楼主 |
发表于 2016-1-5 14:12:31
来自: 中国广东梅州
' d: U+ M- i$ L1 F& f8 aIssues Addressed •Bull tool displays as chamfer mill in Simulator, g" ?% v7 b: F& K
•Converters: Importing STEP file changes wireframe color
( \" e H1 d2 n$ z' E& w•Create Door: Export to separate MCX looks for mcx-8 and not mcx-9
. i$ d1 E) i% _: h; B•Update to Spatial R25SP2 to provide support for the latest version of Catia V5
6 t& c4 r1 m& I& g•Add support for import of SOLIDWORKS 2016 SP0 files) [" o' E: o* c& q# Z
•Parasolid files imported/opened in X9 do not display saved wireframe colors
! w7 h, O% M' T0 d•X8 shows edges more clearly than X9
2 _5 |) l( M* \: Q•Relax machine compatibility check for LMDs
2 r, ~; u T H2 t•Tool holder is inside the B-axis head7 R$ h! }5 y: E" ~) Y
•Invalid tool warning in Simulator on a good tool definition5 l; c( C3 O s! m0 a8 ^5 E
•Allow user to override thread pitch in threadmill toolpath1 S7 A, E% m5 |
•Old style coolant is not retained, `8 J; @3 Y. ?! {
•Set shank type to straight on tools with taper length of zero3 v- `- m+ K9 g+ A& D" E, ^
•Coolant settings populated from tool library do not persist after confirming the operation9 R! k8 p; d4 i4 [$ B
•Crash report) z9 y+ ?1 X4 f4 o0 X
•Parallel Cuts Multiaxis: User-defined direction "sticks"5 {5 F2 ~8 f, ^) i
•Multiaxis algorithm regression when locked to 4-axis# f* G, D# h% @2 ?! [
•Rotary 4-axis influenced by Cplane
; o% S9 g9 x# v, i* }4 D•Feedrate override request not output
7 a# H8 P5 J+ |2 f; H |
