查看: 4776|回复: 15
[分享] Solid Edge ST7 MP7 Update only (by SSQ)
发表于 2015-5-19 00:37:52 | 显示全部楼层 |阅读模式 来自: 俄罗斯
To install this update you need Solid Edge ST7 to be preinstalled!) j, l4 g. n( T9 T$ I; u
, ~1 ^' k/ _: F+ K/ s; A See ..\_SolidSQUAD_\readme.txt for more info..+ y$ j& t. U$ D# m
' t+ t2 [) b3 `5 X torrent file..
SE_ST7_MP07_Update_SSQ.rar
13.24 KB, 下载次数: 116
 楼主| 发表于 2015-5-19 00:38:42 | 显示全部楼层 来自: 俄罗斯
List of fixed PR's$ |5 F+ p9 s, I( {
4 O7 C0 j5 B, T; d9 [
4 w* ?( _1 E  I5 @' i! \& ?--------------------------------------------------/ q+ I( H6 V: S& U$ N9 K2 K
This Maintenance Pack addresses the following PRs:+ m- K6 v9 K, A6 g9 I$ y6 s
--------------------------------------------------6 g. O* n! X7 s: C
4 l' u2 j) O9 q  J7 o6 J5 e8 k1 Z
===API=== # ^' n3 c( u  g9 E4 K
" A! l2 @5 P0 `/ ^) H
PR 1128909: SegmentPointRelation3d.GetElement method fails on connection to other assembly, h, b9 \" Z* R. L+ P
PR 7326618: API Interpart references are broken% X$ d, O( L3 L: Y1 Y1 Q0 L
7 ?4 @" g8 E1 {5 l3 b! j4 A===Assembly=== ; j: W0 e7 C8 f1 A/ q
* }" U9 s: I- f" o
PR 1997310: thread feature fails in standard part screws- K$ t/ N* }5 P6 C
PR 7238389: Changes in Variable Table has no effect on other depending variable ' ]; f8 m$ j' k6 `" @" Q. n1 y; C
PR 7288288: Handle points of frames moved after Update all links done8 A7 A, x3 I/ v' t  i
PR 7329238: Files opening with Read Only status when they are available) Z4 \0 _" n6 e* O( L
PR 7340152: Relation fails in assembly/ x7 O0 e! \: g# V' d
PR 7340513: Crash when editing a multiple profile assembly feature
6 t# x; O9 h( C; OPR 7347154: not getting immediate feedback indicating that relationships have failed when IPA" `! u: T- O- }( f
PR 7351598: missing assembly features when opening from Draft9 e, w( m8 w$ d5 A2 N
PR 7360551: Subassemblies being empty when any instances are not tagged "display in higher level"0 t( T6 b$ R0 R. k3 E  q8 A
PR 7339408: Cannot download the document message in open file dialog8 X8 J5 W0 x9 K0 Q/ X, |: }" @; v5 Q
PR 7345683: File units change for legacy files in ST7
( w5 a. l  S6 M6 M3 e1 oPR 7286029: The values are overridden and updated in the SE options# V. p) S, S: Q8 c+ f2 n
PR 7343765: Missing properties on a Family of Assemblies - Please repair file
& u0 C3 b/ w. a  U) }8 i2 x7 x# PPR 8266361: System error encountered during evaluate while editing 3D sketch
  W7 ?: T% E9 a+ O7 O/ VPR 7283939: decimal places in assembly physical properties mass moment of inertia is locked0 c& q0 J- \( a# |
PR 7329334: Alternate Assembly previews not being correct
; w. u# q! p; S! v: h' a6 W9 O; IPR 7362568: not being able to edit a failed connect relationship& ?5 d8 g5 O; }. I; k4 F& t
PR 7249140: Parts disappear from the display! G8 r2 J. L) y4 T# K, R& V* a5 g
6 ]& T- g8 B  t! |===Draft=== - }2 t, b$ U  `1 B
# f$ N# _1 u# a+ y  l
PR 7328318: Property Text "Last printed date" will not be updated - wrong date on printout
( `+ p$ _" A/ t+ z, R9 n" B0 }PR 7234234: vertex edges were incorrectly suppressed in a section view of an assembly
- y; q' y: T( W% D6 l0 [; x. yPR 7235932: 3d connection device leaves fence select artifact
' z" b3 E; ?/ j; u2 p! }, @8 @5 LPR 7335228: Opening a DFT file crashes Solid Edge7 N. |) c; r9 ~, A
PR 7337320: Block in Drawing View will not be exported
" L8 [' d+ d' i  J2 A5 APR 7342543: Incorrect section view display
/ T2 ~8 t8 f* g( h/ p' G- {+ SPR 7353124: Wrong dimensions in a Draft, when broken out section view exists$ a/ j  S6 B/ f' w& ?
