发表于 2018-11-2 09:26:51
来自: 中国陕西西安
看看这一段程序
& m6 R, p6 p1 |, w6 S- $ A0 d" `/ u/ i% j/ @
- '----------------------------????BOM?????--------------------------5 {2 v0 P2 B% w
2 e* d( w6 m2 T; ?" f! ?- t- Private Function TableToExcel(ByVal part As ModelDoc2, _
& {: s9 `( P6 l D" B - ByVal inExcelName As String) As Boolean
# @: f4 g6 l n7 n( H# X - % D- S6 O( A7 F' J! O3 S$ o
- Dim exCOUNT As Integer& b' e8 q$ ]2 O# y) A0 U
- Dim swBomFeat As SldWorks.BomFeature2 f M7 o9 w; e9 p! _! x
- Dim vTableArr As Variant5 Z0 p& g' t8 s1 ]6 H7 T
- Dim vTable As Variant
7 c( `3 P2 K6 e4 K9 Y# L3 r( L7 @8 p - Dim swTable As Variant0 z( R0 `# `; t* i' {
- Dim swFeat As SldWorks.feature3 Y5 w/ n7 `' S" Q x, Q
- Dim swWeldmentCutListFeat As SldWorks.WeldmentCutListFeature" L" L# f. C2 H* S$ ]( C' W+ o
- Dim vWeldCutListAnnotations As Variant
" q. b; W* x( ~4 F& @3 S - Dim WeldForI As Integer4 p4 M) t6 K7 }, P0 k. A
- Dim WeldForJ As Integer
2 `' n: a! z) K8 v/ L, S, W, [. l - Dim a1 As Integer
5 D8 z) L0 ]. F, \6 ]( ?) K - Dim a2 As Integer3 [& d p j1 X6 _0 l- P
- Dim s As String
8 o; Y0 P0 @2 ?* Y+ T - Dim s1 As String
! l" U1 s1 b' u - Dim s2 As String6 t0 j8 V% [' @- ?
- Dim f1 As Single
# p% p) h' A( S5 Q8 e9 x/ w - Dim f2 As Single5 i! Q" ~2 W# U4 v! `
- Dim ExcelName As String
4 w" D) ~ z3 @, r8 ~1 }0 C r - Dim textName As String
3 O: O6 I7 H7 F3 j1 ?9 X& P - Dim oRes As New ADODB.Recordset
I5 Y: Z& k! } - Dim oConn As New ADODB.Connection
# |+ r- N" P4 i6 \0 z% e - Dim myTable() As String
: @9 N& x, m: k7 G7 q" b5 E) S0 _ - Dim bTableIn As Boolean '??????д??2 S4 F" ^. D% }/ a' [2 e
- Dim c1 As String '????????
+ g8 n" Q/ T+ t* y4 S% P - Dim SQLstr As String '??????SQL????) t' [6 Y9 y1 a; B5 F& H
- " d8 A6 `2 C0 A9 O8 X+ |1 M5 U( [/ p
- ; @, O( M, M6 A
- On Error GoTo ToExcelErr
, T" h5 B, v, F4 V# D# h2 @) U+ ]7 T - bTableIn = False
4 P+ k- C/ H d+ R& X" e - ExcelName = inExcelName + ".xls"
4 C" W( O8 H9 X - Set swFeat = part.FirstFeature
3 q4 O6 H7 q3 q5 ~5 u5 i - Do While Not swFeat Is Nothing, r! o' j% `" w6 B2 F2 _
- If swFeat.GetTypeName = "BomFeat" Then
! [. D+ y7 Q, m' }2 z - '--------------- ????????????----------
