批量转cad和pdf宏错误,请高手指导,字体加粗的位置就不对了( s: e6 c9 Y0 C* q1 l* ~8 T
代码如下
* k" ^' d7 {- h6 p8 ZDim swApp As Object
7 H) ^. ]" Q5 L- CDim Part As Object
/ y! Q" |- B* r' Y; V8 s0 J* \Dim boolstatus As Boolean. B: b- J5 Y: E2 e
Dim longstatus As Long, longwarnings As Long! r5 l* C$ l. @: K" [
Dim PathStr As String
8 B. A; D! p; I2 W) oDim FName(500) As String, FNum As Long
; M: L8 T4 x! pSub main()6 o+ N: d4 ^7 f- T
Dim i As Long' r8 _, \3 T O0 B h3 ]' d
Dim PathStr0 As String, PathStr1 As String$ v* X6 p0 X6 e, y% P- I& z
Dim PathStr2 As String, PathStr3 As String, PathStr4 As String, PahtStr5 As String6 C G1 V4 T( Y4 L
Dim L As Long, L1 As Long3 A* j1 m8 k( r9 W! b6 l
PathStr = InputBox("请输入需要转的工程图所在位置")' \/ K4 m( X( ?1 }
Call Showfilelist(PathStr)
1 M4 G7 I$ z( h7 Y3 rSet swApp = Application.SldWorks. f8 C! J B* C3 l9 x8 |6 T
For i = 0 To FNum - 1
- h5 p% ~2 _) O6 s2 a3 q PathStr0 = PathStr & "\" & FName(i)) G$ V1 x {2 R# b' l z( D) a
Set Part = swApp.OpenDoc6(PathStr0, 3, 0, "", longstatus, longwarnings) z) g4 X2 z& z0 Z3 U, l" f
L = Len(PathStr0)
, b. d6 B: J; ]& W, [; {+ T PathStr1 = Left(PathStr0, L - 7) & ".DWG"! ^: ^" @- S( y( @/ C7 H# X
PathStr2 = Left(PathStr0, L - 7) & ".PDF"( ]. y( }! @6 U: m d. X
longstatus = Part.SaveAs3(PathStr1, 0, 0)
& E2 B8 k. j) r0 y longstatus = Part.SaveAs3(PathStr2, 0, 0)
/ D! R9 Q1 L1 I7 u 3 J& ?; o; j+ U) A* P6 R7 F, r! V' z
Set Part = Nothing4 O9 P) K; ~/ m4 {' j8 [6 S5 w% J5 v
+ e. }3 L2 R7 K' A* Z- A- }3 q L1 = Len(FName(i))
$ U/ q% o) O( O/ A- I PathStr3 = Left(FName(i), L1 - 7) & " - 图纸1"
8 V3 ]. f2 g1 m, u. q6 r8 V! G PathStr4 = Left(FName(i), L1 - 7) & " - 图纸2"! |: Z$ k5 Y( {! z, F
PathStr5 = Left(FName(i), L1 - 7) & " - 图纸3"
1 _6 T+ Q* o9 \# k
; t, n# S; g( _% O: @" ?) o swApp.CloseDoc PathStr3$ {) i' Y& ~( h$ c9 A9 S2 C
swApp.CloseDoc PathStr4
! x# ]1 w; \- _% w0 ~ swApp.CloseDoc PathStr5
5 ^2 J. e. i9 ^" L2 ` F* u. MNext i4 d, m4 \& \+ F; O7 R% S* f
End Sub0 y( b$ q: d9 s4 S& Z$ H# k
Private Sub Showfilelist(folderspec As String)( N) Z3 H# f, F U& B. w, i( S
Dim fs, f, f1, fc, s
7 f" N7 K9 ~( p Set fs = CreateObject("Scripting.FileSystemObject")# s5 h/ x9 w o# h2 D
Set f = fs.GetFolder(folderspec)
. ^7 s, m! ?0 R Set fc = f.Files+ d, U1 ^& X/ ]) s! p: i
FNum = 0 '清零2 N7 k9 r. L! t' c2 H) d
For Each f1 In fc
" a K) ?. K: `- [* _9 f0 u If InStr(f1.Name, "SLDDRW") > 0 Then
4 R4 |, l& X: J$ V" R* u- v( f5 W FName(FNum) = f1.Name3 d( T, r% R8 z3 U
FNum = FNum + 1
5 i) q' B, R, z End If
6 M3 k' a8 {3 c# O4 P, e Next) A& k" v0 V) j7 z4 Z" j
End Sub( J9 ~, u- r) P5 L- B) O
