6天前
查看: 4731|回复: 13
[分享] Solid Edge ST7 MP08 Update (by SSQ)
发表于 2015-6-24 01:47:25 | 显示全部楼层 |阅读模式 来自: 俄罗斯
It's update only!
; G( E) a1 g% K0 v/ z! \- D) { To install it you need Solid Edge ST7 to be pteinstalled6 w3 [- A) d' Z. y& ?
3 F; _+ e/ y2 K+ m, I
see ..\_SolidSQUAD_\readme.txt for more info
' a) y% S- }/ [& g$ [) Q4 D
' j5 C, W6 E! i9 M( qtorrent file..
SE_ST7_MP08_Update_SSQ.rar
14.1 KB, 下载次数: 149
 楼主| 发表于 2015-6-24 01:48:07 | 显示全部楼层 来自: 俄罗斯
list of fixed PR's
  b4 u; a) u- c. I: _, H! l) U4 |) T9 E* E
& R+ U& k- N! S' l  YThis Maintenance Pack addresses the following PRs:. A& E, j0 x0 _( P% M0 @
7 B4 `8 L' g* c: O
* v; K3 e& Y7 U) B% R===API===
, V" @6 S$ a/ ]9 G- p' O5 `* X/ s' y' _+ h; |" H& N
PR 7368046: YouTube states it will no longer support older YouTube apps
3 P7 P4 n/ a2 k: H0 P0 z/ b' z9 N. |% H3 q5 t8 k, z: W
===Assembly=== + J* @  O/ F8 u4 A+ F5 o
4 A$ m; U% k# J# E' w% `( JPR 7382055: Failed relations in replace part with copy3 q( k2 b0 T. X. Q; _+ p
PR 7377429: Dimension on Sync cylindrical face not shown if an assembly feature modifies part
4 q) ]8 F7 H  Y4 gPR 8266419: Path edits does not cause Frame feature to update
" d+ Z1 o9 Q/ _PR 7382761: Performance issue opening an assembly file
: e) V3 E4 j7 E! D3 e5 R" w+ JPR 7400876: Animation editor does not work
( y. |0 q" ]/ |/ S( j  G1 f) j! {. E5 v4 `' T" [
===Draft===
% F5 ?, I( z- |6 d1 D1 L" s
! c2 E$ ~/ h0 K+ e) y9 ]PR 7316543: Wrong result when copy-paste table in draft.
! D' {5 @4 O2 v: Z* L+ b5 u, ]5 ]PR 7332149: Callout doesn't handle Chinese + Cyrillic chars from DraftCallout.txt correctly
+ f' r3 X3 P% A$ [+ H3 m  a$ FPR 7384367: Parenthesis indicating reference dim are interfering with dual dimension bracket* X0 j  ?' I* @1 n
PR 7396466: Draft - Copy/paste and attempted parts list placement crashed# U  n! u+ n: U& T, K8 \1 ]2 i: }
PR 7395989: Incorrect dimension scale on Import of DXF files
: _9 A' D% r' w: EPR 8505242: Dimension changes when opening this drawing file in SE ST75 _+ Y$ T# l3 u+ L! j; G  ?' r" E
5 l* [) d1 \% g4 Y===Part/Profile/Sheet Metal=== * B3 Q- b8 j! v8 h) b
9 g6 x! h% k7 O5 \PR 7387755: Solid Edge crashes after clicking cancel on warning dialog
- }# ]* W  J0 n# |' XPR 7399116: Hole feature problem since ST7MP7' x2 p5 q6 H- b. A. K
PR 7280647: Smart dimension value differs from curve length about 0.5 mm% e4 k" b& d5 J, C* J) B( ~3 u
PR 7405986: Solid Edge closes with 'System is Low on Memory' error
+ W! N( q- q0 L* m% C
0 [# P8 j5 w! k3 x" {' h% V# G===Translators===) X6 C  U+ G% O" G4 u/ j9 {* Q- }% K
8 f9 e7 C, _' Q0 S6 l
