发表于 2017-10-30 19:44:20
来自: 中国浙江宁波
0. Uninstall ANY SIEMENS SPLM License Server if one is installed:
# x+ }, s1 q9 I2 x2 A: E8 Z k9 d6 }' ~, G. s: z* @
- If the original SPLM License Server is installed, use "Programs and Features" $ Z, g+ m% z8 J- U$ W. l) z7 I
to remove it$ y& I1 Q3 T9 E/ ]* e+ p
& {' o1 S; }/ ^" k4 ` - If SSQ SPLM License Server is installed, run as Administrator the "server_remove.bat"
2 J% b Q) S9 Y9 ?9 Z+ y! p+ V from the SPLM License Server folder
& A1 V! d% V/ S7 \8 d9 }& V* t/ u4 q( ^& s
1. DO NOT install original SPLM License Server from NX-12.0.0 setup media!!!
! k4 \, m. f( C0 s+ n( a3 j# B. q7 I# ?8 v; y4 ?
2. Install or update the SolidSQUAD Universal License Server, n# p ^* L- O# I4 k
/ l$ h8 M; N! r' O% o6 c If SolidSQUAD Universal License Server has never been installed
; t# b9 L$ I9 r5 b _ on the computer:
# d! f8 U. E/ y* a
+ S& m5 {$ _$ X v4 O% d - unzip the "SolidSQUAD_License_Servers" folder from ; ]7 ~( P# L0 c: D1 p
"SSQ_UniversalLicenseServer_Core_<release-date>.zip" to any DRIVE ROOT
, o" I) u# k6 {& e+ i folder X:\ (like C:\, D:\, E:\ etc), so the path will be:
$ }8 n7 o S6 l: C5 K* c h7 e9 F9 }& |* y) U6 j6 [: N
X:\SolidSQUAD_License_Servers
) [! d8 T$ ~0 }' V; {/ s, [3 X/ ?
7 H0 D# Q& m. v& v. Z/ Y4 a - unzip the "Vendors" folder from 2 w4 U7 h7 ~+ y3 o
"SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip"
6 D) \* [$ \) N" S to the "SolidSQUAD_License_Servers" folder5 w5 X1 L1 S$ R" @4 f) _0 V
. |* E8 y2 z( L9 X+ N3 |( S
- As administrator run "install_or_update.bat" from "SolidSQUAD_License_Servers"
7 T) F; x' ]- ?0 Y o/ l2 K' r folder and wait until it completes4 e2 P3 T7 D! R7 ~+ c" l2 F
2 m7 e! _* Q w+ I" v# d2 c
-- OR --
' E9 q# U, t6 S
5 o: X, }% L. @7 d7 ]$ i# f If SolidSQUAD Universal License Server is already installed,
# ]9 t9 o7 D) w but the release-date of "SSQ_UniversalLicenseServer_Core_<release-date>.zip"# F* q, X# Q/ d
is newer than the installed one, update the server installation:
2 H2 i$ v" U9 T; ~5 B8 o! a9 B# \7 |
- As administrator run "uninstall.bat" from "SolidSQUAD_License_Servers"
% Y" U5 `" j, v" k; [! r8 p9 R folder and wait until it completes5 r9 [8 O' V3 t' K$ M7 y8 R
5 N8 v* P! Q( L6 S2 y - unzip the "SolidSQUAD_License_Servers" folder from * A& P/ [' u o; s. r
! C7 C3 g& k8 ?# y& |1 e- s7 e, x folder X:\ (like C:\, D:\, E:\ etc), so the path will be:) z8 |: e/ t7 ^) D5 ^
' z6 @3 I1 u; |6 J! J/ p; [* f
+ t" P, J2 q2 J1 x# V4 r7 |9 R& S, V( A4 a( S& u( ~: @
- Y2 X- j% {/ M" b2 F "SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip"
@( u! S; B" X# r) W* v to the "SolidSQUAD_License_Servers" folder
4 U' c! [) J( j9 F% m* C
) K7 F% t$ g6 ]4 q% V - As administrator run "install_or_update.bat" from "SolidSQUAD_License_Servers"
4 j; }9 s" q% J7 G) `/ G folder and wait until it completes
2 I, U6 L8 o5 N I- n# B' C4 P4 ~* x# r+ {; N
-- OR --( Y" z8 [7 Z( ]- W% |! G
" e" j- p# N: K, @; `0 g* O If the release-date of "SSQ_UniversalLicenseServer_Core_<release-date>.zip" is not newer4 \3 r% C. O+ f( j+ |/ p
than the installed one but the release-date of O5 A, F* s+ n I- T
"SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip" is newer than the installed one,; D, E g4 v% s! V2 L1 J
update SiemensPLM module only:3 E. k5 L5 }9 j! w
8 X) k/ U6 W8 G$ v: {( t4 }) c - unzip the "Vendors" folder from
9 Z9 b$ X: [" u3 y6 b! F6 F "SSQ_UniversalLicenseServer_Module_SiemensPLM_<release-date>.zip"
7 R9 z! h$ n* d/ W0 {4 }7 y to the "SolidSQUAD_License_Servers" folder g$ |% B2 a/ k `
6 S; H; n$ ^. x' W9 B6 G
- As administrator run "install_or_update.bat" from "SolidSQUAD_License_Servers" . _( H0 D0 [5 I5 [5 o/ {0 F
" S1 `' Q; I. r6 X# l" T& T; Z* X7 V! J0 f$ Q% |% |; ^
5. Install NX-12.0.0 Win64. At setup when asked for license server port and name input 27800@localhost' z7 b H. m8 g+ H* F' x
2 M4 |( w# V7 g7 j2 d$ ~6. Replace original <NX 12.0 program folder> (by default C:\Program Files\Siemens\NX 12.0) with cracked one; [% R5 {* i& T2 a
6 U! k' @% q0 Q
7. Reboot computer
4 W5 f- k, [9 h2 o9 T1 X) ~7 X- R0 L1 e2 i" o
8. Enjoy!2 u8 j& d2 s% k- b7 W- }3 c
0 @, W! x4 d- g3 g* }- z( f' @
