捡来的,各位慢用。
5 m5 F" e$ V, p" Q- x X* p. S; u0 a; r g6 q
- Sub print_current_sheet()
. `& e( J& h! N$ S - Set swApp = Application.SldWorks$ ^5 s4 ?# X* Z* h6 n8 s) J- A
- Set Part = swApp.ActiveDoc
$ ? U; T7 ?: r1 U1 F5 Y. @ - Part.PrintPreview
- |4 N& O* q2 { {) B - answer = MsgBox("请把一张 " & Part.PrintSetup(2) / 10 & "mm x " & Part.PrintSetup(3) / 10 & "mm 的纸张放进打印机:" & Part.Printer, vbOKCancel, "打印当前图纸")
5 ~& X& R G/ y6 Z; L7 V0 p - Part.ClosePrintPreview3 I7 M' j0 P8 n/ ^6 ]. d# l* H
- If answer = vbOK Then
7 f& G9 m2 R0 K) A% l8 H& g: W - CurrentSheetName = Part.GetCurrentSheet.GetName
" C# B$ l+ v2 g; i: j/ t - AllSheetNames = Part.GetSheetNames
: Q/ C* |. z; R4 |% U - For i = 1 To Part.GetSheetCount" h- Q* o; o$ n/ c* \
- If CurrentSheetName = AllSheetNames(i - 1) Then
3 @6 e0 q1 L: t: C: Q M - Dim sheets(0) As Long
2 u( V) p- y/ _ - sheets(0) = i
1 E; X y0 A& b; \ - Part.Extension.PrintOut3 (sheets), 1, False, Part.Printer, "", False! f& g& ]. z" Z: |8 [
- End If
: ~9 Q& T. P9 k! O+ h% T - Next i
% K3 |( r, U) D2 C" d+ p: h! _# i - End If
+ f9 _& e* d# M3 U3 j- I - End Sub
( Z; E: h9 T6 \7 Y
复制代码
# u3 Y' P# t2 o
- u& \& j7 [: `, O
; I) [. D: n8 a; @$ }1 b |
