楼主 |
发表于 2015-3-18 02:13:26
来自: 俄罗斯
list of fixed bugs% d& \! l( z3 q
! U" F# [/ A; G* f, I* k/ i
% l4 f' _% F/ YThis Maintenance Pack addresses the following PRs:
, R" _1 T. i8 }0 D. @--------------------------------------------------& w7 @7 _* s5 e6 g. n$ |3 N
7 d: Y& _" l5 O p: A, U6 o===API=== : i( h3 ~, X# u, ~% P
PR 1996343: 2d constraint solver in a sketch profile works differently in ST7 - : D, N, t; S0 C" ?1 ]. h. Z3 h
PR 7274554: Physical Properties data corruption after "Move to Synchronous"
& Z6 j a1 Z) Z# o$ q: KPR 8252701: Assembly Relations are lost when using "TranslateMultipleOccurrences"
4 {* w3 W P8 ]$ ?8 _PR 7306995: Density is not set when Material is synchronized' \* Y5 N% D( ?- u+ m
PR 7248181: RevisionManager.Document.SetPath, Assembly Copies cannot be changed1 r8 u. G1 g8 o& k$ w" `
' c; W( N8 t9 i) |- L===Assembly===
1 |" K* L' @) Z+ G" r5 t# H2 vPR 7247238: SE crashing when opening an assembly
7 q& \' r+ \! [' B7 OPR 7251083: Enclosure fails to create in ST7 French+ r& U( f" r' O7 Q5 X* ^/ F+ R
PR 7261344: Stored Groove Weld information not showing in Options dialog box
) J n$ L, O5 T$ \8 i6 Q8 WPR 7268784: PathXpres causes a highlight problem if a part is recomputed before" c, B- a O0 T: G4 g
PR 7279664: Interpart Copy copies old geometry after Replace Part( U- J: h. ]) Q' |0 x
PR 7284762: color changes in assembly being lost after Save% M. w8 t% y% }6 k9 a9 W
PR 7286828: after IPA edit -steering wheel move and cancel on suppress dlg undoes everything V/ \' J) N: Y6 N# h
PR 1993287: Occ prop dialog shows wrong rotation values - f* n9 I o& S. }7 X
PR 7253903: Assembly File cannot be opened. Corrupt file problem
# Z! M `* s. z; U) mPR 7254312: links do not update after save command
) t4 w( [) v) i5 oPR 7261085: Simplify assembly not working in the French version of ST70 M g: F4 _2 a* d. m
PR 7225926: Relationships fail after assembly feature hole modification6 A0 g! t5 P O7 N0 I1 e) R
PR 8255899: Assembly is not correctly updated after modifying dimensions
/ ^3 y; t D' R! X9 W/ i5 VPR 7271790: adjustable assembly not updating properly with a "reference only" subassembly.
- T' @! ^3 w( H0 a' NPR 7298481: 1/64 precision is not sticking leading to wrong results.0 T1 F" y/ r9 Q2 [( N, O3 W
PR 8250893: Reproducible Crash within Framing
" j5 U7 {1 B2 k- F5 m3 ^PR 8251764: Cannot update higher level assembly when occurrences are marked as hidden at the
2 ]( ?, z* ` s* F# y6 OPR 7310380: Select Parts Constrained To command locks-up or aborts Solid Edge0 O! \6 j& m' p7 \* F$ D
, K3 \" l& X1 W' m( F; [' L===Draft===
- W. v4 J7 q, b0 i9 M0 q! K# pPR 2247261: Parallel dimensions are abnormal4 x9 o8 Z6 H7 `9 _$ Y
PR 2249099: Dimensions move when I open dft in ST60 e$ g0 H1 N6 g% B5 H
PR 2249101: Moving one dimension cause placement change in other
8 F( w6 b. z* P9 I9 tPR 7212177: drawing view did not depict correct assembly feature in some cases6 [4 O1 q' M; t& q4 Q7 j/ `
PR 7216837: In ST6, the text "jumps" to a higher position in the callout box
% O; @; m$ e$ T3 g- {& UPR 7247679: Reference Text generated in German SE version will not displayed in English SE
5 Y' M% z. s5 a4 aPR 7261278: shading on a drawing view that was cropped larger was incorrect* r* p9 B5 C' _" w# L5 t" V+ G6 t
PR 7263310: Solid Edge ST7 - Very Poor Performance when working with old Draft File
. \/ ]# {# z% Z" ]3 }! H$ ?& wPR 7276910: Grid-Origin moves after switching sheets. Y1 B s# h+ L5 S; F4 _! ~
PR 7279255: align edge does not show alignment line
+ t- V1 W2 J# e- d2 R5 v7 ePR 7287234: Table cell changes size when opening file in ST73 t7 |! O) e2 K9 Q Z i
PR 8259652: "Filled Textboxes" are shown in white (instead of red, yellow, etc...)