$ v( z; u5 c# a7 R/ B - Set swBomFeat = swFeat.GetSpecificFeature2
9 N: U; b& w5 y - vTableArr = swBomFeat.GetTableAnnotations
. l: e$ e% x1 k. c1 {) L - For Each vTable In vTableArr
+ t% X! z7 _* S. R" m. ]; j9 F - Set swTable = vTable
}- w# {! @ I. s - exCOUNT = swTable.RowCount - 2
6 g J+ \3 `% _& V9 f9 F" g - bTableIn = True
7 s6 m, n+ W2 {6 Z G - ReDim myTable(0 To exCOUNT, 0 To 8) As String '????????2 S8 X" p" T; O s
- For a1 = 0 To exCOUNT% Y* d) H( u% {* _5 }' v
- For a2 = 0 To swTable.ColumnCount
- j" O( M4 d2 h$ ~3 b - If IsNull(swTable.text(a1, a2)) Then! I, z( N* A7 p+ U& q8 s- N0 W+ d: x
- s = " "
z3 \ h- Y' J0 Q - Else( L9 g K9 S- }
- s = swTable.text(a1, a2)/ s% {) u5 \: _4 c9 ~4 V
- 'If Len(s) = 0 Then s = " "1 R: p8 f3 b6 T) Y& ]
- End If& f$ s- [# a1 _' r
- myTable(a1, a2) = s
; y3 d& X6 E, w/ O8 g - Next a2
1 H/ c& H$ P, {& }/ X - Next a15 R& q! p2 T9 }2 D$ Q, P. `
- Next vTable- R! U' L' f7 H
- End If0 w" p1 b4 J! q$ e
3 D1 X, M, S" i% N5 U - If swFeat.GetTypeName = "WeldmentTableFeat" Then6 H+ p# F6 h+ [& g6 `: C! M
- '-----------------?????и?????????-----------0 c1 s+ N# y6 q! K! C$ O/ m
- Set swWeldmentCutListFeat = swFeat.GetSpecificFeature2* Z% A1 N& i2 r, w. Q; f
- vWeldCutListAnnotations = swWeldmentCutListFeat.GetTableAnnotations
2 V% m& G3 z H* Y; ?& w - WeldForJ = vWeldCutListAnnotations(0).ColumnCount - 1
9 G3 x Q9 T0 F* c) y' v6 X0 t - exCOUNT = vWeldCutListAnnotations(0).RowCount - 2
8 Q2 Y( E) c8 `; R0 M9 E, g$ [% d - bTableIn = True
5 F6 f0 d, W: l, L7 r& m - ReDim myTable(0 To exCOUNT, 0 To 8) As String
+ M# H6 z" E0 @, X v& f | - For a1 = 0 To exCOUNT
* f9 h0 R, R) Z2 z2 X+ b5 W - For a2 = 0 To WeldForJ" [3 s& ?2 `% v4 f; G8 Y: r8 g. o |
- If IsNull(vWeldCutListAnnotations(0).text(a1, a2)) Then
! T/ V7 [5 L: Q0 D o5 }3 k1 | - s = " "
! ^2 y! R. g$ ]6 Z- T7 l; n8 ~ - Else
+ a' r5 P9 p4 _, q& U2 h - s = vWeldCutListAnnotations(0).text(a1, a2)
/ \' X0 h- ?+ u3 t - 'If Len(s) = 0 Then s = " "9 f9 Q+ @. q$ c9 C1 ~
- End If5 ]8 s# V4 l3 t# T0 n2 D
* a8 u* j" P. f( J# P( i: ` - Next a2) R5 K. [# B& I0 D/ `1 V
- Next a1
& n: _% [& \" c7 t3 { -
" Y& o; ^+ Z) M% {2 c - '????????????????????????????????(?????????????)???,???????????????????
