职位:试验工程师 Position: Test Engineer 部门:比例阀事业部 Department: PVG Engineering 主管:工程部主管 Manager: Engineering TeamLeader 工作地点:浙江省嘉兴市海盐工厂 Work Location: Haiyan Factory, Jiaxing,Zhejiang 摘要 SUMMARY
! o0 l1 Q$ G+ D, |& P试验工程师负责按照全球试验规范, 根据本地和全球的试验需求, 计划和执行各种试验; 判断分析试验中的被试件失效或试验台故障, 提出解决方案; 分析试验数据并提供试验结果; 协调设备维修部门制订和更新试验设备的维护保养计划; 负责现有试验设备的更新并参与新试验台的建造项目. Test Engineeris responsible for scheduling and conducting tests according to global testspecification, doing troubleshooting for test unit or test stand during testing; analyzing test data and releasing test result; coordinatingwith maintenance departmentto create and update preventive maintenance plan for test stands; being responsible forupgrading current test stand and involving in the projects of new test facilitybuilding. 职责 RESPONSIBILITIES $ R: v! O) U% ^& k5 \
· 根据全球或本地的试验需求,按照全球试验规范文件,与试验需求者协商制定试验计划, 并负责实施. · 制定试验液压回路图,明确试验步骤. 协调试验所需的被试件,外协加工件和采购件及时到位. · 按照试验流程正确操作和监控试验室设备,并负责解决试验台故障.保证试验设备和人员的安全操作和运行. · 判断和分析试验过程中出现的被试件失效或试验台故障, 并找到解决方案. · 分析试验后的零件或部件,及时将试验结果通报给试验需求者, 并提供详细的试验数据以及相关的结论. · 协调设备维修部门制订和更新试验设备的维护保养计划. 确保试验设备的高效利用. · 负责现有试验设备的更新并参与新试验台的建造项目. · According to global test specification,schedule and fulfill the test based on specific request. · Make hydraulic schematic for the test,and confirm test procedure with test requester. Make sure tested unit,fabricated and purchased components are ready for testing. · Operate test facility in according withtest process, and monitor test equipment as well. Ensure the safety of testpersonnel and test facilities. · Identify and analyze test unit failure or test sandproblem in period of test running, and find solution. · Analyze the tested parts or components,timely inform of test requester the test result, and provide detailed test dataand conclusion from test lab. · Coordinate with maintenance departmentto create and update preventive maintenance plan for test facilities in testlab. Ensure test facilities effective utilization. · Being responsible for upgrading current test standand involving in the projects of new test facility building. QUALIFICATIONS · 机械或液压工程专业大学本科及以上毕业。 · 至少3年液压行业的工作经验;有液压元件尤其是多路阀试验经验者优先。 · 掌握液压、机械、电气或电子控制等方面的知识。 · 熟悉压力、温度、速度和流量等传感器的应用,了解常用的数据测量仪器和数据采集系统;熟悉LabView和PLC者优先。 · 良好的沟通和团队合作能力。 · 良好的英语口语和写作能力。 · 熟练使用Outlook.Excel. Word. Powerpoint. · Bachelor or above degree in Mechanicalor Hydraulic Engineering. · At least 3 years working experience inhydraulic field; experience of testing hydraulic products, especially proportionaldirectional valve is preferred. · Knowledge about hydraulic, mechanicaland electric or electronic control. · Familiar with the application ofpressure, temperature, speed and flow sensors etc., know about general datameasuring instruments and data acquisition system; understand LabVIEW and PLCprogramming is plus. · Good communication skill and team work. · Good oral and written English. · Familiar with Outlook, Word, Excel andPowerpoint. Remarks 工作时间:标准工作时间 Work Hour: Standard Working Hours0 F2 y7 e1 k0 d( l
8 W& H, ?, v' A% M0 H: g) Y" b' S
有兴趣者请登录51job.com应聘 |
