亲爱的用户:
3 c* G; w) s+ m; S( J Solid Edge ST7 MP5现在提供下载。请所有Solid Edge ST7的用户及时更新。另外,除西门子PLM官网下载外,Solid Edge ST7 MP5也可以从QQ技术交流群(14882199)的群空间下载。 想及时、准确获取Solid Edge技术、市场信息的用户,请关注微信公众号“SolidEdge联盟”。 Sincerely, & `- g1 q6 e$ z$ M
The Solid Edge Team ============ ; g" d- ]* L+ e3 h
Release Notes:
2 @& V# p2 ?" K0 i2 J8 j, D ============ Maintenance Packs are released for CRITICAL items only. Maintenance Packs are available up to a maximum
+ K# M% h( `1 U- U1 wof 15 months following the release date of the English version. The release date for Solid Edge ST7 English was
% f% o7 R2 b \/ p08/08/14, making the Maintenance Pack cutoff date 11/08/15. ================
# e. e' n$ e) e q+ ~- ] Download Location:
/ J6 ~5 G% g+ K7 B" i ================ ST7 Maintenance Packs can be downloaded here: ==========
1 I! r" V1 I# e* t; j. x% k0 G1 u b# ? Installation:
& l, a. u$ e8 l6 I% r7 v& \" W( \ ========== There were Solid Edge Embedded Client policy file updates in MP2. It’s vitally important that you install SEEC 6 q7 `, q ^- w
Administrator, which delivers the policy files to TC_DATA. Maintenance Pack Executables (.exe files) patch existing product dlls. Maintenance Pack executables , |& n; j5 d3 n) @9 |/ m! w, e0 f
are all inclusive and can be installed on top of a base release or any released Maintenance Pack. Maintenance Pack Installs (.zip files) are complete product setups. Therefore, existing versions must be 1 @1 W% r% g I" B$ R/ C
uninstalled using Add/Remove Programs from the Control Panel prior to installing the new setup. =========================================4 l$ a- C! p8 l" |" x/ Y
This Maintenance Pack addresses the following PRs:1 E( J6 {, Q% z! \7 b
========================================= ===API===
I. t. C, c/ P. c3 Z1 sPR 1996343: 2d constraint solver in a sketch profile works differently in ST7 - 6 I$ C+ d$ w" Y+ c3 Y2 ?: ]. m; D
PR 7274554: Physical Properties data corruption after "Move to Synchronous"' P' C+ ~0 ^, Y7 [" v, g o8 y
PR 8252701: Assembly Relations are lost when using "TranslateMultipleOccurrences"6 B+ L: ^) T- l" C# E1 s- C- S
PR 7306995: Density is not set when Material is synchronized
$ d, ^, l7 Z( C9 p; tPR 7248181: RevisionManager.Document.SetPath, Assembly Copies cannot be changed ===Assembly===
J& [3 c8 p$ {, iPR 7247238: SE crashing when opening an assembly$ I8 D% j' Y; [5 a; r
PR 7251083: Enclosure fails to create in ST7 French% I$ a0 \- U/ h- N8 U4 g& L1 K; O
PR 7261344: Stored Groove Weld information not showing in Options dialog box
5 m) X/ o v$ z- Q) ~+ l7 MPR 7268784: PathXpres causes a highlight problem if a part is recomputed before
1 N- g# ~1 D$ M) ~0 C/ A/ NPR 7279664: Interpart Copy copies old geometry after Replace Part
( p. `( \/ m& P4 M) e7 L iPR 7284762: color changes in assembly being lost after Save2 }" `' O: r$ p$ f9 b4 f
PR 7286828: after IPA edit -steering wheel move and cancel on suppress dlg undoes everything3 l) `$ s8 G/ B) S" k
PR 1993287: Occ prop dialog shows wrong rotation values ) r& S; b7 H: b+ E
PR 7253903: Assembly File cannot be opened. Corrupt file problem
. k" m- |- A. v9 h% _! p4 f" P' vPR 7254312: links do not update after save command: f# U: K- a( ]) ^# ~+ B3 U
PR 7261085: Simplify assembly not working in the French version of ST7
) l7 `6 R& d A! `- FPR 7225926: Relationships fail after assembly feature hole modification
) T4 s9 I, U- L' v2 F$ }PR 8255899: Assembly is not correctly updated after modifying dimensions' {4 K9 d1 Q& c: p$ R
PR 7271790: adjustable assembly not updating properly with a "reference only" subassembly.
