查看: 1523|回复: 0
[求助] 关于批量修改零件属性的问题
发表于 2016-12-14 16:02:44 | 显示全部楼层 |阅读模式 来自: 中国天津
安装
主题分类用于问题归类:
+ Z  q  [7 ^/ |: n- U; V
  Y2 Q  K! _$ V+ f7 u( m'
+ Z8 t: v9 r0 q'Dim swDM As SwDMApplication
& |$ t+ j: u  k  |) h'Dim swDoc As SwDMDocument12
: t% q& F) I7 u9 r  L1 K" T! a'Dim mOpenErrors As SwDmDocumentOpenError- ^8 [6 p+ ~7 b, o' G4 R
'Dim swCfgMgr As SwDMConfigurationMgr
8 A  @% O  L6 z4 O- a'Dim objClassfac As SwDMClassFactory& x, S! k; T, n: E0 W  N
'Const SWDMLicenseKey = "C45DA6BCACBC9A3864AD7ACAB1C78A17EE34AFA74DDAFF6E"9 x% M8 D: c" \9 a' u
+ m3 n" Z; k9 a& A, J
Sub 打开文件()( ?* r5 }/ b/ v% A" ~
Range("A3").Activate0 _  E/ M" z1 y
'Set objClassfac = CreateObject("SwDocumentMgr.SwDMClassFactory")
8 h2 Q4 l3 _) C'Set swDM = objClassfac.GetApplication(SWDMLicenseKey) '啟動SWDM+ T8 e; f  V1 r2 p3 o5 p. a( I
Set swApp = CreateObject("SldWorks.Application") '启动SW
% N+ O' W8 z) l9 E5 c/ dDim intChoice As Integer6 X; t3 ?/ g# j4 Y7 q8 ^5 p
Dim FilePathName As String% t; \7 z! q4 A3 ^
Dim i As Integer
0 M, {, ^7 ^% p4 Y2 e* o/ g; nHeaderRow = 24 w# k& U2 g7 e) ?* L0 a0 c
RowNumber = 3
3 u' g. g1 f0 b" ~PathName = Cells(RowNumber, 1) '讀取第一個路徑的值
" r# s' V* J+ Q! g8 sWhile Not (PathName = "" Or PathName = 0 Or IsEmpty(PathName)) '直到讀完路徑欄(尋找繼續填寫的位置)1 M0 S# u$ E: t  E( |: w$ U
    RowNumber = RowNumber + 1 '下一列
9 [' Z8 M) W  L' T- S    PathName = Cells(RowNumber, 1)+ I, _" Y  J$ P" j0 F: G
Wend '回到>直到讀完路徑欄
$ l+ u' Z8 l  t% y, J* [Application.FileDialog(msoFileDialogFilePicker).AllowMultiSelect = True '設定為多選對話框) g) M* x$ P+ q
Application.FileDialog(msoFileDialogFilePicker).Filters.Clear '清除既有類型
) Y5 }2 s9 l- z' SApplication.FileDialog(msoFileDialogFilePicker).Filters.Add "零件自定义属性", "*.SLDPRT" '設定檔案類型4 o% j/ r6 o. X1 O/ G6 V
Application.FileDialog(msoFileDialogFilePicker).Filters.Add "零件配置属性", "*.SLDPRT" '設定檔案類型( U1 s% p( [2 a% N; j
Application.FileDialog(msoFileDialogFilePicker).Filters.Add "装配体自定义属性", "*.SLDASM" '設定檔案類型
( M+ U. Q; Z! TApplication.FileDialog(msoFileDialogFilePicker).Filters.Add "装配体配置属性", "*.SLDASM" '設定檔案類型
  D  d/ `1 D0 W/ l$ y* A: h8 j" kApplication.FileDialog(msoFileDialogFilePicker).Filters.Add "工程图属性", "*.SLDDRW" '設定檔案類型* f  M5 m' |; @9 i, {$ s3 i  v
If Cells(1, 1) = 1 Or Cells(1, 1) = 2 Or Cells(1, 1) = 3 Or Cells(1, 1) = 4 Or Cells(1, 1) = 5 Then. g9 F, g; C$ n& ]& r6 v
    Application.FileDialog(msoFileDialogFilePicker).FilterIndex = Cells(1, 1)
$ B) W8 u. d' ~End If
1 U8 a2 V  _  G2 W! l( p- UIf Cells(1, 2) <> "" Then Application.FileDialog(msoFileDialogFilePicker).InitialFileName = Cells(1, 2)# U; o' B8 X! e/ A4 ~
intChoice = Application.FileDialog(msoFileDialogFilePicker).Show '彈出對話框  H% k! K: y/ ?& p
5 `( I2 O$ H5 s  @, x; T& HIf intChoice <> 0 Then '判斷有否點選檔案
5 A( _: m  _! U9 B- w    RowCount = 1