PR 8253818: Material Table > customer properties cannot be retrieved e.g. in Draft
) H; U" t  M: D6 Z7 Z' SPR 7304635: Shaded draft view colors inconsistent
+ H! Z$ q. o( l$ m7 RPR 7360547: Repeatable ST7 crash in Draw In View
9 ?) t# {- _3 B! u% p- [" W
- V+ b5 ]. A3 T0 Y===Part/Profile/Sheet Metal=== , J6 R7 c$ J. R9 g3 X+ z
: m( k; l; s  n0 ]PR 7339408: Cannot download the document message in open file dialog- ^! C  V2 {6 t! L1 N2 a7 d
PR 7345683: File units change for legacy files in ST75 ]- ^+ R# x5 `% y5 w  V, ^4 ~( L
PR 1996278: Unable to access edgebar features via API5 Q4 C, m+ H1 [' c5 E+ u5 p
PR 7295029: Deleting a hole profile locks Solid Edge if relationship colors are turned on * R, w( v8 t2 \" O& L6 [
PR 7325679: Creating a 3D sketch, Solid Edge will crash
- q4 k* P. p, Q! A. `7 LPR 7340095: SE crashes due to NULL pointer access2 I7 r* d" c% ?# O- L# D) K
PR 7340385: Solid Edge crashes if a feature has the same name as the solid body: h4 M8 N/ E: `" o" }
PR 7356608: Dimension Type Feature Callout slows down the graphics performance* G" {/ k( W/ F; K8 ]
PR 7357175: Hole feature changes geometry after editing the hole, that came via hole recognition
8 d+ y+ L" K" ~7 K4 B0 XPR 7175521: Part dimensions change after doing a save-as
, O* K7 l6 F% V: m& \PR 7298290: Unable to repair web network0 L% R; W# @3 G) {/ H  V1 W( `' g
PR 7309165: Profile side changes direction when editing variables% t3 K# _3 y$ H
+ |; F) R  r4 Y$ `4 N0 D3 p8 k
===Translators===
- {4 J% [7 |" U; \3 }7 m
: ^. ?: o" R( iPR 1991712: JT with long PMI causes crash
/ E/ }3 @: T( M+ K3 Y5 pPR 7234372: Problems to import SAT files to ST7MP2, regression against ST6
) C9 L6 y) H. e9 ~  KPR 7294318: Document name Formula will not be taken in 3d PDF# a8 R- N2 X% A* q: Z% t0 A
PR 7351253: Solid Edge Viewer keeps psm files within an assembly opened for several minutes0 b. O* \% D% C. _8 n: b% q
PR 7355757: Save as jt not possible - Insufficient error message
1 C( e8 I4 V1 @5 r2 J
: _) @3 [. `! w" w' L7 U' f===Solid Edge SP, Server, Standalone Client, Solid Edge Client===1 S4 [& z5 ^$ e+ J1 i6 i6 G; Y
% z/ b2 h4 e* z  i8 F. `8 yPR 1997720: Cannot sync exposed SE dimension variables to SESP numeric columns 2 G3 F  B3 L3 s* G7 I1 @# z
PR 7172511: Pathfinder do not get update with the assigned numbers for drag n drop assembly
7 W3 }* i9 Y) n  J! A' m7 GPR 7221411: BrokenLinkLog.xml does not include Alternates when running from cmd line
. Q% `* d) s: m1 v2 n% v! SPR 7322191: Sync property values across part structure
) ~3 P% [$ J. x7 g8 u) H5 G" FPR 7340397: Where Used on sub-part, Revision.Title values not populated. s2 U( \6 C1 \7 w5 t
