楼主 |
发表于 2022-1-26 19:21:00
来自: 中国江苏无锡
这个是SW2016的版本的宏,就差一步就成功了,就是如何从被选的零部件获得文件名。
3 \; b! j @9 l- W* s9 O+ GDim swApp As Object0 k5 x, A9 n0 v3 z
Dim Part As Object
# |7 ~; J" l" s Q U- bDim boolstatus As Boolean, }+ N3 o' Y% Y# F! h, }2 q
Dim longstatus As Long, longwarnings As Long
* w8 l7 p4 X7 j. K/ ^0 iDim Filename As String' Z7 `, t: F6 B+ B- [
Dim No As Integer$ m# Y4 u; G+ M1 w; k: P3 B
Dim Title As String T: W* p+ |! Q3 E" U* ^, f
% n; M8 _! C" \7 E7 ^. \6 H: ^, b
; m) G) W& D! a# y+ g9 S- e/ E
Sub main() y: ]' e. G* E) m" M7 O
+ R, f: j& }/ `) \% K
Set swApp = Application.SldWorks
4 _1 a# q( c9 B. n3 bSet Part = swApp.ActiveDoc/ P, f' O. G1 [8 [
boolstatus = Part.Extension.SelectByID2("Part", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
' b" I, Z, v1 m# p8 aSet Part = Part.Extension.SelectByID2("Part", "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)/ ]) J- d) Q* {1 ]$ A! o7 r f5 F
Filename = Part.GetPathName()8 ]! o& F5 q+ Q( M' F2 M
No = Len(Filename)
. Z0 D1 ]9 U; nFilename = Left(Filename, No - 7)
, x# Z. i/ r! d& B8 ?# y
% H) n+ z3 L' `8 l! C* @3 G- }4 USet Part = swApp.OpenDoc6(Filename & ".SLDDRW", 3, 0, "", longstatus, longwarnings)
) p: @% _9 _! @Set Part = swApp.ActiveDoc4 n; z$ |, k; C/ x, b+ D1 e
Dim myModelView As Object" }+ X0 k( S( g
Set myModelView = Part.ActiveView5 X: n0 o' _0 X" L6 o
myModelView.FrameLeft = 00 t( W A" h! o; i9 K
myModelView.FrameTop = 0) t# y% C9 R! S# T) `: l( v
Set myModelView = Part.ActiveView, y5 S6 h- w7 Q( ?
myModelView.FrameState = swWindowState_e.swWindowMaximized% S& G8 _" I, i4 x
- a4 e* T6 J8 DSet myModelView = Part.ActiveView& z/ S9 `2 A! R- D- O9 ^, T
myModelView.FrameState = swWindowState_e.swWindowMaximized5 w0 E' T8 \* U, w
End Sub- u+ X$ C e" s2 o5 Y4 u/ V
