楼主 |
发表于 2022-9-19 19:43:25
来自: 中国陕西西安
Microsoft Installer (MSI) Maintenance Pack
3 i6 c4 K; m+ j' U' f
$ o9 O, p& Z, R6 u- |; USolid Edge 2022 (V222)& h8 ]" r+ r, f* u# J
Version: 222.00.09.06
* c" P3 D9 H1 N5 I& ]3 d, B/ ~+ ^& s
+ c4 M( \' t' e! T/ v/ x5 A9 k& Z=======================3 _3 G: f! O! @/ Z* y
Maintenance Pack Policy. Y2 P4 v% Q3 r% P0 m2 o. c0 A! y6 |
7 L6 D) A9 I: u# Y9 p6 P" ^Mainstream Support - 15 months of Maintenance Pack fixes/ |! A9 C4 }+ X' g/ D. V8 v, n
Extended Support - Plus 6 months for select critical Maintenance Pack fixes, if needed
" z) A0 ~- {. X7 [' a6 c6 Z$ G+ y% ?+ \/ d4 y- e( i
Release Release Date 15 months Plus 6 months
" h7 m" B# j6 Y; mSolid Edge 2020 JUL-2019 DEC-2020 JUN-2021
) z0 N+ W+ V9 n4 fSolid Edge 2021 JUL-2020 DEC-2021 JUN-2022" G# f! F$ l P' I7 c/ M
Solid Edge 2022 OCT-2021 JAN-2023 JUL-2023- |3 I- \8 {( ?- u
Solid Edge 2023 OCT-2022 JAN-2024 JUL-20243 T9 {8 U+ R* z5 ]" S6 D* |
/ x" D( w" c, n' W' U x$ j7 O===============
3 a/ L. k- C$ o) L6 V9 ~OSS SOURCE CODE. Y' B% Q# q1 x( X* x* T' \
! M7 z7 i7 \' R8 p- kWhere there is a license obligation to provide you with source code you can apply in writing to;
4 t, P @! T8 {9 S" r, k: @ Siemens Legal (LC TE SL) - s7 L7 ~ k- b4 X" @% B
Werner-von-Siemens-Str. 60, + s( S% O# z# X
91052 Erlangen & n! U3 h! F9 F- n5 x
Germany6 `8 _8 p# v7 Q& B
Alternatively, it may be found at https://download.industrysoftwar ... ns.com/open-source/
) _! k9 J' W2 L3 r3 U w, _3 @
* z, K# }% r+ c9 t* J- a; M" b=======================
: p; |. k T5 p1 j, dOPERATING SYSTEM UPDATE4 C: c! t' E: h4 y, ^
=======================+ E$ p9 C- Q$ v5 L1 _. C+ l
In addition to the Operating System Requirements documented in the original 2022 Solid Edge readme, " W7 ~' j& S/ C: z* o( ~
Solid Edge 2022 MP2 has now been certified to run on Windows 11 Enterprise or Professional (64-bit only).' r. [1 A2 f+ ?1 S) p
; x, r' s" w4 O===============================" j; \' |! v& l; F
Internet Explorer – End of Life 4 j( J$ V* C) I" s
$ X$ v. w8 O9 i( F: |Microsoft Internet Explorer Desktop Application ended support for Windows 10 starting June 15, 2022. Enterprise
6 E8 K7 X2 X, A( Q, j7 Pcustomers are encouraged to move to modern browsers like Microsoft Edge.
0 U* d K" D9 U
. a1 a$ z2 D+ f; ?1 PFor more details about this change, please visit the official Microsoft Blog:
) B4 p! G& j2 G Nhttps://blogs.windows.com/window ... -in-microsoft-edge/
& V, A7 I" Z- w% k! W( U: Z! F: ?" a& x: u1 N7 x
========================- J0 x% L3 w+ a. K
Resolved PRs for this MP) p6 L/ q' [# x# n" Y
========================% m1 }1 ?* q& `0 l6 ?
