查看: 2329|回复: 2
[分享] 将图号、零件名、版本分割,并按约定格式保存文件的宏程序
发表于 2016-5-5 22:20:49 | 显示全部楼层 |阅读模式 来自: 中国广东深圳
其他
主题分类用于问题归类:
4 ~  z% q' W$ b" f! s
; i5 N% k; E; X/ ?( O9 `: r'本程序自动将零件以“图号(国标号)_零件名_版本”的格式保存;
9 M, \) [/ f/ w, |0 S9 ^$ L" p5 @0 f3 c* [3 Y3 k, p; A; ~5 C
'注意:" ?; \7 e# ?1 [7 }# r, q/ e: r
'①零件名不能以数字开头和结尾;
! `' _2 U1 L, U, `! }6 {- L'②零件名内不能有空格、全角的“·”;
* Z# `6 T( K7 v% j3 y# ]  M& l
  Dim swApp               As SldWorks.SldWorks/ A* j) {7 k3 r* X+ v/ M( W
    Dim swModel             As SldWorks.ModelDoc2# B8 y2 Z5 k( v9 d
    Dim swPart              As SldWorks.PartDoc3 f+ y4 b* O& P$ [1 y3 q2 q2 |4 g. {
    Dim swConfigMgr         As SldWorks.ConfigurationManager/ {$ ]! K6 c+ |
    Dim swConfig            As SldWorks.Configuration! L* V8 Z4 q6 ?% e3 D- w0 w
    Dim swCustPropMgr       As SldWorks.CustomPropertyManager
* d  k/ _  w) c& S" m" \) _    Dim swConfPropMgr       As SldWorks.CustomPropertyManager
# d8 X" V1 O* M; P5 a& F' o& u    Dim a                   As String2 l/ a6 n5 A) E# }( n3 V) M2 x
    Dim i                   As Variant' z0 E) @. k+ I0 K! Y  o
    Dim j                   As Variant
. t% m4 h! |( o* D    Dim b                   As String
/ X, h8 A" i  j# p/ j# b    Dim c                   As String
$ D  I4 F0 N4 c, t3 u    Dim e                   As String* h2 L: M1 t% G5 g
    Dim t                   As String
4 B. ]% c: f% S    Dim q                   As Long: l4 d  d! G* B% b; o$ N. Y, n
    Dim BB                  As String& m- g, P, T( v) }' |7 A2 M
    Dim OldPath             As String/ Q7 t# J8 ^2 f! h! a" M4 \
    Dim FilePath            As String
; h" I0 G' @; S1 @0 ]    Dim OldName             As String" N' c: _% o; j5 [7 U' A
    Dim FileName            As String
1 \$ Z% w5 E# q4 S, u
0 n. I* t$ f: W5 c+ Y   & _  c1 m- {; B' e0 L0 K( }
Sub main()( Z9 k$ M% H; o* L" o; {1 v, E+ T
    Set swApp = Application.SldWorks6 G0 g. h5 ]4 H/ {4 F8 z6 e6 }( `
    3 y; [0 h% a% E3 n. o
    Set swModel = swApp.ActiveDoc
! j. B9 A# p& J2 M    - O- b4 o5 I' f6 c; q5 D0 v4 x
    Set swPart = swModel/ _& }2 j5 r3 l7 ^7 |# K1 V
    4 l7 y. \. z4 ]- S& P+ V, X( g! H
    Set swCustPropMgr = swModel.Extension.CustomPropertyManager("")
8 ]: V5 l& k' i* E5 g8 k    . k* I% ?, E  d0 m4 o1 Z
    Set swConfigMgr = swModel.ConfigurationManager0 x8 O; q; e5 Z/ G' i
    : c  ^# v' d. A4 P/ @; a- r7 w8 S' ]6 u5 t
    Set swConfig = swConfigMgr.ActiveConfiguration" I4 O3 [: o5 M/ M$ O
    ) ?0 \. H% z% W. K9 q/ f9 Q0 Z
    Set swConfPropMgr = swConfig.CustomPropertyManager4 M$ E. G& J, l! U; s
