查看: 1042|回复: 0
[分享] 【Open drawing from BOM】
发表于 2022-12-13 14:18:20 | 显示全部楼层 |阅读模式 来自: 中国台湾
安装
主题分类用于问题归类:
/ d& p! G6 J0 U: ]
; p4 K& }( a/ Q1 e  K8 ~有網友在找,手邊正好有資料,轉貼分享一下~作者、出處如下:% N! d; E/ i6 |+ d) P+ q
0 K; m. H+ g9 z, j, E1 _' d
  Title: Open Drawing From BOM
4 W8 d- \+ I6 O* m! L' F  Version: 21.9.6                                 1 b/ P$ f' r# [+ G
  Author: Stefan Sterk                            ' D0 Z8 Q* V& ?# ?5 \) R1 [. R
  Company: Idee Techniek Engineering B.V.
) z* {  T/ T# ~" `1 H
  b; d' V% {  A" y4 v9 \/ k3 B4 l  i  This macro will open the drawing for the selected component(s) in the Bill of Materials.
. ]+ p8 q6 M( ?& z0 }) H* o5 F                                                  9 {. v) `$ C: n  R
  NOTE: Drawing file must be in the same folder as component and must have the same filename.    9 b8 v9 E) x' z: k  @2 a
& N2 c+ J3 c  H  t' U
+ a  }1 s9 [7 l- s. A
; f+ r5 x8 v* e8 j: s
  1. [hide]0 V! u6 w+ `( ?; P# z% W/ h# q
  2. Option Explicit
    8 q+ @+ Y3 B+ j: g2 O& @0 a
  3. Dim swApp As SldWorks.SldWorks: A9 N0 P1 z  M
  4. Sub main(). B+ |' u" v  }& Q
  5. Dim swModel  As SldWorks.ModelDoc2! ?9 o9 r6 B" U& N
  6.     Dim swSelMgr As SldWorks.SelectionMgr9 J% M" t) j" Y! j
  7.     Dim swTblAnn As SldWorks.TableAnnotation/ u. t& T6 G, s
  8.     Dim swBOMTbl As SldWorks.BomTableAnnotation9 c8 M0 q' T, R! r
  9.     Dim swComp   As SldWorks.Component2
    ( x$ e6 n8 z/ b. p* ^( L
  10.     Dim i As Integer, selType  As Integer
    2 c- Z4 {+ I9 H  w, u4 d4 R! B% C
  11.     Dim frtRow As Long, lstRow As Long) P9 v+ i# W, q2 U! {8 u! ^% L
  12.     Dim frtCol As Long, lstCol As Long1 K: y9 m1 G4 O
  13.     Dim Row As Integer( K1 L8 a; R  l( F) r5 ^7 g
  14.     Dim vComps   As Variant6 P. {6 Z- W2 v& p9 j0 X0 G6 P
  15.     Dim CfgName  As String
    / ~( |3 U  W. ]! X) i
  16.   U; K& }; u5 k, G3 C/ Y" u
  17.     Set swApp = Application.SldWorks0 V* K& V8 }- o7 ?& B
  18.     Set swModel = swApp.ActiveDoc
    4 Z9 p& w' f! K
  19.     If swModel Is Nothing Then Exit Sub
    - ^8 z6 \/ s% {3 g- a2 x4 v! F
  20.     If Not swModel.GetType = swDocDRAWING Then Exit Sub
    ' Q3 }) q# G- n' D  d2 [
  21.     Set swSelMgr = swModel.SelectionManager
    * M* ?7 n, K8 V) B: `
  22. ) O$ q  k3 p+ d& U% z
  23.     For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)" @3 D9 E$ T8 K
  24.         selType = swSelMgr.GetSelectedObjectType3(i, -1)0 {; t! |! l" ~3 Y
  25.         If selType <> 98 Then
    9 b& Q; A+ l: S* x# X8 e
  26.             MsgBox "Please select a cell from BOM!"6 J* |: m; q. m' H
  27.             Exit Sub
    - U7 u! c+ P" {. F: W1 d6 \: B# {  z
  28.         End If+ T$ \$ s3 ~6 F4 v$ ~
