查看: 3066|回复: 1
[分享] Solid Edge ST7 MP9 Update (by SSQ)
发表于 2015-9-7 18:37:55 | 显示全部楼层 |阅读模式 来自: 俄罗斯
It's update only! To install it you need Solid Edge ST7 to be preinstalled!& j) H3 h9 |8 s$ }9 X! B; W' k: F
See _SolidSQUAD_\readme.txt for more info..
) N+ h$ e7 X5 o- Q9 U% |  m& C
! Y, e" ~8 W2 E9 Y torrent file..) s/ U9 C8 b9 w8 t  K/ U4 b6 [$ _4 U
SE_ST7_MP09_Update-SSQ.rar
15.86 KB, 下载次数: 46
 楼主| 发表于 2015-9-7 18:38:33 | 显示全部楼层 来自: 俄罗斯
list of fixed PR's6 a( G9 G. @8 K) Q7 l. Y. R. m% i
: Z9 h/ i1 m& M0 P$ x4 n2 k4 V--------------------------------------------------. p; k9 Q8 _; J7 W8 H2 `+ L
This Maintenance Pack addresses the following PRs:
3 C% X5 O1 D( ~2 s. ]& ?+ a--------------------------------------------------, @9 x" H) ?+ p* Z+ L5 a
4 @) ~% @" Y5 i; i% ^
===API===
' [, I" i2 t# {  f  O& N, I1 W: ^% h7 hPR 7418372: CommandInfo::Icon returns HICON of image list instead of a command icon bitmap
9 D9 V6 F' V3 z( B6 x0 _PR 7415571: API: ModelNode::GetCutLength returns 0
7 x% C6 S9 e; v. w7 p/ A. m5 H9 ]PR 7437107: The API 'ThreadDataByDescription' does not work in ST7
8 v; [2 a! M9 s& ?7 `* `  wPR 7457728: constraint.GetGeometries API does not return the correct geometry  n: i8 ]" \% S* @; F
! z" \4 S+ L) i$ d===Assembly=== 5 c% q" M" m( s) A  _9 P' _
PR 7405944: not exiting the command when a subassembly becomes fully defined during placement. J8 S8 K- y- s+ v7 g" _
PR 7410611: Added Display Dimension control to the Occurrence API
; C* x. f& a/ ]# F+ l6 tPR 8264755: "Save Simplified Assembly As" failing& B4 U2 U& c- o" C$ }
PR 1928569: Wrong Amount in "Atomic Parts List" (Reports and Draft)+ P& n$ Y/ f8 H& B- ~
PR 7413477: Expand All causing part files to load
1 I. \! f, U# A5 X; ]/ E$ C9 q. uPR 7423057: user is unable to copy sketch into opened Subassembly& Z) |3 ^& c! N( ]+ e/ V' X9 Z
PR 7432598: Updating all Open documents on each Peer Variable Table record update( l1 m% p# q- F$ L. C1 Y: L
PR 7439634: Item number blank and read only in occurrence properties in FOA files4 c) z# X1 g( U: ?% d
PR 7446113: part status not correct when adding tangential relations* R* p& X* S' i, E
PR 7457275: Interference checking on construction surfaces in ST77 Z' z! {, K' f6 u  h/ l6 s
PR 7459332: not being able to drag a component in some scenarios when going between a selected edge and a triad axis  R# C) x' x8 ^- Q. q5 E
PR 7462671: inactive simplified subassemblies not being included in physical properties calculations.' N1 p0 O& W; G: s& i
PR 8506060: Break links does not exist on the edit links dialog in ST7
2 g4 ^# b4 n( i; X% q8 Q/ YPR 7463722: "Display in Higher Level" setting will not affect physical properties calculations
4 v1 J: @+ x, w$ v4 gPR 7470955: PMI Section view does not cut a fillet weld2 z0 H$ f; ~, z
7 T/ ?$ i$ B, l& O4 ~===Draft=== 2 m4 [* c& r" r5 a  k8 Y! B
PR 7384379: Unusual semi-circles appear in some dual dimensions
6 S5 R$ P/ ^- [1 `9 XPR 7415256: Grid disappears when switching sheets
7 q+ }7 S2 v: t) LPR 7415586: Parts List changed unacceptable after update views5 B& G9 F" m2 y/ I/ j( _
PR 7363506: Loop test does not include spreadsheet" `  C5 {/ a& s% X+ |2 I  X9 T
PR 7376599: Honor hidden explode flow line in drawing views with explode configurations
- |# i: I4 A+ `PR 7405632: Tolerance becomes abnormal when I change a text scale