# F6 w7 O" N  n9 u2 x: i8 w% K    swApp.ActiveDoc.ActiveView.FrameState = 1
# N* Y8 g" M+ V7 Y- y7 E    3 V# J  k, m0 J! b& I& H+ Z
    OldPath = swModel.GetPathName   '获取文件路径
' R7 u' B9 `' W7 Y" z, x    1 S# |+ g" S9 W6 ~6 u* I
    If OldPath = "" Then     '判断是否为新文件(即未保存过的文件)
8 P1 l/ [4 Y! D8 i6 {
% ]* J: e4 T0 c        swModel.Save          '如果是,则保存: @0 d6 T1 x( P
4 A& ~. n  [1 h. q( P" T        OldPath = swModel.GetPathName   '重新获取文件路径0 G- t5 @: V% C3 `! \4 h
9 Y6 c5 a5 [7 b  y; w    End If
( o! W; k( F- _: ?   1 i0 V) z: r* h& r
'将路径和零件名(含国标号/图号)分割开来  u, O+ h4 ]  ?0 B: B
    q = InStrRev(OldPath, "\")1 b, r1 |2 z; `  a
& A3 V' q2 A- d) E* {* R    OldName = Mid(OldPath, q + 1)
8 C7 n8 [- h  c+ @$ `' W2 X+ }
( g# C% B% P1 A2 X2 }' k& l  O    FilePath = Mid(OldPath, 1, q)
0 ~: j1 A7 F  v5 S             C8 n& _, j3 L2 t5 r
    t = Right(OldName, 7)7 S( Y) A7 X2 x4 l* K
6 O8 O4 M, J9 B    If t = ".SLDPRT" Or t = ".sldprt" Or t = ".Sldprt" Or _
- }/ j- p( _$ p% O% u+ P5 q$ T        t = ".SLDASM" Or t = ".sldasm" Or t = ".Sldasm" Then: E' I: c0 B0 {( E* f- J# r% v5 Z
- o$ I. J* P4 Y' f        c = Left(OldName, Len(OldName) - 7)
  ~: w! T# ~. O6 k1 s+ r/ n1 `                8 J% a3 x$ d1 D" q
  End If6 |! X$ ~+ h; J3 R
0 J7 C+ D9 r( @( }9 K3 u'判断文件名是否含版本号,如果是,则分割版本号
% z: ~6 A- ^& C5 M  B/ v. `    BB = Right(c, 3)9 m. s/ |% A, v9 H# c* I; S( w
    If Len(BB) >= 3 Then
: \  ~' g" s: o    0 f, H/ Z$ D4 l0 Y7 V
        If Left(BB, 1) = "_" And (Asc(Mid(BB, 2, 1)) > 64 And Asc(Mid(BB, 2, 1)) < 91) And (Asc(Mid(BB, 3, 1)) >= 48 And Asc(Mid(BB, 3, 1)) <= 57) Then. P8 m2 |$ J3 c6 ~# d
        2 \1 Z1 E0 r, X& x% M: ^& t0 q
            BB = Right(c, 2): c = Left(c, Len(c) - 3)4 }8 P1 e1 d0 A8 I7 X
0 r4 h5 n) R, t( y5 d        Else
& q8 o7 a' p& q3 _5 Z, {4 y" I
! }/ C6 |& u" J. m/ K            BB = ""
4 o, u6 x4 F. ]) Y            5 E" C( m' a- H5 D' ^- t
        End If7 o' w7 h+ @$ Z
        0 w+ z/ h8 ]" ^
    End If
3 s  q! k  r; v  s  U: S'下面是图号/国标号与零件名的分割
  ~' E( c2 \" N" p0 q    If Left(c, 5) = "XXXWG" Then      '如果前面是XXXWG,则判断为外购件+ c5 b) V7 I0 Y, |- i8 Z  F
        ' k$ U. Z6 o& A% }! g
        e = Left(c, 11)               '外购件的编号为XXXWG□.□□□□,所以选前面11位为外购件编号
5 H2 S1 }. g* a4 q) Y3 O
+ h: K  g7 ~& Q$ `0 c) O        q = 12
* m/ G9 t  L1 Y0 r# k
1 i' I( q# z' S( ~& U5 M* J9 Q+ L    ElseIf Left(c, 2) = "XX" Then     '如果零件名前两位是"XX",则判断XX后面是否为图号
6 O# B$ v- L9 {
- f: c: w( Z, `+ D3 {        If Mid(c, 6, 1) <> "." Then b = c: goto FileName    '如果从左边数起第6位不是".",则判断为不带图号
0 {3 C! C$ n; s: l8 c
2 r+ J; D+ {+ a0 b% [: _        If Len(c) <= 5 Then b = c: goto FileName            '如果从左边数起第6位是".",则判断3到5位是不是数字(按XX的图号命名规则,