6 z3 r6 n, j6 f- S4 U f0 `7 pPR 7298481: 1/64 precision is not sticking leading to wrong results.7 ^4 G, {3 o* y. D
PR 8250893: Reproducible Crash within Framing, h& i; b3 u# V! M( ~
PR 8251764: Cannot update higher level assembly when occurrences are marked as hidden at the
, O' X; q1 q: F1 O: O% ]PR 7310380: Select Parts Constrained To command locks-up or aborts Solid Edge ===Draft===
% Y3 w) \1 Q% L" n6 N; sPR 2247261: Parallel dimensions are abnormal
* J: s5 F' H3 XPR 2249099: Dimensions move when I open dft in ST6( \" c2 N* ^5 v( v& H
PR 2249101: Moving one dimension cause placement change in other& ^! P# \" a; \: y' v
PR 7212177: drawing view did not depict correct assembly feature in some cases! b* y, ^. a: ^. ?
PR 7216837: In ST6, the text "jumps" to a higher position in the callout box
0 |5 ~$ Y6 \+ ^) z# f/ BPR 7247679: Reference Text generated in German SE version will not displayed in English SE
* E( G& f! U* L: N3 q: `PR 7261278: shading on a drawing view that was cropped larger was incorrect
( b. T H. d! [* U7 R/ pPR 7263310: Solid Edge ST7 - Very Poor Performance when working with old Draft File9 N5 E9 B5 D, P4 p% K0 Z
PR 7276910: Grid-Origin moves after switching sheets' X: o7 u: \) t8 t }
PR 7279255: align edge does not show alignment line
: ]3 u2 E' T Z3 K; VPR 7287234: Table cell changes size when opening file in ST72 ]( o3 L: M7 D; Q& G) _" F# X9 U
PR 8259652: "Filled Textboxes" are shown in white (instead of red, yellow, etc...)8 I& ^/ i' O- G4 @/ M3 q7 Y* Y3 Z' Z
PR 1998827: Save as pdf results in rotation of portrait drawing X g/ Q( t3 x3 g+ {
PR 2250493: abort when un-breaking views in some cases! }. S2 z7 @: N" a& s) e0 R# c/ l
PR 7245005: Error loop when placing a DV of PMI with subscript
' d) [' x8 c r- t% t$ qPR 7290018: Coordinate dimensions are not migrating to sync properly for revolutions
& d3 F- x% b, l8 `8 l; XPR 7259995: drawing view tracker incorrectly indicates model out-of-date& T% C6 i1 X; G/ _' c& e
PR 7269193: section view fails to cut parts in some cases. k; V- t$ p9 b
PR 8261329: crash while using a new configuration file for a specific draft to dxf export
5 h# s! v) Y: c* c2 |$ iPR 1997742: drawing view scale in wrong format (e.g. 2:10 instead of 1:5) ===Part/Profile/Sheet Metal===
: S# `" Y8 X% OPR 1999126: Preparing Piping Components
8 g7 }( f' L8 @# qPR 7250325: Sync Chamfer Unequal Setbacks makes the model disappear/ v, d# a7 Q1 a
PR 7239628: Need the bendtable dialog to support pulldown lists and cell changed events
) ]4 s2 R/ B; X t2 {PR 7239634: the PZLEx function returns 0 for the BendTableIndex argument for synch PSM model
- e P8 W0 {4 ]8 mPR 7250956: Mirror Assembly/Part Copy Flat pattern differ from original
( |4 @. U# t: F6 i+ K! p, {PR 7279296: SE becomes unresponsive with endless flickering of the display, a2 W+ l/ ^0 l) @1 Y8 n. Z$ i( I( H- @
PR 7274977: Problem using PCBto3D when hole table files have been edited in ST7 5 ?, _ O3 P$ I0 H) w1 b
PR 7239628: Need the bend table dialog to support pulldown lists and cell changed events8 n, _3 y' }: l( M
PR 7247778: Open file regression from ST6
) I' ^( ]# E/ R/ T" S0 u, k' yPR 7247647 (Master PR): Unable to open files created in SW2015 in Solid Edge4 F$ V/ {- k# Q( H
PR 7284703/7245305: Update NX Adapter to support NX10
( f# i! Z/ ^1 z: @9 v: n* EPR 7249088: Remove material does not update display ===Translators===
f* K0 j- [/ JPR 7198900: Scale is off on when multiple sheets are exported to AutoCAD
4 `5 ~( U- c! _+ k) I& @0 R6 PPR 1991000: When saving to Dwg, 'Solid Edge ISO' textfont is not converted to textfont 'Aria
7 e2 D2 E9 o; ^3 R" aPR 7231939:SePvAdp.exe hangs when multiple assemblies are exported3 C( R/ p% H# @5 S. h) m
PR 7240716: Cannot import a Catia V5 R24; m! I( D! q! K1 K/ t
