发表于 2014-11-29 21:12:38
来自: 中国江苏无锡
下面是用9.1版本Mpfan.pst来说明更改后处理的方法:0 N; @9 q: l$ i0 [8 m/ S( Y9 ?
1、打开Mpfan.pst后处理文件9 V2 {9 A( y: {1 x2 W2 g$ R- b" _
2、查找到下面内容:* x0 V9 Z- O. c0 |
ptap #Canned Tap Cycle7 p: X( M: ^/ o% q) T
pdrlcommonb
# l- u. l8 u! ^% a result = newfs(17, feed) # Set for tapping Feedrate format
0 T4 i& [0 h# T3 w% F3 H C. O pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
+ Y; k, O: @8 u9 ? prdrlout, *feed, strcantext, e ! H' K5 x d& F7 L
pcom_movea
$ m- N, o' i( D* j3、添加下面红色字体的内容:5 ^" b0 m7 ~+ b9 v. T" h; @
ptap #Canned Tap Cycle) y0 l8 Z: F2 [' _2 a1 `/ d
pdrlcommonb
) @% b/ L( x1 }, f" w( K result = newfs(17, feed) # Set for tapping Feedrate format
- }, \/ W7 M% e; W pcan1, pbld, n, "M29", *speed, e #如果是X以下版本 - |" Q# ~, i* f5 g$ [
pbld, n$, "M29", *speed, e$ #如果是X以上版本包括X ' Q q/ L- G* R: r
pcan1, pbld, n, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout, # L- w5 O1 u" p; N) ]
) H" u6 X2 s0 i% ^2 D7 z4 n" f pcom_movea |
