Edgers,
( S% M) E2 p5 c! P5 `$ `' h Solid Edge ST7 Maintenance Pack 8 for Solid Edge is available for download.
Sincerely, . ?: k) `+ i) u: N& p, F# X
The Solid Edge Team ============
) |8 L c$ \9 M0 k, K Release Notes:$ U8 i5 @1 R% u& Y% T9 h1 \1 Z' @4 K
============ Maintenance Packs are released for CRITICAL items only. Maintenance Packs are available up to a maximum 6 z, J* G- z" Q, ]
of 15 months following the release date of the English version. The release date for Solid Edge ST7 English was6 Z" n( q1 M9 o3 H' f
08/08/14, making the Maintenance Pack cutoff date 11/08/15. 3 {; S+ u$ I" ^5 m' L
7 S, ?5 \( \; z- y A, r' H Download Location:
# M: h, Z: L# T# U+ {: f3 ]# { ================ ST7 Maintenance Packs can be downloaded from: https://download.industrysoftware.automation.siemens.com/solid_edge/ST7/Maintenance_Packs/
0 J: |3 f# d, S. j0 j% b
, N2 X6 k; b1 K Installation:( `4 x( ^8 C. e+ M' K
========== There were Solid Edge Embedded Client policy file updates in MP2. It’s vitally important that you install SEEC ' s+ v! G4 i& \* p
Administrator, which delivers the policy files to TC_DATA. Maintenance Pack Executables (.exe files) patch existing product dlls. Maintenance Pack executables
4 ?" {: w0 M- ] _/ X are all inclusive and can be installed on top of a base release or any released Maintenance Pack. Maintenance Pack Installs (.zip files) are complete product setups. Therefore, existing versions must be
, d! o- K H+ f5 I. Q0 u& r uninstalled using Add/Remove Programs from the Control Panel prior to installing the new setup. 4 g% S& j0 P2 \( |5 G0 E- f8 r6 ?
( w' f' T" Y x; z; d1 s E-mail Notification:
1 l' Z/ F g! q4 k- k1 l. \ =============== To receive direct e-mail notification for new Solid Edge Update or Maintenance Packs, subscribe # r& G- b8 K( ?; S2 M8 i5 b
to the SFBmail notification. To initiate your subscription, navigate to: http://support.industrysoftware.automation.siemens.com/general/email.shtml for the web interface.
. X* u6 K1 l- Z; Z+ }% K =========================================
% @6 Q- z. s- A; M: ~! X) T This Maintenance Pack addresses the following PRs:
1 B$ v. ^2 ~: g9 R8 v# h ========================================= ===API===
0 K$ h/ @" R3 B PR 7368046: YouTube states it will no longer support older YouTube apps ===Assembly=== c7 D* \) ^( ]3 l0 q
PR 7382055: Failed relations in replace part with copy% u# E5 f; e( `9 ]- H5 J" Y# @; I- f- B
PR 7377429: Dimension on Sync cylindrical face not shown if an assembly feature modifies part% d; v1 |; y* P+ N& s; y
PR 8266419: Path edits does not cause Frame feature to update, X- @+ c* Q6 j" j n+ \
PR 7382761: Performance issue opening an assembly file
8 |# e. {& \) |9 I& L# c3 F7 ` PR 7400876: Animation editor does not work ===Draft===
8 P: H+ v, A$ |2 r+ M PR 7316543: Wrong result when copy-paste table in draft.2 `3 c; ?, S- H2 B
PR 7332149: Callout doesn't handle Chinese + Cyrillic chars from DraftCallout.txt correctly
' z* t* b% l8 y; O) \4 Z1 a PR 7384367: Parenthesis indicating reference dim are interfering with dual dimension bracket+ r& q8 @2 V+ k. v+ G
PR 7396466: Draft - Copy/paste and attempted parts list placement crashed# z% l+ A- d$ ^1 A
PR 7395989: Incorrect dimension scale on Import of DXF files# B. _+ O! G9 a8 f- r) |
PR 8505242: Dimension changes when opening this drawing file in SE ST7 ===Part/Profile/Sheet Metal===
- K2 O0 k9 G8 l% J PR 7387755: Solid Edge crashes after clicking cancel on warning dialog8 N! b4 ?' J& ~, q
PR 7399116: Hole feature problem since ST7MP7
5 c* v8 `0 S/ K/ ~ PR 7280647: Smart dimension value differs from curve length about 0.5 mm [9 a5 \; G. j
PR 7405986: Solid Edge closes with 'System is Low on Memory' error ===Translators===
0 G+ B% B& b$ h+ B J PR 1991413: SolidEdgeTranslationServices.exe cannot run multithreaded ===Insight===
# F; X3 ]! V9 W, x8 z PR 7373760: Slow key-in in Property Manager- Insight actions during edit
9 m, T8 B, L' h' r$ i PR 7378436: Search Dialog "Results per page:" row is misaligned b; _! S0 ^- k
PR 2249492: Property Manager errors when changing properties of parts- w' p c; Q, X4 ]
PR 7396003: Insight Free Text search returns only one file for same filename in diff folders ===Solid Edge SP, Server, Standalone Client, Solid Edge Client===
+ @3 O" o$ d( x( G5 p: D, N PR 7390126: Error during upload to SESP when unmanaged parts are inserted in a managed assembly/ p6 j- C4 @+ n" Q. `/ R* N
PR 7370133: Workflow with option "beliebig" (any) doesn't work on a German SESP Server
- y( t$ L" e; t% q PR 7402064: DP - Modify Tool does not create tmp file for tif files (any image file) ===Solid Edge Embedded Client===6 T, B) Y8 l$ S5 I
PR 7371603: Dimensions values are rounded down with SEEC in French version
( b& F: t2 q, {! O% N PR 8505291: Solid Edge check out SEEC license when SEEC is turn off
! M( O$ W6 `4 g, L8 b2 n. E PR 8270039: Variables values are rounded down on FOP with SEEC in French version! Z+ l& S9 S) K! D1 `- c
PR 7402020: When do not specify a variant the assembly will be blank after it is open7 H ~6 t9 F8 M t" P8 K& c0 C
PR 8270157: SEEC - sub-classed item type missing forms
$ R/ W7 G, I/ O- |- d2 @" s PR 7408247: Change Ownership on SE Assembly doesn't change attached Form
: B7 _3 Q( d! \6 i+ f PR 8271312: Material property sync causes doubled Edge.exe process : |' X- u- E6 w5 N$ y3 h7 S
To access the current Edge Answers, Employees and Partners can click the following link.7 r# j, K3 w/ A3 z
https://sales.industrysoftware.automation.siemens.com/news/int/34/Solid-Edge-Answers
- K2 X; k" Z6 l' B/ E
Happy selling!! Doug Stainbrook, x! x$ p4 c/ g9 J: F* [6 m
Senior Application Engineer
- `, T& W. m; d! d Global Technical Business Development |