# L) q. m$ C3 N# B2 B3 F; X    swFilterIndex = Application.FileDialog(msoFileDialogFilePicker).FilterIndex/ d% ?8 z2 ^0 q/ N9 U! u& s: r" c
    For i = 1 To Application.FileDialog(msoFileDialogFilePicker).SelectedItems.Count '逐一讀取所選檔案
% s" y0 C: f8 }. K8 p        FilePathName = Application.FileDialog(msoFileDialogFilePicker).SelectedItems(i) '讀取完整檔案名稱& p  g  V/ ]! m' T$ ^/ q
        FilePath = Left(FilePathName, InStrRev(FilePathName, "\")) '分解路徑, }6 l# d6 I! Y, S! |
        Filename = Right(FilePathName, Len(FilePathName) - Len(FilePath)) '分解檔案名稱
$ {% s# D8 Y9 w+ P8 D        FileExtname = UCase(Right(FilePathName, 6)) '分解檔案類型  Y$ S- e  E; K/ x
        If swFilterIndex = 1 Or swFilterIndex = 3 Or swFilterIndex = 5 Then+ K7 k) E- [" ~
            Cells(RowCount + RowNumber - 1, 1) = FilePath '填寫路徑! e" v; j9 P  p) G! X
            Cells(RowCount + RowNumber - 1, 2) = Filename '填寫檔案名稱
( _) W( F7 R0 }  Y: k; w7 r8 @            RowCount = RowCount + 1& T0 `; P. F& B( _
        End If
8 L$ r# d. Z  f8 c% \        If swFilterIndex = 2 Or swFilterIndex = 4 Then '過濾器是2或4
* @: a1 ~# z; o. B" n8 E8 o            Set swDoc = swDM.GetDocument(PathName & Filename, swFileTYpe, False, mOpenErrors) '開啟檔案
+ b# f$ T2 z4 P3 X4 Y; n- L7 O" H, P
# t5 ?' I; t- b( q3 W  X            If Not swDoc Is Nothing Then '排除無效檔案5 b; _& a8 D2 E, d
                Set swCfgMgr = swDoc.ConfigurationManager
. {; q$ j8 w* w' A8 O5 E                swConfigNames = swCfgMgr.GetConfigurationNames- T; g$ g% B- [0 X2 q4 y
                ConfigColor = 200
8 v0 i* v3 F; B, T( C  H                For Each swConfigName In swConfigNames6 d" |5 o( O1 {; {& G
" I) a+ Y2 h+ @1 l, U                    Cells(RowCount + RowNumber - 1, 2) = Filename '填寫檔案名稱
9 k  ?' ?: A0 O  t3 Q' L& i2 G* I/ K                    Cells(RowCount + RowNumber - 1, 3).NumberFormatLocal = "@" '设为“文本”格式
. N0 p$ _6 d8 }& B$ E                    Cells(RowCount + RowNumber - 1, 3) = swConfigName '填寫模型組態名稱) n, h1 j) q, ?& Y7 Q
                    Cells(RowCount + RowNumber - 1, 3).Errors.Item(xlNumberAsText).Ignore = True '去除三角错误) Y+ C0 G; Q; w0 G+ Z9 B
                    Cells(RowCount + RowNumber - 1, 3).Interior.Color = RGB(ConfigColor, ConfigColor, ConfigColor)
1 D# f% |5 e3 t$ Q8 ~) Q4 f; h2 a. {9 W  C1 J  Y' K) i( q. c# I8 p4 J. o
                    RowCount = RowCount + 16 h  _& Q0 [* I  v0 ?! V+ h
                Next
4 x- d8 N1 w* I" ^0 r                swDoc.CloseDoc '關閉檔案
1 L  a* F+ A$ w1 V/ K* r            End If '排除無效檔案<完>* E- R7 T" Z  B3 x4 \* Z" |
        End If ''過濾器是2或4<完>7 u$ X; W& A+ J; E+ o2 P& a' r
    Next i '逐一讀取所選檔案<完>
  [2 Q& H* o, }+ J8 REnd If '判斷有否點選檔案<完>  D: ], d2 q( y0 Y9 h- B0 \
End Sub
9 b. {2 W( G  F" c
9 L; \' w" H# s3 R
  J+ g" x5 a, q' e7 C3 F! u% ?6 Y6 x$ J8 o5 W7 u7 ?
上面这段代码,要怎么改才能不用启动SWDM,而是改为启动SW就可以执行呢?请高手帮我看看吧
1 Z  m6 q6 `+ g1 x: Z" [  c6 a+ U4 q3 k4 [
