本帖最后由 密密麻麻 于 2016-8-26 11:25 编辑 ; m6 o. g) t4 z2 g |- _! u+ L
1 s# J: O! T& g8 R
IF (G01 == 1) //正常鑽孔模式5 f9 {7 Y- l% `5 _1 p, H/ U0 @5 U
* SET_ON MCH_FEED;$ |; r' l2 K/ D% P- B2 i
7 d4 p) W* \6 F# h* G3 @& X' b
* IF_SET (CYC_RETR) OUTPUT CYC_RETR " " ; END_IF ; 取消輸出G98 G996 M5 M7 ]8 }" P# l0 H) Z
IF_SET (MOTION_CODE) OUTPUT MOTION_CODE " " ; END_IF ;$ Y8 M. ?3 o6 l; B; T; F
; N# X# m% \0 T* G1 ] KIF_SET (X_CURPOS) OUTPUT "X" X_CURPOS " " ; END_IF ;
+ Z( A& I% f! o7 A$ h. CIF_SET (Y_CURPOS) OUTPUT "Y" Y_CURPOS " " ; END_IF ;/ c' z# I: @$ b0 m
IF_SET (Z_CYC_DEPTH) OUTPUT "Z" Z_CYC_DEPTH " " ; END_IF ;# p5 Z \3 a# ^
IF_SET (Z_CYC_CLEAR) OUTPUT "R" Z_CYC_CLEAR " " ; END_IF ;' w$ P$ H9 ~5 b. ^
IF_SET (CYC_PECK) OUTPUT "Q" CYC_PECK " " ; END_IF ;
( [& Q `2 D, ~5 H( I# nIF_SET (CYC_DWELL) OUTPUT "P" CYC_DWELL " " ; END_IF ;
& Z8 r6 |) r9 J. Y7 T, pIF_SET (CYC_XSHFT) OUTPUT "Q" CYC_XSHFT " " ; END_IF ;6 B9 }( d2 `+ G# }
IF_SET (MCH_FEED) OUTPUT "F" MCH_FEED " " ; END_IF ;
. _( Z9 d( {1 c5 j+ S0 _ END_IF ;$ {* V% l- m& i# }/ f$ }6 d
* 使用G1鑽孔) Q5 M8 x$ N& r6 @- s( O2 W- h l
4 O; m/ a& s+ GIF (G01 == 2) //G81方式用G01鑽孔: W, b3 p' P0 E( c$ @1 O( Z* P+ I
OUTPUT "G00Z" Z_CYC_DZINIT;$ u7 w G5 ^5 J& ?
OUTPUT $;
. ~5 J! _4 r# Z0 f6 g z OUTPUT "X" X_CURPOS;( l7 ^! v+ s' J! s, \0 B: W3 M
OUTPUT "Y" Y_CURPOS; . ]4 Q/ I2 ?# O6 [
OUTPUT $;
, D- b, B, ^" Q8 P6 I) U5 ? OUTPUT "Z" Z_CYC_CLEAR; ( Z! [4 G# O% n: |0 @1 Y
OUTPUT \J;* y* z4 B: @$ I) G7 F1 A
IF_SET (MOTION_CODE) OUTPUT "G01"; END_IF;' @" k$ z0 O" [, D
& T5 ^; H6 Y# P# M, B# I/ U8 y OUTPUT "Y" Y_CURPOS;
1 i, B5 @; v' f9 Z9 _- C( f4 m" H OUTPUT "Z" Z_CYC_DEPTH; 0 F- E& f6 H1 l U
OUTPUT "F" MCH_FEED" ";; s) e+ g2 O7 _1 \/ j. c7 z
END_IF ;9 q4 w4 E, }7 r# d
PS:這只是片段~~請加入在鑽孔循環(CYCLE內~~還有開頭那邊請加鑽孔的開關INTERACTION (MULTI_CHOICE) "鑽孔模式/正常/G81=G01/G83=G01" G01 = 1 ;不會整合的請不要使用~因為不同的代碼~會有定義的問題~會出現很多的錯誤~
0 n) X& u9 e' b
~# R& P9 h+ T! {& ~6 q( l# E
+ s9 v5 K# ]0 k* x1 u |
