本帖最后由 shituo 于 2025-9-9 11:45 编辑 6 C( Q" _+ T" H. @, j) ^- U
9 ^6 y: }9 t3 K* ~' a& p! v+ ISub GetCutListItemsProperly()
/ g2 ~0 H( E. Z' {1 x8 ]; X1 n& B, d0 h' A, i$ e4 Q- M
Dim swApp# _# A/ f) L# ]( @
Dim swModel3 d: ^5 |2 `* S: V3 b6 Z5 ]
Dim swConfigMgr+ k) ]) m% L" ]$ l/ C: t1 A$ h6 e, D
Dim swConfig' G& ]' b' w, [: S# q8 E1 a4 t
Dim vCutListItems, N' v5 L. U# e
Dim swPart
# t. _4 m# e, V5 u1 A" t/ R. W: h Dim I2 Y1 R+ t% I* L( s5 Z$ C* m/ p4 t. b2 `
Dim swCutListItem
9 J0 @1 D' {: D1 I$ \ Dim itemCount
* }# ]6 i. `" Q+ R9 f% Y: ]9 M Dim ConfigName7 z) [& }, Z6 o6 F2 C0 x4 p
( A# p' i& h2 \5 [. M/ Q: K4 s: F( \1 g) o4 X! x) P
3 r( W/ ^, w3 @1 t" R0 _
Dim swClassFact
" Z% A4 M* q' L8 ~" A Dim swDocMgr( Z7 ^" Z3 T2 h5 `/ h
Dim swDocument10
! Z9 h1 X+ I& X7 k Dim swDocument13
( p' m0 t# q) d! r( l# k
0 ^- h$ Y8 w* @& i; Q
; c5 A4 `- z2 l5 w3 U( _ Dim swDMConfigurationMgr
" `; ^2 o: w0 X3 j. m, [+ w+ T Dim config
& ^$ q' f4 O8 Z8 _& @$ u( S0 b) k9 N. |# G
F: c& O9 z/ q( K7 }" g# M- m e1 J Dim sDocFileName As String4 Z S$ ^1 h, ]3 s! F9 K
Dim nDocType
! E& J- Y4 H+ A& c7 R3 j/ ?$ D Dim nRetVal- S, n& P# |6 J5 K
Dim sLicenseKey As String
3 r: D+ ?: ?0 r
# o& J+ S2 f& V7 C* ?2 r5 U
! y# k; [) {% x! A, K$ B1 u0 y& F
' On Error GoTo ErrorHandler
+ _4 J7 g2 C0 F9 L3 d2 J! ~7 s0 d
' 获取SolidWorks对象. s2 }/ e9 O; y0 K4 E$ l' p
Set swApp = Application.SldWorks. m. ] h6 W6 E T6 m
Set swModel = swApp.ActiveDoc, q! V: |+ O# D0 p9 Z
, @' ^* k1 [, e+ F* Q If swApp Is Nothing Then# N' c3 a4 l& s7 v: c9 T# c" N6 G
8 o4 K9 C: U$ T! S; n
Set swApp = CreateObject("SldWorks.Application")
! q. l% U4 m' b; O' G swApp.Visible = True
- D: u1 \# O# B End If- Y1 a, z! C/ }7 q8 C" ]
Set swPart = swModel! X* B2 c4 K' V
' 检查文档类型
3 O- d; o j2 A3 B. {/ C9 o2 z1 x& i If swModel Is Nothing Then
8 V5 J2 P% d2 O$ ?6 M MsgBox "请先打开一个SolidWorks文档。"
7 Y" l. ^7 v! a* K J Exit Sub/ ~5 P$ r7 m& N0 |5 |4 W: G2 y1 g
End If) Z, d! s& G( l+ l* \2 B* ^2 ^
& y7 o+ t& P9 X; S6 E If swModel.GetType() <> 1 Then ' swDocPART = 12 X: X7 _( H2 w8 Q. b3 }
MsgBox "请打开一个零件文档(.SLDPRT)。"! N; P" Y1 o: i) Y$ F
Exit Sub" j* L# z# _4 [* Q( ?# ~9 q
End If9 @2 b3 N7 T1 U7 W
6 C' q A8 V5 D) x0 S: l1 f" f6 K
Set swConfigMgr = swModel.ConfigurationManager' F( D. L8 ^3 l& ?: x0 C5 D
3 a# d0 J) ~; ^ V
' 设置要使用的配置名称
4 K! h' o& ~" Y1 T3 n+ B' configName = swModel.ConfigurationManager.ActiveConfiguration.Name ' 可以改为您需要的配置名称+ J+ B! M: N4 O, D0 M
' 指定配置名称
1 A h. J* u6 k# J N ConfigName = "默认" ' 替换为你的配置名称" f8 K7 k+ I; i% |8 ~( o+ |' w- |4 K
' swPart.UpdateCutList9 W" j3 `6 L1 J9 g/ r
' 获取指定名称的配置
9 Z, H0 \" X/ U/ I/ K0 {' Set swConfig = swConfigMgr.GetConfigurationByName(configName)
. f8 t. d/ @* b6 I$ r Set swConfig = swModel.ConfigurationManager.ActiveConfiguration) Y w0 g) [$ ~/ D
' Set swConfig = swModel.GetActiveConfiguration(configName)
* ]3 P9 l' c) `4 F" A' E! K If swConfig Is Nothing Then
' f) G0 Q+ ?+ @! ^: p+ j MsgBox "找不到配置: " & ConfigName) h" _3 {2 e- p; \. y0 _. S
: d8 n- U( G" d3 j1 {+ Y/ R
End If# o* k6 ~* v7 c- Q" V$ i6 d9 a
; \. G! C4 Y0 J. R ' 检查是否具有切割清单特征% v/ K5 ?- h& J( p0 e# T
'Dim hasCutList As Boolean! `" W3 \6 t& m. {' A
'hasCutList = CheckCutListExists(swModel)
" {$ A. n! H! U ~) B& k' D& |. ]& `'If Not hasCutList Then" e+ f: C" s5 m
' MsgBox "文档中未找到切割清单特征"! `1 t) H8 {4 L6 n' [
' Exit Sub& n q I/ Y7 q6 z8 g3 o, m9 H* r- r
'End If
+ c3 s. u/ Q8 l, F/ u% G! W- Q) y$ l/ _
' l% c( \3 I0 @7 X8 p) J
* p- f! M3 n) q4 S
1 Z. H9 z F! L0 W ' 获取配置管理器3 ~" X! ^4 b0 K9 c
- t, S1 b5 |0 d$ N% M0 ^3 \& w
# w _5 L9 m# H) w8 W( Z7 `' H- N
' 确保切割清单已更新
& |- C& Y: y" h- X5 I, a. y+ J' swConfig.UpdateCutList
/ g" t4 d6 h6 _& e6 Q% D& ?6 ['' swModel.UpdateCutList
' X# ^ x, Z$ X' 获取切割清单项目 -从配置中获,,,为什么用下面两条都是提示438
/ r/ g2 V& f0 J* {* s) Z. w'vCutListItems = swModel.GetCutListItems(), e' |* F |. u" @
vCutListItems = swConfig.GetCutListItems()) A1 W& l. N, h
, }4 ]0 B: ?$ A) Z. x( T
' `9 q& C* W% D6 C2 H
6 [6 W$ X- R; Q) `& j2 H( T- b% s' O4 sEnd Sub
5 Y1 H1 _! u' e) Y4 u) X% X$ g8 d- S3 J9 |7 G6 M3 [