PR 8265581: Content Browser shows only Favorite and Site Name - expand not available
. z; B+ j3 P! J1 k; u8 }$ jPR 6974655: Numbering used to generate SE Standard Parts is incorrect
: I( j% F. j! T, W1 u2 iPR 7332477: Shen the browse folder is accessed from WC or EC there is bad performance
* f" W. {  ]# R- fPR 7346513: Doesn't handle the Title (German Title) column as required ; r4 t; a9 K/ `6 H0 I6 Z+ y; p
PR 7346893: Workflow Action "Update Drawings" creates unnecessary tasks
1 j( F; B) s1 T- j$ M9 L$ L  U9 }# W* Q/ I/ e) z
===Solid Edge Embedded Client===
7 h! }5 Y5 c4 J' @( ~
4 L: D- F: ~& o( k* k  _6 cPR 7283519: ASM occurrence property, Item Number are not being maintained from the TC BOM0 l, s9 h- `# M3 i
PR 1993522: Revision field is blank in CPD when naming rule used% a4 x( ~8 U8 T5 V0 O' o
PR 7186212: Doing SaveAs of a NX driven reference assembly gives a Tc rules error( ]  p, l  W/ e6 K
PR 7244837: Mandatory attribute in Teamcenter won't appear in "Add to Teamcenter" in SE4 N4 S2 ?4 s' v. [2 L# F3 |
PR 7324478: SaveAs copies ItemRevision name from source to new object in 10.1.3) H+ w' H$ J( b5 ?5 ^6 B% M
PR 7355261: Solid Edge Structure Editor not displaying the correct items
( \* R0 {; G1 M2 A; wPR 7355760: Revise generates Partial Error
0 |. s3 y( V* q+ ?; w6 IPR 7357577: create draft from model results in empty CPD
/ j3 i% c6 s( PPR 7370456: Save as from managed draft does not properly do link fix up to new assembly2 m2 l: T# h9 p+ h) o+ d+ \$ |# T/ x
PR 7287253: Takes a very long time to open assembly files in SE Structure Editor
8 ~! n# o+ U% F7 h5 u
: B/ O9 N- D' k2 F---, H3 W5 x8 f" q
End $ u5 x) q7 m1 P6 a8 u9 {7 `& c
---1 \$ s% Q! o: F# m1 \
发表于 2015-5-19 07:03:33 | 显示全部楼层 来自: 中国天津
多谢soliduser老大分享!
发表于 2015-5-19 08:21:41 | 显示全部楼层 来自: 中国广东梅州
多谢老大分享!
发表于 2015-5-19 08:42:00 | 显示全部楼层 来自: 中国江苏苏州
Thank you very much ,soliduser !
发表于 2015-5-19 09:12:29 | 显示全部楼层 来自: 中国河南安阳
谢谢提供,辛苦了,
发表于 2015-5-19 09:29:45 | 显示全部楼层 来自: 中国广东广州
solid_user 发表于 2015-5-19 00:38 static/image/common/back.gif
& p+ k7 ~; ~  U8 d9 SList of fixed PR's
8 r4 {) ^# Z# E* k. Y1 d
多谢老大分享!
发表于 2015-5-19 15:49:50 | 显示全部楼层 来自: 中国河北沧州
谢谢分享 还是打不开solidworks 2015的文件
发表于 2015-5-19 21:22:49 | 显示全部楼层 来自: 中国四川德阳
谢谢分享。
发表于 2015-5-20 08:55:33 | 显示全部楼层 来自: 中国吉林辽源
非常感谢!楼主辛苦了.
发表于 2015-5-20 13:31:22 | 显示全部楼层 来自: 中国浙江宁波
谢谢提供Thank you very much
发表于 2015-5-20 16:19:47 | 显示全部楼层 来自: 中国广东深圳
谢谢分享!
发表于 2015-5-24 20:06:43 | 显示全部楼层 来自: 中国四川绵阳
发表于 2015-5-27 22:51:30 | 显示全部楼层 来自: 中国浙江嘉兴
谢谢分享。
发表于 2015-5-28 16:46:44 | 显示全部楼层 来自: 中国台湾
升级以后经常性的不显示部件。激活有问题,需要进入编辑模式再退出才有显示。
发表于 2015-6-7 17:07:14 | 显示全部楼层 来自: 中国上海
老大是不是SIMENS的人啊?,不管如何老大是我等获得SE最新版本的最佳人选,感谢!
