发表于 2018-11-1 11:43:43
来自: 中国陕西西安
- This example shows how to rename a component and update its references.3 b0 ]1 M/ w& O6 y1 X
- ) v3 y( F! _+ O& T2 ~
- '----------------------------------------------------------------------' p7 G/ {* J/ ^8 @, l1 h; G
- ' Preconditions:
3 B) m( @1 W# h* ^: F7 o - ' 1. Copy and paste Main into your project.: Q0 ^ U1 g4 ^' l
- ' 2. Insert a class module and copy and paste Class1 into that module.( t2 e' v* r5 v; q; X
- ' 3. Copy public_documents\samples\tutorial\EDraw\claw to c:\test\claw.
; a9 q. L7 s1 `: O& P- a - ' 4. Open c:\test\claw\claw-mechanism.sldasm and save the file as
: g3 `4 g7 `" i& C1 C6 V% _ - ' claw-mechanism-copy.sldasm., X- ~' P" w) z' B; D
- ' 5. Close claw-mechanism-copy.sldasm and reopen claw-mechanism.sldasm.
1 f8 G; r- `) j) ` - ' 6. Open the Immediate window.* o; c2 X5 G$ ^+ q P s, C
- '8 B/ |0 Y5 x& \3 ]
- ' Postconditions:
/ L" x, S+ x$ S& Y - ' 1. Renames the center component to centerXXX.0 u) J8 }& |8 t& H* U1 S, M
- ' 2. Fires the RenameItemNotify event.. D8 o9 Z/ h3 Y; p
- ' 3. Saves the assembly.
m# v, v6 o* \$ | - ' 4. Fires the RenamedDocumentNotify event.$ F& r p. @- g1 E: A) v
- ' 5. Updates references.4 K- `( A, p. G. |' a) x
- ' 6. Examine the FeatureManager design tree and Immediate window.
) z8 k2 U9 t1 v" u( f* n8 U+ L7 v - ' 7. Close claw-mechanism.sldasm and open+ Z R+ X! t. a+ g
- ' c:\test\claw\claw-mechanism-copy.sldasm to verify that the/ D0 S% R+ t/ l/ _" d
- ' center component was renamed to centerXXX.
! f7 A, ?. R% r+ p7 R3 \ - '---------------------------------------------------------------------
. D+ w- [2 D8 A; x - 'Main
% O, l* ]- m% g - Option Explicit
, k- g3 b3 u$ n) o K: U9 S - Dim swApp As SldWorks.SldWorks
1 X m# N% O/ ~) j - Dim swModel As SldWorks.ModelDoc26 X% t5 d4 M5 e& X3 a
- Dim swModelDocExt As SldWorks.ModelDocExtension
2 D5 K* ]6 ^4 ~# {$ C - Dim swAssy As SldWorks.AssemblyDoc7 \8 K, x/ v' m8 Y
- Dim swAssyEvents As Class1
* J: E5 _7 ^0 K - Dim errors As Long
, J4 i6 ?: m8 i: w3 I1 t - Dim warnings As Long- N) a& Y* ^; n$ D
- Dim status As Boolean: L R( f h3 C, m5 f; `. ?: I
- Sub main()4 Z' ^) C# Z- D$ A3 f
- Set swApp = Application.SldWorks
7 Q& a; W$ ` O - Set swAssy = swApp.ActiveDoc
* Q3 ]4 `, @# _ - 'Set up event
~" I: w0 g2 @7 q0 n" L+ c. M - Set swAssyEvents = New Class1
0 x+ y6 ?6 ?4 n* v# n - Set swAssyEvents.swAssy = swApp.ActiveDoc
# g7 ~* z# L1 @$ c7 G - Set swModel = swAssy3 `: h5 N$ V+ }% f& r2 X
- Set swModelDocExt = swModel.Extension
) O) N/ x: T3 K7 ]- m, m - status = swModelDocExt.SelectByID2("center-1@claw-mechanism", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
( J* @" u. f' [; i$ t1 g5 o - errors = swModelDocExt.RenameDocument("centerXXX")