PR 1991413: SolidEdgeTranslationServices.exe cannot run multithreaded
2 u4 I7 g# h- V' a' ^& t# @8 Q7 t$ B8 V% m( p: [+ e& B/ Z7 Z
===Insight===
! E! H# T5 V$ p% I1 y$ V# r) i
: S" y8 _( P, `0 ?/ K3 yPR 7373760: Slow key-in in Property Manager- Insight actions during edit
. @' Y  A' k% q0 r  nPR 7378436: Search Dialog "Results per page:" row is misaligned
; p0 H0 j1 t; N3 l8 Z+ TPR 2249492: Property Manager errors when changing properties of parts
5 Z4 a* K: I% NPR 7396003: Insight Free Text search returns only one file for same filename in diff folders3 a' d' B, N$ O! r! O/ t
( {! J" y" ^, P0 n1 g6 I) m===Solid Edge SP, Server, Standalone Client, Solid Edge Client===/ F2 g$ y; [5 h8 E
% D( g! v* ~- x) y1 O
PR 7390126: Error during upload to SESP when unmanaged parts are inserted in a managed assembly
  L3 o% T6 N3 {PR 7370133: Workflow with option "beliebig" (any) doesn't work on a German SESP Server0 F$ p" k, n5 m6 c( [! |
PR 7402064: DP - Modify Tool does not create tmp file for tif files (any image file)- P' Y! J6 X+ `& A$ E8 ^: x! A
+ o: ?# |" o. m# k/ h, C
===Solid Edge Embedded Client===& d0 S* F. Z. W0 P0 k" p
. [  f8 ^9 W  {% M+ c% e" ]0 JPR 7371603: Dimensions values are rounded down with SEEC in French version
# u' C3 j6 Y7 F; XPR 8505291: Solid Edge check out SEEC license when SEEC is turn off# c* r+ m( k! n) B2 D
PR 8270039: Variables values are rounded down on FOP with SEEC in French version& p0 P5 M9 }/ b9 v
PR 7402020: When do not specify a variant the assembly will be blank after it is open  p# M% l" \2 C3 z/ Y& x% h
PR 8270157: SEEC - sub-classed item type missing forms: p3 T" W% L8 z8 [% r4 n
PR 7408247: Change Ownership on SE Assembly doesn't change attached Form
' l$ S- D0 H2 |2 t: p: Q) WPR 8271312: Material property sync causes doubled Edge.exe process  q& L  r8 h. n3 W& c! |9 ^$ j/ {+ C
5 ~2 ?& @) b+ [7 f& V6 m---( L: O/ r& s, n( P9 M
End
8 A! {: ]$ v0 T& _( k: D( Y% v---
发表于 2015-6-24 07:17:44 | 显示全部楼层 来自: 中国四川成都
多谢soliduser老大分享
发表于 2015-6-24 09:15:26 | 显示全部楼层 来自: 中国江苏苏州
Thank you very much ,soliduser !
发表于 2015-6-24 11:14:11 | 显示全部楼层 来自: 中国四川德阳
谢谢老大的分享。
发表于 2015-6-24 12:27:51 | 显示全部楼层 来自: 中国广东梅州
谢谢老大的分享!!!!!!
发表于 2015-6-24 14:04:59 | 显示全部楼层 来自: 中国上海
谢谢分享!
发表于 2015-6-24 14:55:39 | 显示全部楼层 来自: 中国重庆
必须感谢啊
发表于 2015-6-24 18:59:26 | 显示全部楼层 来自: 中国山东烟台
有solid_user,论坛真精彩。
发表于 2015-6-27 10:55:12 | 显示全部楼层 来自: 中国江苏宿迁
感谢分享!能有网盘链接更好了!
发表于 2015-7-2 16:19:17 | 显示全部楼层 来自: 中国吉林辽源
太快了!感谢solid_user
发表于 2015-7-4 08:43:29 | 显示全部楼层 来自: 中国河南安阳
很好,学习了,辛苦
发表于 2015-7-13 14:03:39 | 显示全部楼层 来自: 中国河南安阳
提示病毒,怎么回事,装不上,直接删除了
发表于 2025-6-16 16:13:40 | 显示全部楼层 来自: 中国广东惠州
& k$ u. E" D% C7 g6 w谢谢老大的分享!!!!!!