5 _1 g9 Y, J' g6 W" s9 P1 g9 \8 C1 p
===Assembly===% s) {/ a7 w: Z% j
PR 10235622: Circular dependency error when creating relationships8 A' l) z" s/ I! [& H
PR 10303168: Creating a second feature on a Frame causes the first feature on the Frame to fail* }6 O; ~8 E5 a5 A ?- y1 r& B
PR 10404066: Solid Edge crashes while opening a specific assembly document
$ R3 [/ ?5 U+ g5 g5 Q/ T+ oPR 10354423: New Frames disappearing after editing existing Frames
0 x1 ~0 m, Q6 ?3 U g4 J, B6 M: PPR 10407894: Changing an unrelated hole feature value, is causing the finite depth to revert5 ]7 r X" w+ e3 ~
PR 10362559: Can't create a frame with mixed 2D and 3D Sketches.
5 R' q) S/ `- h% E# EPR 10373738: Some Frames in subs disappear from screen on file open$ Y4 ?9 E7 u, k/ v* y8 c( W
PR 10420156: Axial Align unlocking rotation after undo
+ m0 A& n0 y- Q' r1 v! ?: ]# T% A0 r0 i9 P9 p
===Draft===
) ]) O. T, L uPR 10394706: Session does not respond anymore after entering a value for a linear dimension% o' I/ a& D. e" w0 W
PR 10229076: Create 3D does not have any templates available
0 m8 T, A1 p8 s( `* o7 \PR 10393437: Contents explode after unblocking and moving objects
5 I" K" n( P( y* CPR 10304017: Customer is experiencing multiple crashes per day$ } \. Q5 j! W, ?$ J
" Y2 P% V" [9 O& s* f& r6 i- z
===General===
$ {& N/ ?0 ]# q6 R" {4 T. {PR 10377203: Random aborts when Windows 'Use text cursor' setting is "On"./ u K9 g4 B# P, x
PR 10378769: Hardware Part field missing in files created in SE V11
' u u- s6 d) T1 B& dPR 10408060: Custom properties deleted when part transformed to sheet metal
]/ m. r0 u0 H7 i' S; w; i1 a) b2 `0 h( b( r
===Part/Profile/Sheetmetal===. R! F- Q* `" {& z3 u; {
PR 10304484: Can't copy Sketch with conical curve created in Draft to part or PSM files
8 E5 I9 t5 O% UPR 10406495: Aborting using Inquire Element while changing variable, E- F5 g7 G1 y5 W4 ?
PR 10140212: Solid Edge crash when opening specific psm file/ s5 f) _! x* N0 {5 y
PR 8610042: Some items are displayed twice at File Properties dialog
3 M) G: M) c# ~/ M* ?0 Q! nPR 10423391: Reproducible crash when editing Chamfer! w0 I5 C# Z# o& N# X. P0 }
PR 201156: Solid Edge hangs when modifying a Bolt hole circle
0 |7 d3 F6 I. A& w8 b" r/ H' k" K9 L3 k5 f n9 ]8 r$ v
===Solid Edge Data Management===% f$ w% |3 n8 Q& R" ?5 w
PR 10398496: where used pops up when using "open draft"
, d. T* l6 L! Z# Q! E7 l& e4 c* qPR 10449224: BIDM workflow causes Available files to become Read-Only for customer. p* p9 ?. l% p5 S% a7 M- t
" l2 H( }) m/ r, P A9 ]! U5 p
===Teamcenter Integration for Solid Edge===% J# ^+ Q$ c1 f( o: X' M, n
PR 10322359: Default Template wrong linking in User Interface
* K3 N0 q/ d i+ ~9 C8 W. Y' h/ Z$ t3 {
===Translators===
2 _) F' @3 s" @+ jPR 10389672: Solid Edge crashes when translating to STEP if Part file is empty% K; u$ a2 I8 M) q4 D8 K
PR 10385320: Crash while opening DWG file into Solid Edge
- p- o- o; c) ?9 j" c. x! Z& J* B+ q6 F6 x
, y% ]8 g; g3 f; T6 |6 bEnd 0 v5 {7 n- s1 C+ b1 c# F
