查看: 3056|回复: 3
[求助] 2017的加工报表不能用了
发表于 2017-12-6 12:35:04 | 显示全部楼层 |阅读模式 来自: 中国江苏苏州
刚装的新电脑,安装了2017后在道路栏里右击选择加工报表后弹不出来加工报表的选项对话框,直接显示什么结合后处理的提示后直接跟后处理程序一样处理出来好多代码,恳请大家帮忙解决下,谢谢大家!
1 m$ F' X( B- \( o0 }4 @; f下面是显示的信息,不会传图* _( Y2 P# `/ J. z" f
2 b1 R7 [6 a" z* I$ n9 t3 UCUSTOMIZABLE MILL SETUP SHEET - MILL.SET" k: \: o9 [; p7 L& P9 B: a
=========================================3 T, r4 g0 k# s0 m
; t- u/ H: D& R4 n+ H# u2 h" l/ kPROGRAM NAME   = OKEZI2
9 L- u% c# `# n3 P* u# k8 jDATE PROCESSED = DEC. 06 2017
6 \0 r. [- c) l+ w6 T$ Y# R1 tTIME           = 12:31 PM
9 a& V% E! W* Z* l; tMATERIAL TYPE  = ALUMINUM mm - 20242 Z( Z0 S& I8 _( }8 ~( `
STOCK SIZE     = X40.000 Y10.000 Z2.000& u- s( r% w3 B/ E* K, f
STOCK ORIGIN   = X0. Y0. Z0.(AT CENTER, Z AT TOP)
3 G# \  b. W0 DMACHINE NAME   = MILL DEFAULT MM8 F' }$ F) g" z3 [5 Y. c
GROUP NAME     = 机床群组-1
* `" I. W# a0 P
7 P& d/ \, z4 q# Z( n--------------------------------------------------------------& ~6 g' A0 G& ^. p
OPERATION TYPE = CONTOUR! B* U! ^) k5 a$ _, f7 w) K- |" ^
TOOL NAME = 4 木雕刀
: H" ?! E+ |" p" I: eTOOL NUM. = 1  ^) W/ Q5 w2 m6 X8 J. [. k7 w2 Z
TOOL DIA. = 4.0008 d( ^4 S& d+ w/ m% h) \! W1 I
NUMBER OF FLUTES = 1* m# g$ V' L! s8 H2 t
FLUTE LEN.    = 10.- S" a9 N1 @( A2 l
OVERALL LEN.  = 50.
9 g8 X$ R# K: E0 J8 CSHOULDER LEN. = 50.
) W4 _* G7 q9 o$ i6 h' [& ]ARBOR DIA.    = 4./ u! q7 ?  p4 O0 A8 Z
HOLDER DIA.   = 50.2 w! e" Y. h1 J$ Y4 Q' r- m6 M. B2 o
DIA. OFFSET = 1
' r: M2 n3 t; O9 H- JLEN. OFFSET = 1+ S+ X% e9 ]1 L& L3 D
SPINDLE = 15000
* D9 U, Y  \+ d4 S4 XFEEDRATE = 500.- C0 u* o2 v; K* b+ D/ I3 D
CUTTER COMP. = OFF$ @' n2 K9 _; n! s5 C
STOCK TO LEAVE (XY)= 0.
# G1 h0 d* j+ oSTOCK TO LEAVE (Z) = 0.
& I- w3 j# ^2 o+ E# TFEEDRATES: MAX = 1000. MIN = 500.
" m, L5 ?3 d# dMAX_X = +15.398  MIN_X = -15.711% a# n$ b" X+ \" `
MAX_Y = +1.252  MIN_Y = -2.270
3 s2 G( z% Z8 S9 x$ ]MAX_Z = +10.000  MIN_Z = -0.100
6 r: l  Q2 a& E' I: fTOOL FEED CUT LENGTH = 197.8662 s' q' G" A2 i1 t+ Q; K
TOOL RAPID TRAVERSE LENGTH = 1088.555
+ t9 G# f9 e2 S% uRAPID TIME = 5.23 SECONDS( F2 [9 w' o. E7 y' C- @
FEED TIME  = 22.23 SECONDS$ m' a% P" c2 g: r
OPERATION TIME = 27.45 SECONDS
发表于 2017-12-6 14:04:49 | 显示全部楼层 来自: 中国四川成都
帮顶一下
发表于 2017-12-6 15:49:02 | 显示全部楼层 来自: 中国山东烟台
 楼主| 发表于 2017-12-9 15:25:14 | 显示全部楼层 来自: 中国江苏苏州
路过不买 发表于 2017-12-6 15:49
% p7 l5 x( B# _2 Y4 I( Dhttp://mp.weixin.qq.com/s?__biz=MzI3Mzc1MTMwMQ==&mid=2247484200&idx=1&sn=59ab156aba32c1ea50da1661b82 ...
1 B! W/ V. b2 U4 T谢谢版大帮忙!谢谢!
