Creo 4.0 部分新功能介绍 % h% A! V- h: G" L% S" z3 L
$ O3 c6 G n' m4 {; Z$ L2016.6 发布测试版本C000, 2016.11发布F000( v9 g$ i( q& _& P5 `4 q
- P6 M& v: W9 o' g, J! K
' u( k2 H+ T! ?' b" B
- After select object(edge,surface,feature, component) by LMB, some related menus/commands will prompt automatically, just like Creo Direct and Creo Elements/Direct Modeling ( 增加左键选择后直接显示小工具栏)
- Import/export support AMF for 3D printing (支持导入与导出 3D打印 AMF格式文件)
- Support Full Screen mode (支持全屏显示)
- Provide some system schemes (提供新的系统颜色方案,因 CREO 3.0 的白色背景很多人不喜欢)
- Add flexible modeling extension into sheetmetal mode and assembly mode (钣金与组件也支持柔性建模)
- Support flexible hose into piping (管道支持软道)
- Update standard for geometric tolerance (形位公差支持新的标准)
- Update standard for surface finish symbol (表面光洁度支持新的标准)
- Add GD & T Advisor as one extension (内置GD & T Advisor)
- Add Keyshot as one extension (内置Keyshot)$ {; n5 [# v9 v' q9 D
