发表于 2016-9-2 19:53:43
来自: 中国台湾
更正3 d9 D8 ?& G r" m
# --------------------------------------------------------------------------" E+ O4 K' ?4 @' J
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
8 Q) j3 F: `( p* S) a: ^# --------------------------------------------------------------------------
$ D) H' r# x! ]2 M' U( x! b0 k#Default english/metric position format statements
# k" z3 _7 L Y/ H2 @# u& Ffs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize ( 改 fs2 1 0.4 1.3l6 C- Z% i, L* d' D
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place 改 fs2 2 0.4 1.3l
! @) d+ C- d$ E" D4 ?% Vfs2 3 0.4 0.3d #Decimal, delta, 4/3 place % _! c3 x7 L* c, M8 y
#Common format statements$ F9 s/ f. J* _" _. P8 o
fs2 4 1 0 1 0 #Integer, not leading6 B" l" S; _! c. W
fs2 5 2 0 2 0l #Integer, force two leading
4 V: j# u2 s( @) e5 ?" E+ k3 rfs2 6 3 0 3 0l #Integer, force three leading
: u. o# V, H& V+ r! w) Gfs2 7 4 0 4 0l #Integer, force four leading
! C7 v% F# H2 g) \4 a& i3 Cfs2 9 0.1 0.1 #Decimal, absolute, 1 place
6 a! @3 D. H- ^$ {0 m5 ~% ofs2 10 0.2 0.2 #Decimal, absolute, 2 place& n, x8 y+ a. a# F
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
1 J, [5 V/ p5 z$ @4 f/ I7 P, i% ^fs2 12 0.4 0.4 #Decimal, absolute, 4 place
V! p, K8 O/ x: ~fs2 13 0.5 0.5 #Decimal, absolute, 5 place
A8 H* E7 c; y6 u! O& wfs2 14 0.3 0.3d #Decimal, delta, 3 place
+ I4 O: N2 y# e& O3 Q* dfs2 15 0.2 0.1 #Decimal, absolute, 2/1 place (feedrate)
/ z Y) m7 F- \: x! t2 nfs2 16 1 0 1 0n #Integer, forced output
% e9 J# Y5 F8 Pfs2 17 0.2 0.3 #Decimal, absolute, 2/3 place (tapping feedrate) 改 fs2 17 1.4lt #Decimal, absolute, four trailing
2 F$ u+ Y' j$ l: J: Z# This format statement is used for sequence number output
X& ~7 F: t9 _# u2 N# Number of places output is determined by value for "Increment Sequence Number" in CD( ~: Y9 f* w& Z D% X
# Max depth to the right of the decimal point is set in the fs statement below
$ O* H- d# p. [: U9 X7 Xfs2 21 0^7 0^7 #Decimal, 7 place, omit decimal if integer value
0 ]; B: Q3 u# Y; T+ E, ]fs2 22 0^3 0^3 #Decimal, 3 place, omit decimal if integer value9 I3 q( h5 s4 \, T% o! ~, ~7 i
6 P' G: P' A' w1 B: z# Y
