6天前
2021-06-25
查看: 2803|回复: 3
[分享] PTC Creo 和 Pro/ENGINEER 产品之间的对应关系
发表于 2015-4-26 19:07:56 | 显示全部楼层 |阅读模式 来自: 中国台湾
+ u$ [: s/ u% I, S: H* j7 C/ _# z% Y- H) E
Pro/ENGINEER
PTC Creo Parametric
模块
Pro/ENGINEER Advanced Assembly ExtensionPTC Creo Advanced Assembly Extension
Pro/ENGINEER Advanced MechanicaPTC Creo Advanced Simulation Extension/ A; Z( D8 L5 F. v
Pro/ENGINEER Advanced RenderingPTC Creo Advanced Rendering Extension: k6 U: ]7 `" A9 I7 U1 G
Pro/ENGINEER Behavioral Modeling Extension% q, q5 {  b5 p3 C8 Q
PTC Creo Behavioral Modeling Extension$ c& `+ i! \* f+ W6 b
Pro/ENGINEER Complete Machining! y5 Y! A3 r5 `* E' Q  D; D
PTC Creo Complete Machining Extension
! X. N6 }! K3 h% p0 v/ D; @
Pro/ENGINEER Complete Mold Design- V/ b: s' |" J! {; R, r
PTC Creo Complete Mold Design Extension9 E; [& f: X, Z, C$ S
Pro/ENGINEER Computer-Aided Verification
1 H) ]8 S, k% L/ e2 T+ p. t  l1 E
PTC Creo Computer-Aided Verification Extension
Pro/ENGINEER Distributed Pro/BATCH- s( A7 n) y$ I
PTC Creo Distributed Computing Extension
Pro/ENGINEER ECAD-MCAD Collaboration ExtensionPTC Creo ECAD-MCAD Collaboration Extension
Pro/ENGINEER Expert Framework ExtensionPTC Creo Advanced Framework Extension
Pro/ENGINEER Expert Moldbase ExtensionPTC Creo Expert Moldbase Extension
Pro/ENGINEER Fatigue Advisor3 k/ {* U0 A  G+ T9 \
PTC Creo Fatigue Advisor Extension
Pro/ENGINEER Interactive Surface Design ExtensionPTC Creo Interactive Surface Design Extension
Pro/ENGINEER Manikin Analysis Extension
6 E3 E% n4 K' k0 W& A
PTC Creo Manikin Analysis Extension
Pro/ENGINEER Manikin ExtensionPTC Creo Manikin Extension
Pro/ENGINEER Mechanica4 a# H6 k! C% k" x2 D
PTC Creo Simulate
Pro/ENGINEER Mechanism DynamicsPTC Creo Mechanism Dynamics Extension
Pro/ENGINEER NC SheetmetalPTC Creo NC Sheetmetal Extension
Pro/ENGINEER Piping and Cabling ExtensionPTC Creo Piping and Cabling Extension
Pro/ENGINEER Prismatic and Multi-Surface MillingPTC Creo Prismatic and Multi-Surface Milling Extension
Pro/ENGINEER Progressive DiePTC Creo Progressive Die Extension
Pro/ENGINEER Reverse EngineeringPTC Creo Reverse Engineering Extension
Pro/ENGINEER Routed Systems DesignerPTC Creo Schematics
Pro/ENGINEER Spark Analysis ExtensionPTC Creo Spark Analysis Extension
Pro/ENGINEER Tolerance Analysis ExtensionPTC Creo Tolerance Analysis Extension
Pro/ENGINEER Tool DesignPTC Creo Tool Design Extension
Pro/TOOLKIT 自定义 APIPTC Creo Toolkit
Pro/ENGINEER Interface for CATIA II with ATBPTC Creo Interface CATIA V4
Pro/ENGINEER Interface for CATIA V5 with ATBPTC Creo Interface CATIA V5
Pro/ENGINEER Interface for JTPTC Creo Interface for JT
Pro/ENGINEER Interface for Unigraphics with ATBPTC Creo Interface for NX
4 o+ [: O6 _; m9 i
PS : 論壇不知Pro/Engineer已全面改為 PTC Creo,所以請不要再刪除相關之PTC Core帖子了,不然就太無知了,要刪也應給個道理。
 楼主| 发表于 2015-4-26 20:45:18 | 显示全部楼层 来自: 中国台湾
寂静天花板 发表于 2015-4-26 20:15 static/image/common/back.gif
, L  b; I5 G2 o  r2 A+ s, O5 y你竟然说论坛不知道,你当这里的版主,技术员,管理员,都傻啊。
6 q' P2 e5 E" q6 M0 v
是啊!不然為何刪除個人的PTC Core 帖子,上船前都多以搜尋過(我有此好習慣),除非論壇說清楚為何?
发表于 2015-4-26 20:51:51 | 显示全部楼层 来自: 中国江苏南京
变化够大了
发表于 2015-4-27 07:25:01 | 显示全部楼层 来自: 中国江苏
creo是潮流: k. O; L; {. a2 Q