) t: |8 V: l" {# Z2 Z5 i* V5 j - swModelDocExt.Rebuild swRebuildOptions_e.swRebuildAll* n: Q( f& N3 C0 a$ ^7 D
- status = swModel.Save3(swSaveAsOptions_e.swSaveAsOptions_Silent + swSaveAsOptions_e.swSaveAsOptions_SaveReferenced, errors, warnings)
! ~ v/ y% z4 ^' m& ^ - End Sub( N ]5 I8 N; ^
4 h# X- z4 h( N7 ], f9 k& D - 'Class1
4 L+ E4 h* i5 _$ a; V- O - Option Explicit
% F' B2 Q" C, G - ; ]4 z/ ]9 p" [! [: ]# B+ R
- Public WithEvents swAssy As SldWorks.AssemblyDoc
" B. ~7 w# ^7 q7 k# Q - ' a) ~* u' l8 H% S3 A3 O9 H
. F, r, G/ l4 l3 R- 'Fire notification when item is renamed) {$ ?# j7 D2 B3 s: z* x' S8 e
- Public Function swAssy_RenameItemNotify(ByVal entType As Long, ByVal oldName As String, ByVal newName As String) As Long% O% S3 |4 L" d
- Debug.Print "RenameItemNotify fired"0 D2 e' [0 M4 |. S* S
- End Function
8 B8 n' R& q" W% {8 S
3 r* d# I8 B* E6 o$ @. r; p- ! e4 z0 J7 z5 f& h* `4 F
- 'Fire notification for Rename Documents dialog
% x( o7 o' k% ?' G- I* o! M5 U - Public Function swAssy_RenamedDocumentNotify(ByRef swObj As Object) As Long
2 M" k) r; x5 [0 A$ \. V0 S' y# R - Dim swRenamedDocumentReferences As SldWorks.RenamedDocumentReferences
2 D9 Z) X+ h4 B T1 M - Dim searchPaths As Variant) _8 M' P3 I+ E. ^ T
- Dim pathNames As Variant, b7 E" ]) d5 h/ }7 F
- Dim i As Long
0 B: J# c5 y. g - Dim nbr As Long
4 B. X2 ?* {3 i% Q/ U; W, ^
+ P# Y) ?8 o1 V- Set swRenamedDocumentReferences = swObj
6 A( w# _% U0 _) O8 K
1 _0 f9 \1 L4 _# s% v$ E- swRenamedDocumentReferences.UpdateWhereUsedReferences = True. P. t7 [( [! G; v% A$ i/ e
- swRenamedDocumentReferences.IncludeFileLocations = True$ |: T6 |% k# G3 j' \) N7 K
( k X/ Q- b6 V# `6 |# n! T3 ^- searchPaths = swRenamedDocumentReferences.GetSearchPath
% b; S- L+ T7 a4 ?( m, \3 D - nbr = UBound(searchPaths) D4 @" N2 `5 ]% a: K5 ^+ d! K8 p
- Debug.Print "Search paths:"1 S: y$ ]- o S3 s
- For i = 0 To nbr
5 F. r; @! y \+ ?8 c - Debug.Print (" " & searchPaths(i))0 i" j7 k) U' l0 E1 C
- Next i
$ c m, b8 F6 z' D; S/ w
' t! v! W1 X9 L# Q6 D- swRenamedDocumentReferences.Search Y0 a+ l# R+ s0 _5 E8 [& P
+ g7 h, X# O) ~; W; ]+ E2 [# r- u- pathNames = swRenamedDocumentReferences.ReferencesArray
. H2 X. g' f% H7 V/ R5 M r8 U - nbr = UBound(pathNames)
* L* T$ M7 f$ K- W0 T$ {3 @! ]5 i - Debug.Print "References:"
- W* L7 w9 H0 a7 | - For i = 0 To nbr% y# b3 I' ` |
- Debug.Print (" " & pathNames(i))6 N& G# T' o# A5 K
- Next i) N' X* d6 {; Q. v- i
- + e/ Y9 x0 p% m6 q" d( C
- swRenamedDocumentReferences.CompletionAction = swRenamedDocumentFinalAction_e.swRenamedDocumentFinalAction_Ok- \( ]% V C: z
( e# V, E6 y# q, U0 V6 W- Debug.Print "RenamedDocumentNotify fired"
+ ?! c: q- v. j. u8 X - ; h3 r9 s3 w9 Z
- End Function9 w2 q! [$ O4 d# {
复制代码 3 ~6 T: u5 ?' e$ E3 `8 p
* ?0 s) Z- b$ g+ f; p8 V
3 }$ N; Q0 S/ {8 O: g( t+ \ |
