查看: 1161|回复: 0
[分享] 熔模铸造中蜡模制造的方法研究
发表于 2016-5-20 15:41:55 | 显示全部楼层 |阅读模式 来自: 中国黑龙江哈尔滨
熔模铸造中蜡模制造的方法研究$ W* [4 P  o# K% S
慈铁军, 张刚
9 K9 x: }) Y! l. [( W; J/ Y(华北电力大学,河北保定o71ooo)8 N" X* g. n3 O) p+ ]6 C
摘要:探讨了工业工程的方法研究技术在熔模铸造中的应用。采用“5W1H”提问技术和
0 R* L; i* J3 n“ECRS”等措施,改进了熔模铸造中蜡模制造的生产工艺过程和工人双手操作方式。改进后的工艺
" f' M- k$ }- q  l过程大幅度提高了生产效率,减轻了工人的劳动强度,提高了产品的质量。6 N7 ^6 c7 @* g  p3 Q+ v7 e1 p
关键词:工业工程;蜡模铸造;方法研究
. j/ E1 x1 g, X3 Z- k) U8 B1 Q中图分类号:TG249.5 文献标志码:B 文章编号:1003—0794(2007)l1-0101—03
$ P( y: ~1 n  f1 ~  ]8 cM ethod Study of W ax Pattern M anufacture in M elt M old Casting- p; `+ ?# D4 ?' A  a  p
CI Tie—jun,ZHANG Gang6 O: O0 S7 s0 `0 D# G2 B
(North China El~tric Power University,Baoding 071000,China)
% b; |% W; @/ _* l  k6 mAbstract:Discusses the application of industrial engineering method research technology in the melt mold cast—
9 U& A& `. h" Z7 T1 [5 s. ^ing.Through using the inquiry technology of“5W 1H”and the measure of“ECRS”and SO on,the wax pattern
  O$ e: J9 N4 D7 }- V& Vmanufacture production technological process and the worker both hands operating mode are improved in the. m3 m+ C4 {. I6 Q
melt mold casting.It mades the improvement the technological process to enhance the production eficiency* F2 D& ~0 l8 z
large scale,reduce worker’S work to be weary,improve the product quality.% u' ?  c: v* K2 C
Key words:industry enginering;Wax mdd casting;method study' C5 g5 y# l! {& n
/ h: m/ T" B2 L
熔模铸造中蜡模制造的方法研究.pdf
173.03 KB, 下载次数: 8