# A; `5 g9 o0 o9 b5 [, `9 ?7 @" o - For a1 = 0 To exCOUNT
; X3 r) q8 e: Y& }: x* P - s = myTable(a1, 6)
1 c3 u0 M k I- I/ f/ I: B - s1 = myTable(a1, 7)9 n. C; R' T9 |# d2 k+ k( y
- If Len(Trim(s)) > 0 Then/ Q3 @6 t: @8 ?! D5 a' k1 {1 _
- If Len(Trim(s1)) = 0 Then
3 W1 F; m6 b& C& i - myTable(a1, 7) = "L=" & s
1 Q6 b# R) y! b/ H- W/ n1 ] - Else/ O: W$ y5 ?' d9 g! ?+ N" H7 E
- myTable(a1, 4) = myTable(a1, 5) + " L=" + s) i2 E' v5 w! F7 O/ u( i8 e
- End If
$ B0 O/ N; _9 |3 @+ L, [; R5 M - End If
5 e c a, B7 O6 k3 J i& |, { - Next a1- z7 ]2 S) H5 {1 d8 s
- # c4 {/ {* y, {, t, A& o3 d
- End If
3 h6 h. k# Q8 ]+ F7 u1 _( j - Set swFeat = swFeat.GetNextFeature% Z& o! @9 B& ~, F& l3 \
- Loop1 s, r* x: E) P! c, O/ m
- 3 Y6 l. ^4 |, I1 j( r
- If bTableIn Then '??????????????????????excel???& B! V: }6 B5 C w9 r. n
- For a1 = 0 To exCOUNT '????????[3] X [5]?????7 l9 G2 p- {2 g- e6 S. u
- s = myTable(a1, 3)1 Q2 l3 D" n8 V4 i8 Z b. D
- s1 = myTable(a1, 5)' }. i5 k6 u4 u; A+ v
- If Len(Trim(s)) > 0 Then2 Z% `. t1 K1 e- p6 k) T6 Z
- f1 = CSng(s)
5 @- q1 _2 J" H - Else
2 d" r4 _% l4 l g! a' \$ a! b0 w - f1 = 0( x P- K! J* ~" k3 w
- End If" M+ ~. G2 T( A* H/ p
- If Len(Trim(s1)) > 0 Then
9 l7 v Z$ y9 h& U( `0 ^ - f2 = CSng(s1)
4 j( P \% I R* q - Else
4 F) j2 J3 L! q2 s' x# q8 X6 ~9 x) s - f2 = 0
* a4 N$ c7 w( l0 R - End If
* Z. v: l# D+ y/ f X - myTable(a1, 6) = Format(f1 * f2, "##0.00")3 J7 i8 ?* o- v( F
- Next a1# ?1 t/ U; c3 T
- DeleteFile ExcelName '??????·???е?????????????; f( u* ~2 O5 _( K
- oConn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & ExcelName & ";Extended Properties=""Excel 8.0;"""
4 j0 @2 F9 q0 ~2 W9 A - oRes.Open "CREATE TABLE a (IndexID TEXT,PCPNO TEXT,PCPName TEXT,Amount TEXT,MaterialName TEXT,Weight TEXT,Tweight TEXT,Remark TEXT,Source TEXT)", oConn, adOpenStatic
$ F$ r* I/ T# K9 E9 `& x: b- q6 S -
" C3 ^+ a: k5 t% p/ ~) B - For a1 = exCOUNT To 0 Step -1
% Z: p# L# Q; |* M - s = "IndexID,PCPNO,PCPName,Amount,MaterialName,Weight,Tweight,Remark"5 R4 d. E2 B. y" e4 q# m
- s2 = ""
2 h0 u. c1 R, }3 A - c1 = """"0 R- y4 c3 Q( @+ Z. \% Y) n
- For a2 = 0 To 7
3 {5 I/ t8 X3 \! C" H) q" ] - myTable(a1, a2) = c1 & myTable(a1, a2) & c1
0 Q4 Y+ P7 N% I+ {& P% h - s2 = s2 & myTable(a1, a2) & "," '???????????????) d5 l8 ~" u) s `% C
- Next a2
- O0 a* ^, Y2 k - s2 = Left(s2, Len(s2) - 1)
! L$ s+ F8 z, C* O - SQLstr = "INSERT INTO a (" & s & ") VALUES (" & s2 & ")"
1 i9 E% C+ A& _ - oRes.Open SQLstr, oConn, adOpenStatic
* k3 C2 g9 B- Z' f9 ~ - Next a1
% Z+ R3 A4 y; S- o: j - oConn.Close
! |" ~, Z+ s, l; _2 m. v - End If
: h E( ]- _) _- i6 [ - + {, f' _' i8 C2 ]( g3 L
. }: X7 \ t- D3 W& ?, x - TableToExcel = True
; N8 |# Z9 X1 Z3 O - Exit Function3 s: Y4 ~- b! Q" b8 a
- ToExcelErr:. v" N" `, M; \8 {. @: R$ p
- TableToExcel = False
# Z2 o8 m! ^' p8 L" a. s - ' j4 {/ ^0 P* @1 r' c* N% x% Y' `
- End Function
复制代码
9 L" Y7 Q8 x) q3 L) r- o3 h* {! J3 |4 {; s1 V+ l
) W4 m k) \7 v# _+ c6 l- Z |
