查看: 1630|回复: 3
[分享] Mastercam X9 Update 1
发表于 2015-8-28 14:01:14 | 显示全部楼层 |阅读模式 来自: 中国广东梅州
4 y  O- U& P# N( g( b- P' g" f
5 C4 G; ^4 t# QMastercam X9 Update 1
9 x* F, ]- E5 J0 F* n% MThis update is intended to update your version of Mastercam X9 to Mastercam X9 Update 1.6 _" l: {; P; R
& d8 k7 e' G% R4 m7 B+ f% d. JMake sure you close Mastercam before clicking the Install button.+ ?5 m) k2 `# f3 K9 h
8 K5 o8 D7 c9 w! U6 Y3 HVersion number: 18.0.14020.0 0 a# q# ^7 P2 k6 a$ O8 G' L1 {- ]% {
! _/ y2 u- }) `& e7 V1 H0 H  WIssues Addressed 0 }3 D- {, _8 [) j+ l$ }2 Z7 H. N+ A
  • Radial chip thinning factor (RCTF) changes the FPT, feed, and speed
  • Update All option not updating feed and speed
  • Invalid radius condition on chamfer mill
  • Moving entity blanks geometry instead of deleting it
  • Xform functions not creating new geometry
  • ATP only processes one operation per level
  • ATP custom cut list fails without front/back identifiers in file names
  • Extruding and analyzing solids error
  • Switching WCS on toolpaths used in Nesting causes error
  • NCI not updated after changes in Plane Manager
  • Multiaxis linking move inverts tool
  • Locking four-axis toolpath around X-axis rotates around Y-axis
  • Mill-Turn machine deactivates some CAD functionality
  • Files with many tools/operations delay opening of Toolpath parameter page
  • Copying a tool not marking operation dirty
  • Mastercam start-up issues for some OS/processor combinations1 Z8 D, K, _7 o- r4 I
发表于 2015-8-28 14:02:11 | 显示全部楼层 来自: 中国辽宁铁岭
坐沙发)16*()16*(
发表于 2015-8-28 14:08:54 | 显示全部楼层 来自: 中国广东东莞
楼主,这是什么东西啊,是不是X9的补丁。
 楼主| 发表于 2015-8-28 14:11:21 | 显示全部楼层 来自: 中国广东梅州
是啊!等solid_user老大放水了!!!