; R( T% M* Z/ C+ |; ~1 hPR 7407307: Blocks on background sheets not exported to DXF
: t, V+ }0 d" G, @* q3 n0 s# x2 {PR 7432084: Solid Edge crashed while reading entities
1 J8 o7 p( H9 d8 u2 V( FPR 7436337: Tangent command is in a bad state after pressing SHIFT and middle mouse button; W$ H- z9 C2 K* {) {3 L3 u
PR 7440042: Drawing View Properties / Style page shows the wrong style8 w# w. h' |& @# k
PR 8505679: Direction of displacement is reversed in the saved image
: x1 `3 k! d1 c# K4 F' s; g; J. Z- y1 g* u* W# Z+ a
===Part/Profile/Sheet Metal=== + }2 f9 Y1 B4 [
PR 7421230: Crash when inserting feature library" |8 u% v( L/ y& J
PR 7392093: Driving dimensions do not accept decimal values" b2 V" B- E3 u. q4 E) l; `
PR 7434569: KeyShot import issue& H3 W  V5 M% J7 Z1 s
PR 7247507: Problem of changing geometry in Sheet Metal Assembly 6 v9 O8 D4 X4 l( {4 K
PR 7271837: Deselected region reselected when green checkmark clicked
1 i; c+ ]# {  Y5 T  `PR 7437087: Smart Dimension locks 2 files up - Please repair in ST7
9 E- e9 \8 w0 b5 GPR 7441752: Transfer from styles via material.mtl doesn't work correctly! g9 L* Y, ?0 l; y0 ^8 T
PR 7444567: Unusual semi-circles appear in some dual dimensions
' `+ n+ A& c+ @1 {1 M, @PR 7448157: Sheet metal part can no longer be edited
5 X5 i/ f0 s2 |! v# a' ^
! ?# W5 {3 Z& e5 O. P4 T===Insight===8 K+ b1 G! W  Y  z% I
PR 7398888: Difference in assembly contents and relationship when opened with different user
2 {9 E% `2 T, r+ ]* F$ Y: ]' v$ Q& BPR 2215861: SaveCopyAs changes Author value in Summary Property to Windows User Name 0 R2 z, U* `3 A, l; }3 ?3 c
PR 7143583: Revise via SE is changing the author property + m# ?" Z# ^3 c/ |
PR 7361387: Unit Tolerance for Insight Managed files doesn't work - Dot / Comma problem5 y5 \2 }& U) q
  @2 u( G+ z6 v
===Solid Edge SP, Server, Standalone Client, Solid Edge Client===- G7 p1 P# K' Z+ U" j- N* U
PR 7387776: Crash seen on sending part to RB which saved under a folder that has "," in name
5 _( }; }* V0 l3 l% Y( |2 ~; uPR 7408925: SESP Client performance slow on Address -> Select Folder dialogue
9 f5 e: e. n- \% p2 u' u3 `) K; fPR 7431109: Select Folder dialog for New Document is incomplete if Windows Display is 150%
# B) _  Y2 ^- w% XPR 8274706: SESP workflow issues: SESP people picker web part takes lot of time to load
# ?! [1 D1 f8 T# L3 R$ M0 m2 @1 ?, q2 m# T! V; s7 S$ Z( u
===Solid Edge Embedded Client===
( C, i& ]' l6 |4 q4 @2 WPR 7412957: Multiple scenarios where SESE will either crash or freeze
5 @7 U- W2 d/ DPR 7429671: SEEC: Initial value required attribute not available in ATT Interactive) q. z8 f  k+ d1 N1 j( [+ J
PR 7458795: SEEC - revise all of a complex structure assembly does not finish
/ |; v* t5 ^6 H0 z8 wPR 8263114: AddToTeamcenter interactive doesn't honor the preference SEEC_property_item_name
! T* |: N- C3 e) u1 T7 u: h& `- n1 }0 V0 J8 }: }
===Translators===( h& }9 @' U0 N* H% m$ v9 l
PR 7426671: Solid Works files won't open in Solid Edge 0 E' Y; r3 W. k  M) Y% [% Y( O
PR 7428388: On some parts of the assembly SE in sync mode cannot recognize holes6 j% @6 r+ b+ R5 ^
PR 7428887: Export to 3D pdf, KeyShot, SEV creates several instances of the same part copy
6 a# M4 B- B9 G! n8 `2 |; b
; x6 d! E8 _! X---
  w$ ^1 N7 e$ P# M% wEnd 9 o; F- j& z! |' n) l7 _* h3 A
