" b5 d& h; W# k$ b调质状态下35 CrMo钢的焊接3 o' _; @8 M/ p1 s
倪艳敏 ( L$ X& g. l2 p' h8 u! _(金华职业技术学院,浙江金华321017)) T3 b7 @5 b" o4 c A
摘要:通过焊接试验确定焊条的选用,并制定合理的工艺参数,实现了35CrMo钢在调质状态下与16Mn钢的焊接。接头具较好的机械性能,尤其是冲击韧性,满足了焊件在动载荷工作条件的设计要求。1 S# P0 A. l0 l4 |
关键词:焊接35CrMo钢/调质状态 ; g7 O g8 v) I# ]4 f; \Welding of 35CrMo Q.T.Steel % \6 t5 P5 C' v" y* PNI Yanmin/ U" R; c: I# r% V
(Jinhua College of Profession&Technology,Jinhua 321017,CHN)( P( @$ b: V9 }
Abstract:According to the welding test,the optimum electrode is selected and the proper procedure parameters aredetermined,thus 35CrMo Q.T.Steel and 16Mn steel is successfully welded.The welded joint has supermechanical properties and reaches the design requirement for working under dynamic loading condition. ( N1 k k; I( e2 `Keywords:Welding;35CrMo Q.T.Steel
