查看: 2426|回复: 1
[分享] I-DEAS指令(文字檔不用下載)
发表于 2015-7-25 13:24:46 | 显示全部楼层 |阅读模式 来自: 中国台湾
I-DEAS指令
3 Q# C3 N1 a9 w2 L) T+ s/AG DS Check Shell . p0 Q% H- f/ ~7 J* E1 q9 P
/CL Clear list region
9 T. |6 ~8 q. V* M: y/CO AE WI Add entire assembly with history " v% d1 e& e) T+ A  ]
/CO AE WO Add entire assembly without history
3 w1 s- H( U! r/CO XCI Circular pattern without intersection check
- ?3 o0 g! U) u9 B/CO XRE Rectangular pattern without intersection check
( q) F  d. o/ |) V% x/ W# I* r; e/CR L2R 2 Rail Loft for MS5
: s: b$ m, i" a, s  k/ER OFF Erase switch off ' o' h: C7 w; J' W
/FI XX MF Memory clean up : ^# r: a& ?- \4 m1 Q3 c3 X0 C+ g; Q
/FI XX MR Memory report , K6 R7 c' B5 e$ @" N2 x
/FI XX OPL Use the MS2.1 IPLOT plotting user interface : k, f2 i3 R, f3 w: G( {
/MA MA Pre MS7 style manage bins 9 g% E! x7 E2 {& i
/MA IDM Display IDM Privilege Status   [2 Z/ W. }0 B" Y( E, a
/MA IT I-Deas8 Manage Items
7 p! `! [3 A4 @- v; [% s1 `9 d/MO DE==>刪除建構歷史(僅可在Master Modeler環境)
0 M7 [4 w1 g# v2 B4 [/MO E DI #dump canc dump dimensions to list region
& @8 d9 l; g3 S2 P4 K. T" ^/MO QERY Debug Modes
( I0 [3 Q+ m7 k/MO QERY GT List part params (errors)
  k7 g. k; d. B5 m: A# V/MO SPE FDG Fillet Debug Graphics
( }" q$ u" e4 D4 s, }/MO SPE FH Clean all parts in modelfile (hams)
) S+ C" k% B& D- V/ P- s' E8 S& Z/MO SPE RDI Renumber part data ids
9 u, F& W/ ]8 B0 D1 Z- T( t# \/SD TES Test and evaluate geometry in Master Surfacing # ^5 T4 N* b& n/ Z- P* C, [
/SD TES EX GEO Gives nurbs formulation of a curve 2 o0 n) \7 e  V4 x
/UP AP Update all parts in modelfile
7 X& N, L' ~  O& D- X! k/ i7 O9 F/XT Time since last XT
5 e2 K9 j9 U  ^2 o$ C3 Z9 I; o/XTO A whole load of extra menus including some debug items presumably for SDRC internal use. Different sets in Modeller & Assembly
4 u. O: G! k& w  H' u/ i* q2 ]! X/XTO CO BO CT Check tangency 3 D1 _2 S: X: t# ~  ^0 t/ F
/XTO CO BO FC EX Pre MS7 IGES Export
; `1 x$ j, t. y# P& {. k/XTO CO BO FC IM Pre MS7 IGES Import / L# z9 g) {* q( M' E) w
/XTO CO BO FI Displays fillet rails plus other extra geometry. 6 i( G3 s3 R1 A- s/ D! @+ |
/XTO CO BO MV Make part valid
: u& @8 v  |) n' _# C- w9 s6 e/XTO CO BO TO Display offending edges in boolean operation
. I$ W& {& ~1 O( T$ m/XTO CO PJ Partition Join " }6 ^0 v2 t( O9 \" V
/XTO DB CH Check part validity 7 S( z( S" I: \1 U% ?2 P7 k
/XTO DB CK Run Debug Check
; z# j: l* `# {6 L4 _/XTO DB WF CL Clean Wireframe (Ghost Connector Errors) ' q0 q0 k9 W1 d5 Y
/XTO F EA==>轉出3D-UNV
: Y/ V) P( s8 t( a% v( L8 B/ [/XTO FI EA Writes a Universal File / s7 ^5 @6 V8 Y8 S: L
/XTO FI EA Write universal / ~6 q- T; k+ n  E8 B/ r2 ?
/XTO MA WB Directory of workbench - J& z$ B. R% \
/XTO TE GG GO CA Export crushed ascii
发表于 2015-7-25 14:11:49 | 显示全部楼层 来自: 中国湖南益阳
这个软件用的人很少了,可惜了。
& |2 W# H% C- t5 V0 X* F" k楼主有工程图模块相关的资料吗?/ u9 a- b2 a& m" X; z