PR 7274737: Import von JT ===Insight===
- @7 `9 k3 {: ~* ^0 c9 z/ R7 t7 CPR 7207681: Insight: Non-string properties deleted from files
, Y$ d" r4 r& G) V9 t. d8 s: XPR 7225962: File dialog is switching between managed and unmanaged version in Insight
3 K+ A/ C) c% X' y' ePR 8261192: Insight Search lists all documents twice after an upgrade to ST7 ===Solid Edge SP, Server, Standalone Client, Solid Edge Client===# v$ |2 d# ]' }( [
PR 7271007: SE SP Client: Edit a part in an assy and Revise, Part is checked out and Read On
% z3 k0 }2 a/ ?2 K3 o' E& ePR 7283302: 'Show selected item+WFcart in task description' needs to be back ported in ST7MP
" F& p& Z9 D9 a0 \. J* sPR 8259630: Error message " exists in the following folders:" is insufficient) A* @: f$ t- R: S8 o! A3 ^+ H
PR 7292077: SESP crashes while creating part having number column with default value! {! _% V' e! L V8 l. ^
PR 8250211: File >Save As marks the filename in blue, so that it cannot be modified# C! V1 L, I' e. u* b, M2 o) }
PR 1996897: Error Message AnchorGUIDTransfer at ST7 SP Server Update 7 Z: T1 |" r% s; Q0 G
PR 7177847: Projects can be moved to InHouse via Favorites ; i8 |& K5 X4 z6 \
PR 7292967: Quick Workflow with Draft update send Email which is set to no sent
* y- o8 d# J8 g$ b) F& o+ ~PR 7193844: With Workflow Cart=No, status is not updated for documents
' P r6 @0 f5 F7 ~- ]# _% U: mPR 7199893: Some part are not released if part in sub-ASM is checked out- r* ]1 q1 a" T6 O: m
PR 7234699: Right Click in Pathfinder 2 times to open up a part or assembly
7 t/ W1 o3 w4 l' b+ ^' l4 c/ d9 uPR 7312417: when action set to revise the folder column should be read only ===Solid Edge Embedded Client===' h% f* e* |: I
PR 7169854: Item Name in Solid Edge CPD not synchronizing between Part and Draft file% l8 Q* O: `" Z4 M( D' B) l3 j
PR 7170066: Interdependent LOV group mapped properties field is not editable for some props
# M3 s% Z3 R2 yPR 7251662: Bad performance in new SEEC implementation# ~! X0 ~! `! o0 \7 P
PR 7278961: CFG file is not being uploaded to TC for an assembly having no links or component* U1 O* l. m/ c5 Z y8 G
PR 7278977: Draft image files such as emf, jpg, bmp etc. are not carried forward during Revise: ~$ d6 e) n; J, M0 b
PR 8258193: Add to TC Interactive will change the creation and modification date
; W$ ^+ A+ _+ D! ]$ @8 i: RPR 7271453: AddToTeamcenter Interactive in French is consistently crashing
* N% W9 N- W$ p! b' b& Y& i+ c8 TPR 7272921: Opening a managed doc via the API will do 2 BOM expansions+ d# T5 w1 Q' U6 ]) y
PR 7279570: Error in UOM to non-graphic parts
8 p0 t1 p9 P! M/ X, l$ B& z+ ?. iPR 7299494: Structure editor Save as operation entering same id for part and draft generates error. P! g1 `1 L2 {9 S
PR 1991572: Problem setting SEEC_ItemTypeList_SE Part and SEEC_ItemTypeList_SE Draft
' D6 ~ W' J& Q- q# gPR 6781873: AddToTeamcenter needs a better message for missing Meta Model properties
# l2 W& G$ U, [; ~: nPR 6958514: Revise is using the default NR and not the one used in the file1 B, _6 A$ |5 V
PR 7218222: Save As of Draft w SE_Draft_ofConfiguredAsm does not preserve the relation+ p* N+ N5 Z. k3 c
PR 7305483: Solid Edge Model file remains checked out to me while the Draft is checked in% g4 ~/ k6 ?4 J7 w
PR 8252307: AddToTeamcenter removes the TC_Import_Time from previously imported files
+ a) x. t. C4 dPR 1993522: Revision field is blank in CPD when naming rule used$ w* w$ B0 Y' \( M, y
PR 6997635: Save As on Solid Edge Draft in SEEC gives incorrect filename
# B0 s. c" I1 X) KPR 7226933: Opening a part with a part copy of direct model always prompts to update
7 X4 ^: l8 d# d# p* Q0 q" B: x7 k# T6 @& l) [
n9 O+ z8 x& e9 Q) K g
http://www.3dportal.cn/discuz/source/plugin/sina_xweibo_x3/xwb/images/bgimg/icon_logo.png 该贴已经同步到 goto3d的微博 |