. w8 R2 a: s0 B: N+ HPR 1998827: Save as pdf results in rotation of portrait drawing. ?- v9 w" f1 ^' \" T/ ]/ z" }# d
PR 2250493: abort when un-breaking views in some cases
3 K$ [9 P2 G9 l& j8 w0 ?# lPR 7245005: Error loop when placing a DV of PMI with subscript* Q0 m' ` Z0 q0 H1 {* H5 j9 `4 T
PR 7290018: Coordinate dimensions are not migrating to sync properly for revolutions
0 t/ k) y# e7 [5 q6 V3 Q# vPR 7259995: drawing view tracker incorrectly indicates model out-of-date- ^* X2 V7 Z5 }2 ]! e( J
PR 7269193: section view fails to cut parts in some cases$ V/ N& D" G/ [# W5 y3 U$ q
PR 8261329: crash while using a new configuration file for a specific draft to dxf export
1 B W7 |: S$ w9 pPR 1997742: drawing view scale in wrong format (e.g. 2:10 instead of 1:5)+ m1 x9 b+ |4 l+ ]; m W
1 }5 K' K c) Q( |* { D" @4 r1 D& N===Part/Profile/Sheet Metal=== u- U# |8 q4 X9 | M' j& c
PR 1999126: Preparing Piping Components # ~. @0 g W- U8 _* Y- L0 i
PR 7250325: Sync Chamfer Unequal Setbacks makes the model disappear# Q/ J( d+ u& _
PR 7239628: Need the bendtable dialog to support pulldown lists and cell changed events; ]6 z: Z- p0 I/ Y
PR 7239634: the PZLEx function returns 0 for the BendTableIndex argument for synch PSM model
: b/ T6 h, U( H8 n/ g* zPR 7250956: Mirror Assembly/Part Copy Flat pattern differ from original: o' F1 X7 v6 I. u6 n% ?4 R
PR 7279296: SE becomes unresponsive with endless flickering of the display( p5 t2 W0 o2 P+ H" o9 y2 O; S
PR 7274977: Problem using PCBto3D when hole table files have been edited in ST7
Q. Q% Y' U! w- q- A4 \PR 7239628: Need the bend table dialog to support pulldown lists and cell changed events* e# D" J s- Z' `- v) W7 _
PR 7247778: Open file regression from ST6$ [0 t( j2 z9 H/ h$ F1 O
PR 7247647 (Master PR): Unable to open files created in SW2015 in Solid Edge
R$ f3 U) b: aPR 7284703/7245305: Update NX Adapter to support NX10
) k, D' G' t* S3 h5 F1 TPR 7249088: Remove material does not update display
3 R8 |: a- J3 Z* J5 `: N
' a8 q+ C7 Q$ @/ V) }===Translators===6 j$ h# ~, M% `* C
PR 7198900: Scale is off on when multiple sheets are exported to AutoCAD1 t, T9 z- |; v3 ?4 y' f( o
PR 1991000: When saving to Dwg, 'Solid Edge ISO' textfont is not converted to textfont 'Aria
+ P- q6 w) U' E. {0 fPR 7231939:SePvAdp.exe hangs when multiple assemblies are exported, a4 V+ p! s: H* ?/ {0 G4 S1 z1 Q
PR 7240716: Cannot import a Catia V5 R24' S0 T# C3 L4 J/ j1 c( g% Z$ ]
PR 7274737: Import von JT
/ J9 f* K0 F1 v* o: K$ X b( v1 X$ k' `5 B& J
===Insight===3 h8 N" b* f: R/ Q. D5 u, n4 `3 Q
PR 7207681: Insight: Non-string properties deleted from files/ |9 q( Q" G$ G# k
PR 7225962: File dialog is switching between managed and unmanaged version in Insight
! |& k- O9 O5 E {- ?PR 8261192: Insight Search lists all documents twice after an upgrade to ST75 N5 ]7 x( a/ E0 l: F
$ G1 W# s @7 `* T; V$ K9 J1 D) V% a===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
. o3 ^( ?# f0 h0 T- V2 r3 rPR 7271007: SE SP Client: Edit a part in an assy and Revise, Part is checked out and Read On' J6 ?5 x# b$ a/ @. o
PR 7283302: 'Show selected item+WFcart in task description' needs to be back ported in ST7MP
