查看: 1912|回复: 4
[已解决] problem when transfer to .pdf file
发表于 2006-11-11 02:08:52 | 显示全部楼层 |阅读模式 来自: 加拿大
i use solidworks 2006 creating drawings.(more than 3 page in one file).and i want one of them tranfer to .pdf file.but i can't do it. 1 R0 h9 f. @" G" y1 ^# J
0 i" f; D% N4 p7 L/ f' o
when i use SAVE AS to .pdf file, all the drawing are transfered.
2 y6 P3 Q5 [) u$ u* ` ! \. I- s% f/ {4 W  x$ o
could someone tell me how to transfer one page to .pdf file.
7 Z' _7 V9 l" k3 p' f0 f1 V ; q8 u. H; U4 e) k
thks
发表于 2006-11-11 12:49:33 | 显示全部楼层 来自: 中国宁夏银川
网上word转PDF工具很多,搜一下就可以解决。
发表于 2006-11-11 13:13:11 | 显示全部楼层 来自: 中国上海
转图时有要求转的页面选择提示,选要转的不久得了。
 楼主| 发表于 2006-11-14 04:46:57 | 显示全部楼层 来自: 加拿大
回复 #3 zhangsj 的帖子
thks.
$ x; j! L  g! y5 o5 U: j& H图时有要求转的页面选择提示,选要转的不久得了。8 A) B! k# N* F3 @' x+ g2 g
6 ^" y3 J: q4 Z" O" r; c! ~) `but now ,if i save as ,i can't see this massage.( `& o  I* E2 ]
how can i get this 页面选择提示? what happen to my solidworks 2006 software?
发表于 2006-11-14 08:25:52 | 显示全部楼层 来自: 中国河北廊坊
File list and file name must be in English. You can try.
