查看: 2948|回复: 5
[原创] 依據配置特定屬性之"件號"及"名稱"存檔
发表于 2018-10-31 08:40:19 | 显示全部楼层 |阅读模式 来自: 中国浙江嘉兴
安装
主题分类用于问题归类:
. @" I$ I, Q- X8 v' R9 n" Y
參考
$ b+ X$ s" e; Z+ H- R+ u9 X, t9 u2 m: P7 q6 c
: i8 F0 A- S) y; A2 X+ c9 M1 f 103001-2.gif ( O. w* t1 @/ x4 H  h& |
, k- y$ k+ a. S/ H/ O$ W3 z" b) x8 @- w$ I% x2 M2 v8 ?' b, G- z2 c
  1. ' ************************************************************************************  P% E9 r" q  u1 O
  2. ' 依據配置特定屬性之"件號"及"名稱"存檔 - macro recorded on 10/30/18 by scliang
    4 E0 ^5 A/ D5 l3 r8 j! e' p
  3. ' ************************************************************************************/ \8 {, e+ C/ [, D: `6 A; u
  4. 5 a3 y% u& q" H- I
  5.     Dim swApp               As SldWorks.SldWorks
    6 b7 t7 \2 y9 K' d& }
  6.     Dim swModel             As SldWorks.ModelDoc2
    1 P: s; |! I& w7 T. A7 x# ^
  7.     Dim swConfigMgr         As SldWorks.ConfigurationManager
    ( m( L& @5 @: h  A2 x7 z5 G% _, M
  8.     Dim swConfig            As SldWorks.Configuration1 n, c- E: i7 [. o9 p
  9.     Dim swCustPropMgr       As SldWorks.CustomPropertyManager
    % R- l% N/ I$ o9 N$ {$ _
  10.     Dim nNbrProps           As Long
      _7 \7 ]& {  ]9 v+ Q
  11.     Dim Part                As Object
    ! \+ \! s' i1 v9 |8 u1 s' {: C
  12.     Dim Code_Name(2)        As String
    * b, v1 {0 g- |8 ~+ b9 G
  13.     Dim valOut              As String5 m, j4 J# v6 K8 M
  14.     Dim resolvedValOut      As String
    ) M& u% K; X4 U+ t% z* `
  15.     Dim longstatus          As Long6 y; Y- I7 ]. m4 {$ P2 D
  16. / V; ~5 b0 ]- o2 Z* V! J9 r
  17. ) w& P- ^& u; r" z' P3 q
  18. Sub main()- C8 M" q  p3 ^! F
  19. $ u& K, l7 p# B
  20.     Set swApp = Application.SldWorks
    6 j) G3 L! ]+ f' K. |* E) \
  21.     Set swModel = swApp.ActiveDoc
    0 ?& J- Q/ _& C0 \4 E0 k1 A1 o) o0 ^0 `
  22.     Set swConfigMgr = swModel.ConfigurationManager
    + x' q  h2 d9 i0 Q8 R2 l1 K7 e
  23.     Set swConfig = swConfigMgr.ActiveConfiguration( g' ~9 T: O# c0 U; K) s
  24.     Set swCustPropMgr = swConfig.CustomPropertyManager
    . \9 N0 h9 @, l3 {" p" Z8 ]
  25.     ' Get the number of custom properties for this configuration+ `  m, M* T; |7 n
  26.     nNbrProps = swCustPropMgr.Count! y+ s! P. I, U, v/ P- v+ U
  27.     vPropNames = swCustPropMgr.GetNames
    * u4 I0 w) S9 r8 s9 e' d
  28.     For j = 0 To nNbrProps - 1
    4 c" R4 v) ?! {
  29.         swCustPropMgr.Get2 vPropNames(j), valOut, resolvedValOut
    8 B" _) l9 Q2 ~% N9 e1 q' t
  30.         If vPropNames(j) = "代號" Then Code_Name(0) = valOut
    ' y0 j7 A; a5 [5 y; ]
  31.         If vPropNames(j) = "名稱" Then Code_Name(1) = valOut
    ( ]# I  r; `7 p2 ], c
  32.     Next j3 ?& x8 D/ l: g0 k1 m1 J
  33.     'Debug.Print "    Name, type, and resolved value of custom property:  " & "代號: " & Code_Name(0) & " ----- " & "名稱:" & Code_Name(1)+ o+ |6 M3 f. h* R/ \: l4 l' o
  34.     Path_Name = swApp.ActiveDoc.GetPathName '取得"路徑名稱及擴展名",不管擴展名是否隱藏
    0 i! E: W4 N- D/ I
  35.     Path_ = Left(Path_Name, InStrRev(Path_Name, "")) '提出路徑& `9 r3 Z# R. j" t8 g1 i
  36.     Set Part = swApp.ActiveDoc
    6 ?6 b5 r0 t9 D) H7 w
  37.     longstatus = Part.SaveAs3(Path_ & Code_Name(0) & " " & Code_Name(1) & ".SLDPRT", 0, 2) '依據配置屬性"件號"及"名稱"存檔& ]4 M# P9 o* F! s3 R' e; d+ N. N
  38. 5 s) y4 G+ I- U. s) b
  39. End Sub
    # ?1 K# j8 N, W0 o9 X
复制代码
3 C% J' a' R5 g5 Y0 P/ P
9 I) Y8 E: @$ Q) F3 w1 h3 L9 h! _1 A  L0 o0 x# @8 W% u% N' r
阿帕奇 + 3
发表于 2018-10-31 10:39:09 | 显示全部楼层 来自: 中国山东济宁
感谢分享
+ \$ }6 G# g) m8 }7 y* a/ u& S% K1 w$ C: p
感谢分享。     三维网粘贴的代码里面老是多出一些乱码,几年了论坛的坛主就一直视而不见
点评
那是对山寨网防范的办法之一  详情 回复 发表于 2018-10-31 13:58
試了,已有改善!  发表于 2018-10-31 10:48
发表于 2018-10-31 13:58:14 | 显示全部楼层 来自: 中国辽宁盘锦
xiatian11 发表于 2018-10-31 10:39
2 S# k$ J0 V  j2 N" \感谢分享。     三维网粘贴的代码里面老是多出一些乱码,几年了论坛的坛主就一直视而不见
6 k9 M" a. Y* c2 F% y5 J3 }  _那是对山寨网防范的办法之一
发表于 2018-10-31 13:58:41 | 显示全部楼层 来自: 中国辽宁盘锦
一直都视而见
发表于 2018-12-12 22:10:29 | 显示全部楼层 来自: 中国广东佛山
谢谢楼主。好东东,值得分享。
