查看: 1159|回复: 0
[分享] 复合材料结构分析挑战及samcef composites解决方案(201507)
发表于 2015-10-23 15:36:52 | 显示全部楼层 |阅读模式 来自: 中国北京
复合材料结构分析的四大挑战及samcef composites解决方案
1.      复合材料的介绍文档 7-1
挑战: 1.Composite materials and metals are completely different
2.Their use requiresdedicated design and analysis approaches
3.With classical analysis approaches (analytical or linear)
4.Composites are thin-walledstructures
5.Damage appears in composites, even when unexpected
6.Damage also present for static cases, notonly for fatigue
7.Damage is sometimesinvisible, e.g. Barely Visible Impact Damage (BVID), so this may be verydangerous if ignored
8.Working with compositesimplies the management of a very large amount of design parameters (much morethan for metals)
9.Physical tests areexpensive, sometimes difficult to conduct and numerous
解决方案:
     LMS Samtech具有30多年的复合材料: 软件开发经验,工程项目经验
All these materials can beincluded in an analysis with Samcef Composites
For some materials,specific progressive damage models exist
     具体方案介绍见附件。
具体应用:
   复材线性屈曲分析,复材非线性屈曲分析,复材非线性屈曲分析和优化,复材结构损伤分析及案例等等。
! @, [' m& e( n& ^5 M; W/ J* H
2015-7-1 SAMCEF Composites--专业的复合材料结构分析解决方案-复合材料会议.zip
3.91 MB, 下载次数: 11
