楼主 |
发表于 2022-1-6 18:57:10
来自: 中国
# General Output Settings5 E R' h/ U! P& ~8 |' W" D
# --------------------------------------------------------------------------) m6 B. c& \2 W& j# ~& I& v6 j/ q
maxfeedpm : 500 #SET_BY_MD Limit for feed in inch/min
' Z3 W, j3 l1 f3 e6 s9 Ultol_m : 0.05 #Length tolerance for arccheck, metric
, Q2 W3 Q" t9 M6 T7 S$ Gvtol_m : 0.0025#System tolerance, metric3 _3 S8 `0 D8 C1 ` i' T, |8 ^
maxfeedpm_m : 10000 #SET_BY_MD Limit for feed in mm/min% t. g( x3 {9 Z8 O4 d# X2 ?
force_wcs : yes$ #Force WCS output at every toolchange?
6 w: r/ O7 n0 _% Qstagetool : 1 #SET_BY_CD 0 = Do not pre-stage tools, 1 = Stage tools
; D' U2 _. N$ T1 tstagetltype : 1 #0 = Do not stage 1st tool
$ d& F0 `8 c( H #1 = Stage 1st tool at last tool change
$ `( ^ h% j- C. p+ O #2 = Stage 1st tool at end of file (peof)& ?* B4 S+ s$ K
use_gear : 0 #Output gear selection code, 0=no, 1=yes% s% S! B8 C! I3 Y# E) R
min_speed : 50 #SET_BY_MD Minimum spindle speed
) |3 \, c, {6 q1 Jprogname$ : 1 #Use uppercase for program name (sprogname)
! o6 A5 _4 _- {4 pprog_stop : 1 #Program stop at toolchange: 0=None, 1=M01, 2 = M00
: p) ^4 W) r; |$ h/ btool_info : 3 #Output tooltable information?
8 z L' }. l. K6 i6 G) y #0 = Off - Do not output any tool comments or tooltable |
