楼主 |
发表于 2019-12-13 16:46:23
来自: 中国天津
明暗图渲染存在于CAXA的另一工程图环境中,默认为隐藏状态,如果希望打开,可以使用以下方法:
& H% E( k0 H0 ?2 Z6 L- T/ P9 d首先在安装路径下下D:\CAXA\CAXA IRONCAD\2011\Config找到文件IronCAD.config,注意属性只读勾选再修改/ X& }7 S9 r' N6 D: X9 m/ @% \
1 b8 _% x" }6 d6 _/ s; g Y Comments:
3 M0 u" F5 z3 Z/ U4 A8 { This file is used to configure IronCAD run time info.
, C9 r. n4 }. W# M! e X ` PreDefined Variable:
3 K! d5 q2 z, B4 Q0 l! W9 f; @ {INSTALLDIR}: the directory where the whole application installed( y. W5 ?0 v0 e: |5 k
{APPDIR}: the directory where the application executable file installed
7 d- v. s1 n: T7 J-->* O. g& w. [- [
<IronCAD Version ="12.0">
0 \; A$ Z& j% P! R) `; q4 z7 r <Configuration>
7 v2 c. _' D/ n1 H/ o8 D <Global>
; r! e/ a1 d) ]9 j. T! H. M7 v/ y <!-- the DocTemplate section contains all the external document template declare -->$ f+ S6 |! [. F1 N& w: ^
<DocTemplate>: T7 I: p" i" I! B+ @* Z X% P
<Add Name="TechDrawing" Entry="{APPDIR}3iISTD.DLL" ModuleDir="{APPDIR}" Enable="False" />
3 x* N s7 {9 {* w% z <Add Name="NEB" Entry="{APPDIR}3iISNEB.DLL" ModuleDir="{APPDIR}CAXADraft\bin\" Enable="True" />+ j- r' N- m5 r, s; h7 s [
</DocTemplate>
' r" p" W' P- ~ b* M3 p </Global>
G) i6 |% N% H: X$ o <!-- the NewUserSetting contains all the default setting for new user -->
3 L) h8 _. Y7 P4 y& W <NewUserSetting>
: y+ a/ E2 M& C; q9 M4 O ) X3 G% e, E; V, t6 B
</NewUserSetting>
6 w0 Y0 n( d# j+ m3 f </Configuration>
/ x9 s1 L) V2 O" p; X1 ~" ]: _( {</IronCAD>
, }' A R+ F2 ?$ `' y红色部分False改成True,再打开就有了' z% f, ?& A- o# `. {, Z& }+ Y2 _