" E9 x4 N/ L: O* y, r( w; ]PR 8259630: Error message " exists in the following folders:" is insufficient! O. p. J. k9 G: Q8 G8 G+ T6 F
PR 7292077: SESP crashes while creating part having number column with default value
" V) n4 h d3 @) ^! HPR 8250211: File >Save As marks the filename in blue, so that it cannot be modified9 z9 V7 l% e3 ^" S: @
PR 1996897: Error Message AnchorGUIDTransfer at ST7 SP Server Update ) A' V; e* ]& t- Z1 h
PR 7177847: Projects can be moved to InHouse via Favorites ) I3 {; F: g' O2 T
PR 7292967: Quick Workflow with Draft update send Email which is set to no sent* F) F! A9 I: g; c
PR 7193844: With Workflow Cart=No, status is not updated for documents2 @7 W3 G6 ]" ^# U+ x: C
PR 7199893: Some part are not released if part in sub-ASM is checked out: { a0 Z% y5 ~: h
PR 7234699: Right Click in Pathfinder 2 times to open up a part or assembly
$ b& k/ a+ P% T6 h# }7 KPR 7312417: when action set to revise the folder column should be read only
% Y; G6 a E/ a& @ e
1 J& U" x* J0 _; K===Solid Edge Embedded Client===+ S$ @$ ~! Y4 W/ t; F" b* c
PR 7169854: Item Name in Solid Edge CPD not synchronizing between Part and Draft file
" d' n! T6 |9 D) f/ x5 G9 v8 f' iPR 7170066: Interdependent LOV group mapped properties field is not editable for some props
# h% K) S% ~+ P# [3 jPR 7251662: Bad performance in new SEEC implementation: K. o/ i7 K3 O7 }2 \6 [
PR 7278961: CFG file is not being uploaded to TC for an assembly having no links or component
# C0 R# K0 {6 u- r- P: x) C% QPR 7278977: Draft image files such as emf, jpg, bmp etc. are not carried forward during Revise U7 p% ?2 M+ ?8 n5 U
PR 8258193: Add to TC Interactive will change the creation and modification date
7 R+ K- L; g2 M+ h8 T% \% DPR 7271453: AddToTeamcenter Interactive in French is consistently crashing
% M4 {+ X$ [9 @+ z; f m7 ]$ gPR 7272921: Opening a managed doc via the API will do 2 BOM expansions; ^; b `, i( e1 }4 ? l" _
PR 7279570: Error in UOM to non-graphic parts" `8 v% T4 ]' l X, K2 c6 T
PR 7299494: Structure editor Save as operation entering same id for part and draft generates error* E, C- r0 D( D3 K( B1 X
PR 1991572: Problem setting SEEC_ItemTypeList_SE Part and SEEC_ItemTypeList_SE Draft 6 h4 q5 R1 Z$ x( s( L" h
PR 6781873: AddToTeamcenter needs a better message for missing Meta Model properties* x; w" S' `! g$ l$ C. ?
PR 6958514: Revise is using the default NR and not the one used in the file
3 H$ H5 M" b4 s2 J/ k5 @PR 7218222: Save As of Draft w SE_Draft_ofConfiguredAsm does not preserve the relation& D% J; L& e# a
PR 7305483: Solid Edge Model file remains checked out to me while the Draft is checked in
7 R3 E: Z: ?: j, aPR 8252307: AddToTeamcenter removes the TC_Import_Time from previously imported files - q1 z6 S* ^* I) ?" s9 Y# n
PR 1993522: Revision field is blank in CPD when naming rule used
5 n0 o: m2 F8 X, R/ p- zPR 6997635: Save As on Solid Edge Draft in SEEC gives incorrect filename. ~8 u' V( _/ O7 V# M! n, }
PR 7226933: Opening a part with a part copy of direct model always prompts to update
K% W% c4 z1 K" j# v# n9 ~/ X) m+ p* K, I3 l6 k. v/ g: X
& K% O" T9 W: y7 B9 c+ J% v& Y0 o
---( J/ [$ z) j$ i7 }0 U
End
+ K! S8 {! K' E g9 [--- |
