查看: 3010|回复: 5
[原创] 90度頭上下左右的寫法
发表于 2016-8-14 09:19:05 | 显示全部楼层 |阅读模式 来自: 中国台湾
安装
主题分类用于问题归类:
INTERACTION (MULTI_CHOICE)     "側機頭/不使用/右側/左側/上側/下側"        CJ = 1  ;
/ M. v( U! [) w" A, P9 B
$ l/ {# n* S; _8 E2 }------------------------------------------------------------------------------------------------------------------------
; ]- ~7 o+ E2 Y$ U! k+ ^- c
( [" q# ^6 e* M) e5 X: z/ j, z  }# KLINEAR MOTION: fast:1 X2 W  _1 h! x* M8 x7 y( `0 ^
Znew=(-1)*Z_CURPOS;
( T$ T& A: f2 J% I( w6 S) {% L Xnew=(-1)*X_CURPOS;
0 `  W# X7 Y4 |* P$ D Ynew=(-1)*Y_CURPOS;
. X( k, t# [! S& j
1 l+ a" m; y! H0 _! V  K$ [ $ D* u8 {- ]. x) i7 l$ z: r
OUTPUT $ ;
, u3 Y" w6 B" _' }1 n IF_SET (MOTION_CODE) OUTPUT MOTION_CODE   " " ; END_IF;
) H+ _; y" M, Q/ k1 e) i: e  IF (CJ == 1) //正常
# b/ E/ S/ Z6 {/ d! U# G; a
$ ^4 M% l# b+ N- ^$ D3 J* Q        IF_SET (X_CURPOS)    OUTPUT "X" X_CURPOS  " " ; END_IF;6 _+ @1 t5 M; e: W/ b
     IF_SET (Y_CURPOS)    OUTPUT "Y" Y_CURPOS  " " ; END_IF;' m9 w- _1 {1 v$ j" v
     IF_SET (Z_CURPOS)    OUTPUT "Z" Z_CURPOS  " " ; END_IF;6 U, A/ S! A7 q+ V& x" k
      END_IF;
) q/ t* h, `5 ^5 G    IF (CJ == 2)  //右側X=Z,Z=-X
% C* h9 o  Y; |2 Y0 J( A, z8 _+ Y     IF_SET (X_CURPOS) OUTPUT "Z" Xnew   ; END_IF ;" w+ [- v- l# g- l3 F( U
        IF_SET (Y_CURPOS) OUTPUT "Y" Y_CURPOS ; END_IF ;
: D' o9 n( A  b+ W2 N        IF_SET (Z_CURPOS) OUTPUT "X" Z_CURPOS ; END_IF ;9 z8 a, O2 n$ ]; r
END_IF;: p0 ~' _1 N& p
IF (CJ == 3) //左側X=-Z
6 u1 `! \7 Z: E5 r, f  r+ s1 O! n   9 R% d' b6 ?+ [9 e
        IF_SET (X_CURPOS)    OUTPUT "Z" X_CURPOS  " " ; END_IF;
% K: B* k, {" z+ M     IF_SET (Y_CURPOS)    OUTPUT "Y" Y_CURPOS  " " ; END_IF;7 W4 v3 x# R& T+ |
     IF_SET (Z_CURPOS)    OUTPUT "X" Znew  " " ; END_IF;
& W& G5 _" Y5 z- ~: m8 W
" M1 k  s' P( `1 A7 J END_IF;
4 k2 s5 n% v7 c) j7 N1 O9 s IF (CJ == 4) //上側Y=Z,Z=-Y6 E. J3 a) C* U' m( `( O
2 m5 s% e/ n8 r% `& a+ V1 B& {  o        IF_SET (X_CURPOS)    OUTPUT "X" X_CURPOS  " " ; END_IF;
/ E! t+ d% u' Y6 }     IF_SET (Y_CURPOS)    OUTPUT "Z" Ynew  " " ; END_IF;
2 ~5 K7 g3 @5 ?7 t     IF_SET (Z_CURPOS)    OUTPUT "Y" Z_CURPOS  " " ; END_IF;+ z' h. O; ~  i- p- W
, q' Z* r+ p  r0 g% q5 y
END_IF;! U4 W# E: ^$ {5 c9 M# V9 ?
IF (CJ == 5) //下側Y=-Z5 U: r! U* t' x, c$ y6 M/ V
7 T- ?% W! q4 ~' F& E5 |7 T( w        IF_SET (X_CURPOS)    OUTPUT "X" X_CURPOS  " " ; END_IF;3 X. Y; Q) K% V3 Z
     IF_SET (Y_CURPOS)    OUTPUT "Z" Y_CURPOS  " " ; END_IF;
5 N* S( ^( g. d- O     IF_SET (Z_CURPOS)    OUTPUT "Y" Znew  " " ; END_IF;# t' W6 y2 M' V+ b0 Z7 @& f  ~2 m
( B7 d/ f9 Y+ y3 w$ u; k  Q END_IF;
( C* Y! ~+ {6 V, T
$ U6 I/ t* r! }, t8 A因為檔案有點長~~所以我只秀出其中的一段讓大家有個方向~~這是我的寫法~~如果你有更好的寫法~~也可以一起討論+ E; a" |4 m8 F1 o
参与人数 1三维币 +10 收起 理由
密密麻麻 + 10 好资料,感谢您对论坛的支持!
发表于 2016-8-15 08:53:25 | 显示全部楼层 来自: 中国河北秦皇岛
值得学习啊!这个句法是GPP还是GPP2啊?
 楼主| 发表于 2016-8-17 06:39:50 | 显示全部楼层 来自: 中国台湾
lao_ting 发表于 2016-8-15 08:53
; i7 q$ K) a, o! q6 R% _值得学习啊!这个句法是GPP还是GPP2啊?
2 A$ z* |0 ^9 ~7 P9 o: i' e/ a
GPP2~~GPP1也可以用類似的方法去寫
发表于 2016-8-19 08:10:21 | 显示全部楼层 来自: 中国河北秦皇岛
楼主可以写篇论文了!是后处理的核心啊!5 F  a  H3 X; e( T' u4 y, W
楼主能在每句话后面加上中文注释吗?
发表于 2016-8-19 08:29:50 | 显示全部楼层 来自: 中国江苏苏州
支持楼主,以后多上传这类资料7 s( i& \% I1 E
楼主能在每句话后面加上中文注释吗?
发表于 2016-10-11 16:41:34 | 显示全部楼层 来自: 中国江苏苏州
不错,楼主上传文档测试一下
