发表于 2019-12-8 22:50:36
来自: 中国吉林
以默认MPLFAN为例,搜索 ' R0 a* u3 \" v% o2 K2 L
psgcode #Output the Gcode based on the current plane
& `2 @3 D2 V/ E5 o找到代码
; v* e7 d' u( p2 M" ?) l, hpsgcode #Output the Gcode based on the current plane
- Q1 B3 e9 G% Z" y if c_ax_flp,
5 T1 o8 w3 H5 y. P6 \ [
3 H6 T" D) p& B3 P) { #Reverse arc direction for c_axis flip4 g0 N! c |, S% L" K3 \6 u$ f/ I
if gcode$ = two | gcode$ = three,
" s" M7 n& ~/ Q* a( | }4 G [
8 ?6 d6 N3 B k sav_gcode = gcode$# {/ a$ V, d" \) g: P+ W
gcode$ = (5 - gcode$) #G02->G03 or G03->G02
# T+ ^" I3 o% d5 Q5 U, Y. H ]
$ ]5 G6 u h4 I" W1 ~ ]
: B. Q, _6 [4 P: x8 X$ Q if plane$ = zero, `sgcode
# L- O- Q4 `& w/ E i if plane$ = one, `sgcode1
1 `. {3 _; z7 d: _% R if plane$ = two, `sgcode2
) o$ G$ w+ y, ~+ [, z if c_ax_flp, gcode$ = sav_gcode O; g3 J2 D9 g- S1 I8 `# f. s
! h$ U( A9 D5 z+ E! g
加点作料改为, K, \, ?- M% L2 h3 t( V/ T
4 _, b+ y; ]. B! |+ s if c_ax_flp,. m7 _5 O/ o7 g* i: ?
* P) V- [2 u2 h# K #Reverse arc direction for c_axis flip0 ~. ?0 x$ Y4 b& d
if gcode$ = two | gcode$ = three,: g. N3 j9 y/ E- S
[: {9 Q- a. ~' R# @" B" h2 D8 L
sav_gcode = gcode$% K! ~* q- J8 c4 u/ `$ m. u4 C
gcode$ = (5 - gcode$) #G02->G03 or G03->G026 K+ C2 W0 C5 w1 F$ t* Y# H
]1 H! h$ S" B$ n9 ~; B
8 L& T) U+ _6 E if gcode$ = 2 | gcode$ = 3, result = force(gcode$)2 g$ ]; ~6 e! ~& ~: a P
if plane$ = zero, `sgcode7 d+ p1 F" Q O1 r: @
if plane$ = one, `sgcode1) \( k. f9 g L; x
if plane$ = two, `sgcode24 P- O) L# h' N; E+ X1 H* [/ n
if c_ax_flp, gcode$ = sav_gcode* ?' I" k! S R1 A1 p- g: a/ c7 q9 v
保存 完事 |
