楼主 |
发表于 2018-11-17 09:37:13
来自: 中国江苏无锡
fklmn 发表于 2018-11-16 16:283 A4 N2 N; B: c2 }0 F4 {4 C
Dim ConfigName As String$ G: ]: e2 X5 h
ConfigName = Part.ConfigurationManager.ActiveConfiguration.Name
" c8 b! C: W7 Z" u感谢您的回复,我只会很简单的宏操作。我改的下面的宏没有用,能否帮我改下?非常感谢 d: m* |. k; S& W
* v; z g- }8 q4 s1 [, w* X$ Q
' ******************************************************************************9 v2 m% ~+ J6 c
' C:\Users\admin\AppData\Local\Temp\swx3312\Macro1.swb - macro recorded on 11/16/18 by arter
2 b! P* | M' U6 y: S, u, ~' ******************************************************************************
: S. y- F, U/ B& n8 p# A0 NDim swApp As Object
2 P, I/ C( P; ~1 K# s ?2 x1 y' u6 f/ C
Dim Part As Object
5 p; S% O2 m7 K, n! _Dim boolstatus As Boolean
1 D/ Q% u' x) y( H! |Dim longstatus As Long, longwarnings As Long
& X9 G. W, h0 lDim ConfigName As String
0 @9 c4 K! I$ ]1 d" w1 b ConfigName = Part.ConfigurationManager.ActiveConfiguration.Name: p; A5 k; w% ~* J$ G
/ e5 }; R/ @% F1 \Sub main()# H9 k+ k' |3 u7 H! s3 R( ?$ j; t
$ T! @. P" _" j7 G. J) O8 FSet swApp = Application.SldWorks
0 V4 [4 m9 y3 E) A, V" ]- N" |$ U7 d( t3 t& F6 c- F, I& T( B
Set Part = swApp.ActiveDoc
) u; O4 t }' K6 U4 S- nboolstatus = Part.Extension.SelectByID2("δ֪", "BROWSERITEM", 0, 0, 0, False, 0, Nothing, 0)
( `- {. h: @4 A+ ~( F w9 zPart.ClearSelection2 True
- Y: H- j- T/ e# A+ j4 f) B/ e' mPart.SetMaterialPropertyName2 "default", "C:/Program Files/SOLIDWORKS Corp/SOLIDWORKS/lang/chinese-simplified/sldmaterials/COSMOS materials.sldmat", "201"( L. l8 w9 h0 j7 C& m; z5 S4 Q5 m
8 i" o4 F; o" S4 i! i) LEnd Sub8 l- B( b# g6 l. ]7 q