1 Q1 p, C) \% k: E  P: O% }/ ]5 n
7 W2 D5 D  K9 Z9 Z( [, s! q        For i = 3 To 5                                     '3到5位是数字),如果不是,则不是图号* c( i1 W" {+ t" I" C
        5 w) T% P. F3 F" X& R
            a = Mid(c, i, 1)
" H0 G& O4 C) o* ?; m' [        % W0 @: A5 C& H7 [  B
            If (Asc(a) < 48 Or Asc(a) > 57) Then b = c: goto FileName
$ h" N) Z( N" e, t4 Q6 i( s
- N. J1 a% Q% w% V: c$ g) w        Next i
  X" ^' w- K: M' @, [" H
0 O& B  A8 [1 d& @+ `        i = 7
6 W# ?, a7 a$ ]9 l. y( U1 \
' ]! [+ W* Y0 r7 }. R        a = Mid(c, i, 1)
5 ^6 u5 ]- E9 ^6 ~$ n+ @" E& @' x            ( p4 S: y& i8 C, T) y- t, R
# M" w, I/ Z' Z/ o. _. w
% K- ?  N8 M, [) @" N3 M        For q = i To Len(c)                                     '如果3到5位是数字,. w( R) A' v6 }; U" B) i
- g- [# b$ S1 c; o, T5 Y( q; a            a = Mid(c, q, 1)
0 s" K. T" g" v! @6 T# e( {% W            4 p. s+ n1 B' A" H, J
            j = Mid(c, q + 1, 1)# P: r& l! f: a
0 t0 N  t0 m+ y( s            If a = "." And (Asc(j) > 64 And Asc(j) < 91) Then   '判断图号是否为修改版本(A-Z,
& B+ L# y1 O0 Y; H        '其AscII码为65-90),如果是,
* O/ R- S1 k  t5 g; ?7 G                e = Left(c, q + 1)                              '则将其后分割
3 m9 |5 w& n7 L5 ^
# X. l- j! d) g: v5 s+ ?2 u                q = q + 2" z# @8 ]+ D& C- R1 ~/ i
7 m+ E/ S7 y- ^! S* w2 ~% O6 V                Exit For" I! X+ T% z, d) @0 }+ M; E
6 X" _& q3 j! {( C+ I1 \/ F            ElseIf (a = "_" Or ((Asc(a) < 48 Or Asc(a) > 57) And (Asc(j) < 48 Or Asc(j) > 57))) Then. a+ b! h) n+ S6 j, y
                                                 '如果文件名中含有分割符“_”,
5 p# Y; C% o8 N+ q                e = Left(c, q - 1)               '或者连续两个符号均不是数字,则分割" \! E$ O. v2 o7 ~; r: z! t6 a
2 \* j# ?# R2 k2 q' E% {  \7 ^                Exit For! s8 F* ^: S+ p$ [1 m) H- O/ w2 O
$ Q* `0 j/ I2 m' H' O5 o% S            End If% n* }5 \9 T! I2 t
$ Y0 F. C7 ]; |# G* E3 ]- P3 `        Next q
* d' t8 b* O3 B" R) M
2 c( i! @6 \$ R  {7 d    ElseIf Left(c, 2) = "GB" Or Left(c, 2) = "JB" Then            '如果零件名前两位是"GB"或者"JB",则以下过程为截取国标号
, N9 s, k% k5 I- e        2 Y, b* l2 d5 R6 r/ n" u  z3 z- b, ]* a
        q = InStr(4, c, "-")) [# s- s% g" M# v
        ( F, p% |$ w3 D' l4 I) m
        If (Mid(c, q + 1, 2) = "19" Or Mid(c, q + 1, 2) = "20") Then, m! M4 a3 n# }7 Q( T2 b
) A8 Z) P6 M# x5 k! v  @            e = Left(c, q + 4)
8 a- c( B8 v, O% l4 ^2 R( [5 U9 F. I
. d( ]1 ]: o' v            q = q + 5
6 Q& E% B' h4 g! L/ K
+ K- {+ J1 \( I7 p' x- V       Else9 n+ L0 z+ K' t9 m9 i# m$ l. [
" P( s" J! S% J. g            e = Left(c, q + 2)
% q+ q* C8 V! y: I; y; R
