发表于 2015-8-19 20:30:55
来自: 中国四川成都
#Rotary Axis Label options f: [8 x7 ], V8 Q. y- w& j
use_md_rot_label : no$ #Use rotary axis label from machine def? - Leave set to 'no' until available* Q8 k1 p& F' F, }
srot_x : "A" #Label applied to rotary axis movement - rotating about X axis - used when use_md_rot_label = no$ X4 ? P3 |& G- K1 `# w* a
srot_y : "B" #Label applied to rotary axis movement - rotating about Y axis - used when use_md_rot_label = no$ h" V# `& k& S
srot_z : "C" #Label applied to rotary axis movement - rotating about Z axis - used when use_md_rot_label = no2 p3 y; f2 u$ k7 w, }0 @- e3 }
sminus : "-" #Address for the rotary axis (signed motion) 6 y3 K8 Z" _. J6 j
把4轴的后处理文件打开,查找以上字段,把 srot_x : "A" 改为 srot_x : "B"
5 J. g8 F: M' ?% I: o
G! \2 r5 j7 R/ @; e不知道能不能用,你试试吧。9 _* t1 A, ~* h& h# @3 q9 r
" U7 M$ Z$ ?' ?, h! m
