2021-06-25
查看: 7225|回复: 6
[求助] creo 4.0安装出错
发表于 2017-3-28 18:51:38 | 显示全部楼层 |阅读模式 来自: 中国上海
安装
主题分类用于问题归类:
creo 4.0安装出错,开启老是出现图示画面,将需要怎么 解决?" @$ b1 U1 ^  N1 ]% B' W' N/ H. D
错误画面3
错误画面3
错误画面2
错误画面2
错误画面1
错误画面1
点评
游客
视频t.cn/RxmJTrS 海外直播t.cn/RJvOfM6 “绝不照搬西方模式”西方模式是什么?不敢说.①新闻自l由,不敢搬,因为害怕人民监督.②官h员财产公开,不敢搬,因为害怕腐w败曝光.③官l员选举产生,不敢搬,因为害怕人民不选   发表于 2017-3-29 04:23
 楼主| 发表于 2017-3-29 11:52:20 | 显示全部楼层 来自: 中国上海
有人知道咋解决吗?
发表于 2017-3-31 22:48:07 | 显示全部楼层 来自: 中国江苏苏州
1. Unzip "PTC.LICENSE.WINDOWS-SSQ.7z" to temporary directory$ _. w& M7 X4 J$ c- Q
   and run "FillLicense.bat". The "PTC_D_SSQ.dat" file near batch script & N: n6 l# U7 L4 m7 h  a/ r5 G
   contains the license file with correct PTC HOSTID will be generated% _* ?7 Z* i3 |% K7 s
' b( P9 [. `! u8 q   Copy generated license file to folder of choice (for example, C:\Program Files\PTC)9 y: x% c: Q* o( j4 g
+ X  c, c( n% X
& e! p+ J5 S2 S( m1 f. o% D$ @
2. Create enviroment variable PTC_D_LICENSE_FILE=<full path to PTC_D_SSQ.dat>  v+ H9 w6 z# M2 K+ @5 ^, d
; Z% E  a+ L. R7 r) C! Z4 S4 ]
: l! b' g+ j, _: e6 C) h3. Install PTC Creo 4.0 M010 Win640 F5 m0 \5 F) O9 q
! @$ v' E9 L/ d2 R
, q2 j3 _! W+ \/ z7 {3.1. Copy  folders "Distributed Services Manager", "M010" and "View Express" from "PTC.CREO.4.0.M010.WIN-SSQ.7z"\Creo 4.0 folder to <Creo 4.0 progdir> (by default C:\Program Files\PTC\Creo 4.0\ ) with overwrite* F% p1 n- v8 J& h- n
; O/ y; ~1 D4 r: E+ |' w
% Y, n8 `; U, ~5 N' x+ A
4. Install PTC Mathcad Prime 4.0 Win64 (optional)
8 s2 W( q8 M7 e; a* ~% ?8 @7 X, J# `9 R9 P2 e) ?2 J
- }, |3 |' N1 l) k: w4.1. Replace original <Mathcad Prime 4.0 program folder> (by default C:\Program Files\PTC\Mathcad Prime 4.0 ) with cracked one from "PTC.CREO.4.0.M010.WIN-SSQ.7z"
! n2 `9 |5 |: X& D( ^2 `3 u/ A( R$ `- Z. v7 v3 }
9 c4 c, f9 t5 Q# |) u8 V$ y( A
5. Run "SolidSQUADLoaderEnabler.reg" and confirm to add info into Windows Registry# D+ N; o9 V- q6 D! K1 q9 T# {
( w" E" y* S' N+ c, v; ^' Z; P( y3 F- q+ o$ m
6. REBOOT
" n5 T- U7 E2 i
+ L: y* ~5 t" J0 p! C5 y. J6 M
& {& O) }  `$ ]7 I' A* m7. Enjoy!
; y: t# f1 I2 z- O1 }  }/ F2 R: W0 Y% E! I- o
: F  A" R  ]: X. {; `Cracked by TeAM SolidSQUAD-SSQ
 楼主| 发表于 2017-4-2 10:31:46 | 显示全部楼层 来自: 中国上海
werfg120 发表于 2017-3-31 22:48
$ p# @% m3 E6 ^5 f4 O1. Unzip "PTC.LICENSE.WINDOWS-SSQ.7z" to temporary directory
. M7 M6 `4 ]9 ]5 c; Y   and run "FillLicense.bat". The "PTC ...
  S$ J- d5 ^0 {9 i, t
谢谢,2. Create enviroment variable PTC_D_LICENSE_FILE=<full path to PTC_D_SSQ.dat>  上面变量设置安装在E盘需要修改那些?PTC_E_LICENSE_FILE=<full path to PTC_D_SSQ.dat>
发表于 2017-4-11 21:19:21 | 显示全部楼层 来自: 中国湖南长沙
有道理
发表于 2017-4-26 12:18:29 | 显示全部楼层 来自: 中国湖南长沙
楼主按三楼的操作就可以完全解决的,而并不是将那个文件名称进行改变。