0 ?; e4 Q0 m/ J6 |& w* R/ w- a( U            q = q + 3; J$ V) j, h. W/ {/ k7 f
' b( l  j5 B5 Q; ?        End If2 r% a/ }) F. W7 L) r
            1 c. o9 W# X9 e8 K# H
    End If1 \. _$ ~/ D- G- h1 x8 C, n
                                                         9 ?0 B, U$ f5 g8 B
'截取零件名) X" X$ M+ H7 ^" P
    If Left(c, 2) = "GB" Or Left(c, 2) = "JB" Or Left(c, 2) = "XX" Then) x8 b7 x5 W% x" `  s+ p7 O
    + l0 b0 ?) }1 `' [  }  g( L
        If Mid(c, q, 1) = "_" Then                             '如果已经有分割符("_"),则; D5 _' g+ \+ d6 ~+ u. I
( N$ Z6 J- G" F4 M            b = Mid(c, q + 1)                                  '分割符后为零件名0 v& c) r$ ]' H- \3 T+ P
    4 R# _( u5 N9 c& }  [
        Else                                                   '否则
2 O) j& d7 J/ e1 c/ F; P7 ]6 f% w    : C3 [' L- N0 H4 u/ {+ c! C
            b = Mid(c, q)                                      '从当前位置分割# g' \3 T+ K# e
    # N9 g5 ?. [6 x7 I0 V4 z6 x0 T
        End If6 P. f. ?" K& d2 H
    4 t! R" y, e8 F. y" r0 q3 g: s
    Else
) q' v/ c: s# v% R# p    0 c  G! l; J9 ?3 F2 ^, W1 g8 r
        b = c       '如果图号或国标号为空,则零件名=文件名4 w9 w8 y7 \9 W# F) v# @8 @- O6 ?- Z
    4 s- `/ \  \# U1 z# K4 s, x
    End If
5 S) t8 ^8 C, J& I    ! [! _5 e" ?* b
'将BT改为B/T, B/改为B/, 2位年份改为4位年份; h# C: e9 I# q$ z6 ^# _
    If e <> "" Then/ E" J7 i( b  E" r, Q$ E
3 l3 ?: j0 n( f$ B        a = Mid(e, 2, 2)4 H8 M& i( j+ w( }4 X
            1 p) A+ p3 |, |- N; _1 @- x8 d' J
        If a = "BT" Then e = Replace(e, "BT", "B/T")       '将BT改为B/T, @* E" w0 m- w/ `5 p0 |3 z. O; t
9 V( a3 z  O$ \8 x        If a = "B/" Then e = Replace(e, "B/", "B/")        '将B/改为B/7 Z9 ?) v' P' p" c5 Y% Y/ Q
1 p8 h1 ?2 M" x; k  M8 L3 b        a = Mid(Right(e, 3), 1, 1)7 V. P5 \6 B/ ]. B0 k; Y
        " x% X+ k3 W( J# s
        If a = "-" Then e = Replace(e, "-", "-19")          '将2位年份改为4位年份
  J; `  `8 Q- g+ k% v        4 U6 m% q& W4 t9 a7 \# n$ L/ W; K# `
    End If4 o; ]8 V' B* r* N; q
7 ]0 u! L; M; S- u; ^4 zFileName:" i, O/ M, O' W* j7 g0 z( \
    If e = "" And BB = "" Then FileName = b + t# l. D) v* O+ @5 B: ~+ K
& t4 d' D' I. y6 Z    If e = "" And BB <> "" Then FileName = b + "_" + BB + t8 Q* S7 _* b2 Z5 e3 O+ ~- B
    ) ?' x- @9 O2 R( j
    If e <> "" And BB = "" Then FileName = e + "_" + b + t! p8 _8 P7 D9 B6 ]
    ( E3 c2 E" M6 U3 }( F/ b/ {
    If e <> "" And BB <> "" Then FileName = e + "_" + b + "_" + BB + t# c, H8 ?" n0 S* D/ s2 G
    swModel.SaveAs (FilePath + FileName)- X0 l5 c/ y" @5 o% Q
    ( S, ?2 i: l. _1 ~7 E
   End Sub. H; ?2 @& W( n' G
发表于 2017-1-23 14:04:50 | 显示全部楼层 来自: 中国江苏苏州
我正在找的,谢谢楼主
发表于 2017-2-5 09:21:24 | 显示全部楼层 来自: 中国江苏苏州
真是高手
