. N7 |
- scool59 : "M9(Coolant5=OFF)" #Coolant 5 off value1 _, D9 B+ ^' o2 O- ?2 ], I
- scool60 : "M8(Coolant6=ON)" #Coolant 6 on value
: }) |/ ^+ U- q' x4 A, y7 `4 d% F1 S - scool61 : "M9(Coolant6=OFF)" #Coolant 6 off value$ E0 c! F( i* x% P; n6 v( b9 ?
- scool62 : "M8(Coolant7=ON)" #Coolant 7 on value
; G# m5 J8 I7 o2 O$ C7 V2 r - scool63 : "M9(Coolant7=OFF)" #Coolant 7 off value# ?- z6 ~ W! \# x
- scool64 : "M8(Coolant8=ON)" #Coolant 8 on value
: f) ^* C8 v9 G& w" D. l k - scool65 : "M9(Coolant8=OFF)" #Coolant 8 off value; Y6 C% Q0 O6 z8 {4 c/ O+ Z$ e6 S' p
- scool66 : "M8(Coolant9=ON)" #Coolant 9 on value9 N& c2 F4 T* ?% V
- scool67 : "M9(Coolant9=OFF)" #Coolant 9 off value
/ Q7 A8 k3 ?( Y0 @: A8 R; U9 O6 H! o - scool68 : "M8(Coolant10=ON)" #Coolant 10 on value# R, D3 c3 {- S B
- scool69 : "M9(Coolant10=OFF)" #Coolant 10 off value
- Y" Q$ q2 e+ M# R7 m - scoolantx : "" #Target string
& E2 Y" K' H0 I9 I - 7 I% M" y# N( X1 G* |; ?
- fstrsel scool50 coolantx scoolantx 20 -1, a- h; |5 r9 }! i
- # --------------------------------------------------------------------------. h2 D8 I1 N, I/ ~3 _1 L9 p5 O
- #X coolant has the option - First coolant off command shuts off ALL coolant options9 I5 @4 F$ ` N
- sall_cool_off : "M09" #Coolant off command output with all_cool_off
复制代码 我想用- scool52 : "M14" #Coolant 2 on value" a: F& z# X6 d- E6 `$ X
复制代码 來做吹氣/關氣..........
8 \2 E; W( ?0 B8 ~但是新的關油關氣通通是用m09來關
% |+ f7 ^2 U2 X8 D& h% ^: ^2 S
7 k1 f$ R3 i( q3 O. Q我怎麼讓他關器用m15關阿....要改哪裡
5 b$ A2 I& L9 N6 w6 y. F* T4 P' ~4 f) ~
呵呵....用舊版的我會弄....我問的是新版的
0 V. M+ J0 `4 Y7 R7 Y: Q# {9 J. E& d! B" s" d, D: S
有人知道怎麼改嗎?. L, T- f$ i7 `# X! G* F
3 F" \" o/ n2 S7 E; g, H |
