查看: 1576|回复: 0
[求助] 选择对象做往复运动,不知道问题出在哪?附源代码和注释
发表于 2015-6-16 17:34:23 | 显示全部楼层 |阅读模式 来自: 中国广东东莞
程序目的:  模拟运动(选择物件,使其做往复运动)0 X) D. U2 z+ a! {
9 _/ e3 c6 @# n- e现有程序问题:只能移动到一边,无法回去(无往复运动)
8 a# n3 S6 e2 Q: ^  a8 W6 K- Z4 T9 ]5 @) w2 U
源代码和注释:
  1. : X  q% `8 U8 D' A
  2. Sub Objectmove()9 Z5 R; B. L2 `4 u1 d  @. P
  3. Dim p0 As Variant '起点坐标
    3 v" i$ s* n+ m% o5 N; K; `$ I
  4. Dim p1 As Variant '终点坐标- J- ?# I7 }" j) W+ G( Y
  5. Dim pc As Variant '移动时起点坐标' P# j/ f  F& C9 d
  6. Dim pe As Variant '移动时终点坐标8 @; o7 d% z: X* S) s
  7. Dim movx As Variant 'x轴增量
    8 r+ K6 G# Q: y. Z* _
  8. Dim movy As Variant 'y轴增量
    0 L$ u* C; B8 F6 M
  9. Dim getobj As Object '移动对象5 S2 o: f" L" T* o4 H" T
  10. Dim movtimes As Integer '移动次数
    4 k, q! ~2 T: W
  11. ThisDrawing.Utility.GetEntity getobj, po, "请选择移动对象"
    # y/ G2 D2 ]$ ^* y+ Q" v# R4 E: @0 q
  12. p0 = ThisDrawing.Utility.GetPoint(, "起点:")
    + P" p5 N/ P8 m7 X+ [7 e
  13. p1 = ThisDrawing.Utility.GetPoint(p0, "终点:")  s" W: M7 ^6 P. L
  14. pe = p0
    3 V  O1 l( x% h! A6 x. U
  15. pc = p0
    6 R& _4 g! t" U+ v$ `9 \4 S
  16. motimes = 3000
    8 \7 t8 K- s% h+ K
  17. movx = (p1(0) - p0(0)) / motimes; U% x: S' u( P+ ~7 M  s" c# i
  18. movy = (p1(1) - p0(1)) / motimes# ^. L1 I( `1 \3 z2 }3 h
  19. For i = 1 To motimes
    5 `  Y* M  V# K8 B* f+ N$ J
  20. pe(0) = pc(0) + movx
    4 c! ^: j0 M- s; y9 F1 j$ e/ g
  21. pe(1) = pc(1) + movy" x6 z6 r/ g. X. f9 y, y. {# T( X
  22. getobj.Move pc, pe '移动一段7 X1 @) o; H) X! H" Q; m# U
  23. getobj.Update '更新对象: y, p+ q* {) c+ ^* d7 {9 D; p
  24. movx = (p0(0) - p1(0)) / motimes
    0 B: x. W" A& u' b7 Q
  25. movy = (p0(1) - p1(1)) / motimes
    % n; _& `: s8 A( x4 {( v
  26. For j = motimes To 1
    3 Y1 k6 I$ e/ h$ |# F3 V. M0 x4 W
  27. pe(0) = pc(0) + movx
    " J7 U; ^2 z( b/ e' |0 A$ {
  28. pe(1) = pc(1) + movy2 q! V% V1 T: w* [$ o2 e' P' d
  29. getobj.Move pc, pe '移动一段! Q& x7 P0 ~* c! d
  30. getobj.Update '更新对象
    7 N" l2 _+ @1 a, N: X! a0 T6 W
  31. Next j
    : G6 [0 ^6 F2 X9 O( z+ D
  32. Next i/ k/ K0 E, m8 S# d" d
  33. End Sub7 N& M5 U: d+ `4 n
复制代码
另:是否我的声明有问题,选择对象是只能单选?
; s" ~" j/ [9 U6 w3 q$ n7 Q2 {# ]) i0 B1 t
哪位大哥帮忙看下,再此谢过!
! X; B; v6 b8 X2 ~1 q& I2 @3 e# g! y; t; X
3 b! R! D" T; w) A1 R* J
5 Z: k( B! j8 b: ?$ }/ z1 u; X' K" F3 ?+ D6 H