  29. / M" u  ?7 k* @' k$ _
  30.         Set swTblAnn = swSelMgr.GetSelectedObject6(i, -1)
    : C0 L! Z0 x: V
  31.         Set swBOMTbl = swTblAnn3 I5 w- Z( l9 F9 O4 `" D/ ?
  32.         swTblAnn.GetCellRange frtRow, lstRow, frtCol, lstCol3 J5 P7 ]. O2 ]& E8 S
  33.         For Row = frtRow To lstRow
    4 B8 L. v& D; _
  34.             CfgName = swBOMTbl.BomFeature.GetConfigurations(True, True)(0)
    3 o2 I5 V4 k/ m, J7 u! }0 u5 x3 h  v1 G
  35.             vComps = swBOMTbl.GetComponents2(Row, CfgName)/ ]3 \2 K+ z: V  L7 {: ]" E
  36.             If Not IsEmpty(vComps) Then
      U% Z9 w3 S: ^8 l  G8 f
  37.                 Set swComp = swBOMTbl.GetComponents2(Row, CfgName)(0)# B; h& U5 u' ^4 y. \
  38.                 openComponentDrawing swComp
    + K# f. u0 F( k/ u( \; y
  39.             End If5 m6 `5 H! ]8 R& N. U8 P) v: _* p
  40.         Next Row
    ( N  `' J9 U# w- ?7 ^5 `
  41.     Next i
    5 J/ {7 `* D8 j$ C
  42. End Sub8 Q5 E  i. A! z/ [
  43. 2 y! C, O1 C" ]: N
  44. Private Function openComponentDrawing(swComp As Component2)
    . m& s0 }1 M& D' j% r$ [# A5 Q
  45. ( P# x. c1 \. k! d3 R+ u
  46.     Dim compPath As String; [8 @$ u  U* V2 j- O
  47.     compPath = swComp.GetPathName
    $ n! \" k% B3 r
  48.     Dim drwPath As String# D5 _% C8 E, _" @7 O6 c) l7 H7 }
  49.     drwPath = Left(compPath, InStrRev(compPath, ".") - 1) & ".slddrw"' ?8 o% C0 |/ U0 q. }( d9 Y' T
  50. 5 ^4 C' Y. E2 }3 ^# {: Q5 t
  51.     ' Try Open Drawing
    2 `: H' @' T8 Q! a% }  V
  52.     Dim swDrw As SldWorks.DrawingDoc; j; g- `4 r4 R/ c
  53.     Dim errors As Long, warnings As Long6 f; m5 D& E/ \, d# O8 o: o- w/ @
  54.     Set swDrw = swApp.OpenDoc6(drwPath, swDocDRAWING, 0, "", errors, warnings); J9 e$ x; S8 Y$ R/ A- W6 t, {1 \
  55. + a. K6 w) _6 p8 k) x9 P: k( n
  56.     If errors <> 0 Then
    6 B+ ^# X7 H. k4 B/ m
  57.         If errors = 2 Then
    % |% W2 A0 c  s" {( i
  58.             Dim partNumber As String
    0 Y' l0 }" k( d3 x; H
  59.             partNumber = Right(drwPath, Len(drwPath) - InStrRev(drwPath, ""))/ [" N. F$ P  Z: N8 x
  60.             partNumber = Left(partNumber, InStrRev(partNumber, ".") - 1)
    ; L; w5 u- J# n/ X6 A! s
  61.             MsgBox "Couldn't find drawing for following part number: " & partNumber
    6 O7 n1 `! R2 R
  62.         End If
    $ v% C- X5 `* I+ ^' F2 }
  63.     Else0 x/ _3 s& J/ r( W1 ^8 ]
  64.         swApp.ActivateDoc3 drwPath, False, 0, errors1 q0 c' L  ]) Y& H' _: m9 U$ Y
  65.     End If
    8 Y$ j" Y+ m7 y2 C* L
  66. End Function
    7 ?( G3 N3 S2 b5 i5 W- W3 j! u1 _4 |& v
  67. [/hide]
复制代码
7 X3 k- n( E8 b" [; y+ T, U# m
. L. v: E1 ~& k* N# M' }( P6 p7 `* g) H) K
