本帖最后由 alian5337 于 2023-12-11 12:36 编辑 # a) O& p- V+ `; x
* W- V/ O- A! wRelease,PR Number,Description,Application,Function,Sub_Function
- Y. |8 }! x, p& K/ s& e& \. e2206.806,8611019,"The thickness of ""2D Mesh"" becomes 0",CAE,DES_SIMULATION,MS_THICKNESS8 r( h, e& Y. R* Q' o- Q1 D
2206.806,8611442,A joint with a large stroke breaks the entire Kinematics(2).,MFG_FIXTURE_PL,GENERAL,SUPPORT
* Y# ~; w% J( O* {2206.806,8616735,"(PS34.1.247) ""PK ifail 10 from PK_ENTITY_delete"" during trim sheet.",DESIGN,FREE_FORM_MODEL,EXTEND_SHEET3 o2 V6 ?) ^- C( [
2206.806,10331817,Deformed bodies is different from number of source bodies in NX2011,ASSEMBLIES,DEFORM,ALL# D; f& k4 S/ U$ U' ]
2206.806,10362703,Update Formboard Incorrectly Placing Overstock,ROUTING_ELEC,FORMBOARD_V2,UPDATE_FMBD
/ w7 T1 w$ U# Q- ?2206.806,10384126,Existing overrides are being deleted when running interactive check.,ROUTING_GENERAL,DESIGN_RULES,INT_CHECK6 N/ Q/ m6 L) [3 \/ e
2206.806,10418163,Overstock Disobeying Feature Definition,ROUTING_ELEC,FORMBOARD_V2,UPDATE_FMBD
/ Y' I, k- Y; {5 z, D: R2206.806,10467609,D.3) FRAC - units/offset problem,CAE,ADV_SIMULATION,FEM_CORRELATION
6 c" x2 K5 ]6 b4 w& u- R+ E2206.806,10469111,Problem with deformable component,ASSEMBLIES,PROMOTION,ALL) `% A5 O0 l! ^2 I; z- o% D0 V! S+ E
2206.806,10469619,Error creating/updating drawing view,ASSEMBLIES,PROMOTION,ALL( N$ m n( ~$ w* ?7 v( c2 `
2206.806,10471669,Initialize Project PDW failed in TC-managed-mode,KDA,PROGRESSIVE_DIE,ALL
* I+ d* Y; z+ r: H2206.806,10475752,STEP 214 Export: Mixed Unit Assy Fails in Managed NX only,TRANSLATOR,STEP_AP214,EXPORT_GEOMETRY- G2 `; R5 d, j
2206.806,10477851,NX Structure Designer: Cannot add component under the current environment,STRUCTURE_DES,MOUNT_FEET,ALL8 F7 f; s( R1 F
2206.806,10479095,"""Object is not logged"" Error when opening a part in NX2027",DESIGN,WAVE,DELAY: S: {! s( A/ ]
2206.806,10486787,"""Open Related Drawing"" while running UGII_LANG=german / polish fails",NXMANAGER,ASSEMBLY,COMPONENT_ARRAY! \2 W ~+ K4 t6 ?( R( t
2206.806,10490009,2D Exchange doesnt work with simple drawing parts,TRANSLATOR,UGTO2D,EXPORT_DRAFTING
. ]2 ]* F# o8 C2206.806,10490226,exporting mixed units assembly via STEP does not create any data in Managed NX,TRANSLATOR,STEP_AP214,EXPORT_GEOMETRY
' [; o$ R, L0 i: L% G2206.806,10491583,Errors while updating drawing views,ASSEMBLIES,PROMOTION,ALL0 k% J) J5 u+ l6 ?) I
2206.806,10492732,"Failed to update drawing views in NX 2006, but works fine with NX 1934",ASSEMBLIES,PROMOTION,ALL
# F. C8 }9 o! l6 I2 r7 g5 n2206.806,10493793,(PS34.1.247) error recovery failed,DESIGN,FREE_FORM_MODEL,EXTEND_SHEET6 a, M: m4 U; i: P2 l
2206.806,10496029,NX fails or crashes when exporting to dwg a drawing part,TRANSLATOR,UGTO2D,EXPORT_DRAFTING
- O5 F1 \. r' F+ g) Q2206.806,10505040,Nodes are unselectable in SIM and also in AFEM,CAE,ADV_SIMULATION,NODE_OPERATIONS5 A% | Y- B- h4 L8 A; \6 ^
* j$ B" f+ f$ G3 N |
